Stromos & German E-Cars THREADSAMMLUNG
Re: Stromos & German E-Cars THREADSAMMLUNG
Hello, my stromos didn't want to charge and drive anymore, i have check engine light on and the message in the picture, anyone can help me with an advice? The car works until a battery element goes under 2.70V, flash check engine and the car stops. I charge the element until 3.2V but the car doesn't want to start, not even the charging.
Thank you!
Thank you!
- Hat sich bedankt: 814 Mal
- Danke erhalten: 955 Mal
Hello and welcome to the forum!cristy081 hat geschrieben:Hello, my stromos didn't want to charge and drive anymore, i have check engine light on and the message in the picture, anyone can help me with an advice? The car works until a battery element goes under 2.70V, flash check engine and the car stops. I charge the element until 3.2V but the car doesn't want to start, not even the charging. Thank you!
Please open a new topic and link to it. Here in this topic /strand only the links should be collected if possible. Otherwise things will become confusing too quickly.
I do not know the display in the first picture in the upper line of the speedometer.
If the car is not charging, the reason may be too low battery temperature. But that's out of the question at the moment?
In my opinion, the second picture of the display shows that no AC voltage is present.
Hello,
i'm from Romania and buy this car with battery problem, i change all battery cell that have problems(almoust all ) and the car work fine but didn't want to show the menu on the display only says battery enladen, i charge every cell separately to 3.2V ( ballanced ) and the display show me all information ( U, I, Temperature, km )
after that the car work's fine but only charge to 86% and then balancing forever( i let 30 hours that operation ). Another problem is when i accelerate a little more the coolant light flash or remains on, did you now if there is a sensor on coolant liquid?
When 28% battery remains the check engine ( yellow pictogram ) flashing and after that remains on and the car stops. I try to charge but without succes. i understand the check engine flash when one cell is under 2.7V.
After that i checked every single cell ( can i verify in the future that without dismount the battery box ? Some software or connection to bms ?) and in the front tunnel were is the actia BMS controller i find one that it have under 2.6V and charge it tot 3.2V. Mount everything back again but the yellow check engine remains light (on) and didn't want to start or charge. It some possibilities to reset controller or something?
the actia bms controller have some led's, an ethernet port, serial port, can this help me diagnosticate the system?
do you know what can cause the check engine remains on ?
i verify all fuses, connectors, i put a new12V battery, i"l try to charge with 230v and 380V but the same screen
- Hat sich bedankt: 86 Mal
- Danke erhalten: 59 Mal
Hi Cristy081,
This thread is just for collect all GEC threads. "Threadsammlung" means "thread collection". It is NOT here to post any problem, that would end in a mess. You ignored the advice from Joe-Hotzi to open a new thread.
PLEASE open a new thread for your problem in the subforum Serienfahrzeuge and click on "Neues Thema erstellen" (which means "open new thread").
Then post the link to your thread here, so everybody can see it.
Operations Manager | ChargeX
2015: Stromos, 2018: i-MiEV, 2019: Leaf, 2020: Ioniq
2013-19: Kfz-Lehre + Studium; Projekt 150 kW-Station (ChargIN); 2020-22: alpitronic
kW ≠ kWh ≠ kW/h --- Mein Rückblick 2010-2020
Zum Problem von "cristy081" habe ich nach Absprache mit Ihm ein neues Thema:
"Stromos "cristy081" (German e-Cars) lädt nicht mehr" erstellt, bitte dort antworten, damit es übersichtlich bleibt.
Danke Joe-Hotzi! Habe es in die Liste im Anfangspost eingetragen.
In Stromos GEC (German e-Cars) 2018 Servicetermin /Infos berichte ich von meiner Fahrt nach Kassel und vom Service-Termin bei GEC in 10/2018.
Zurück zu „German E-Cars Stromos“
Stromos . German E Cars - Federn
Antworten: 3von Andilux » So 16. Jul 2023, 17:28 » in German E-Cars Stromos - 3
- 976
Letzter Beitrag von stromostsee
So 19. Nov 2023, 20:51
Stromos - Batterie schwächelt
Antworten: 2von Forrest|Gump » Fr 15. Sep 2023, 21:01 » in German E-Cars Stromos - 2
- 816
Letzter Beitrag von Joe-Hotzi
Mo 2. Okt 2023, 00:02
