BMW EV - Neue OBD2 iOS/iPhone app für den i3
Re: BMW EV - Neue OBD2 iOS/iPhone app für den i3
- Danke erhalten: 36 Mal
@Tsr
sure,
just PM me your email address , so I can include you
sure,
- Hat sich bedankt: 26 Mal
- Danke erhalten: 20 Mal
- Hat sich bedankt: 347 Mal
- Danke erhalten: 144 Mal
i also would appreciate a connection to "a better route planner". That was the main purpose for me to buy an android phone, just to use the "electrified app" and get the data to "a better route planner".
The voltage of the 3 AC-phases is not displayed correctly /(220 / 0 / 220 ) V
for AC current there are 5 values ? and the unit is "V". I would expect 3 values with the amperage of the 3 phases. Thanks for your work !
BMW I3 120Ah, Tesla Model Y LongRange
@Dentec
thanks for spotting labeling issue
AC Current will be redesigned after upcoming UI changes,
it is in testing phase for different sources of data....
- Danke erhalten: 83 Mal
Bug in v1.0(8) and earlier: When battery temperatures are below zero, strange values are shown. After charging indoor @ 11 kW for half an hour, the temperature was positive, and then shown as normal values. Thus I suspect the strange values are a classic signed/unsigned bug, where 654,36 really should be (65436 - 2^16)/100 = -1.0C (which would make sense given the local weather).
Bug in v1.0(8): Graph is not shown with any grid labeling on my phone. It also looks like y-axis is not zero based, thus small fluctuations around 10,85-11,00 kW looks like massive changes. (Volt and current values also have strange distribution across phases, but that is reported before.)
- Dr.Zoidberg
- Hat sich bedankt: 65 Mal
- Danke erhalten: 260 Mal
- Danke erhalten: 30 Mal
@Orbit
good point, try v1.0 (10) pls
Can you try to press on (i) mark next to Charts
it is either view dimensions are not respected , for some reason
or you are in zoom mode already -> (i) will reset zoom to default.
@Dentec
should be doable.
New version available:
Rex view:
obviously, I dont have REX on my car but tests are welcome!
@Dentec
should be doable.
Code: Alles auswählen
- v1.0 (10)
- better WiFi support, internal implementation
- Fxed current (V) -> (A) label
- General tab: fix of temp values to be signed format
- added more REX motor relevant details
Zuletzt geändert von MaxD am Di 19. Jan 2021, 23:43, insgesamt 1-mal geändert.
ISmart 2.0.1 Iphone IOS
von Elektronaut Ralf » So 24. Dez 2023, 09:10 » in MG - modellübergreifend - 0
- 672
Letzter Beitrag von Elektronaut Ralf
Android-App für OBD2 auslesen
Antworten: 1von ZeroEmil » Mi 23. Aug 2023, 17:32 » in Niro EV - Laden, Ladeequipment - 1
- 908
Letzter Beitrag von KippA
Mi 23. Aug 2023, 20:22
EVC04 mit der iOS App Drive Green Next verbinden
Antworten: 1von McGismo » Mi 19. Jul 2023, 07:33 » in Private Lade-Infrastruktur - 1
- 650
Letzter Beitrag von McGismo
Do 20. Jul 2023, 09:43
iSMART-App binden/koppeln (iOS)
Letzter Beitrag von m.a.v. « Mo 8. Jan 2024, 16:29Antworten: 4
Verfasst in Marvel R Electric - Allgemeine Themenvon dlareg37 » So 24. Dez 2023, 23:50 » in Marvel R Electric - Allgemeine Themen - 4
- 1080
Maingau ESL: Neu iOS App - Version 4.0.0
Letzter Beitrag von Fritzchen-66 « So 28. Jan 2024, 13:04Antworten: 28
Verfasst in Betreiber, Roaming und Abrechnungvon k_b » Di 23. Jan 2024, 20:09 » in Betreiber, Roaming und Abrechnung - 28
- 2003
