BMW EV - Neue OBD2 iOS/iPhone app für den i3
Re: BMW EV - Neue OBD2 iOS/iPhone app für den i3
- Danke erhalten: 36 Mal
thanks for feedbacks shared , some got fixed
just need to move development further....
Note, new version available:
if possible , please share charging details.
so I can better finalize new UI....
Code: Alles auswählen
- v1.0 (6)
- Improved data pool time: faster values updates
- BT(default) and WIFI adapters: now current mode shown
switch still with this button. Bigger button: 25->30px
- Several WiFi related improvements for stability
- Prevent sleeping after StateInitializing; Start sleeping after disconnect
- Charging time: yet minor format fix
- Fix: if > 16A single phase => two charger spit load
- Fix of range_rex_cur
- Added pedal/throttle as % details
- Hat sich bedankt: 78 Mal
- Danke erhalten: 142 Mal
Hi Max, thanks for the update.
There is still an issue with the calculated AC charging power on three phases. It's the same effect as charging on one phase with more than 16 amps.
In the area of 8 amps, depending if the power is increasing or decreasing, the i3 is switching or combining phases between the two charging units differently.
@LocutusB
hmm...interesting...
can you pls share app screenshot for this case?
- Hat sich bedankt: 40 Mal
- Danke erhalten: 210 Mal
@LocutusB
please check 1.0 b8 version,
first screenshot problem should be fixed.
@AQQU
thanks for confirmation
New version shared:
Example of Charging chart:
@AQQU
New version shared:
- v1.0 (8)
- Added graph of Charge Power
will show up at bottom of Charging Tab during Charging active
- (i) sign next to Charge Power resets zoom to default
- fix for "not yet populated Phase(s)" and Power calculation
- TODO: Grouping of pulling events for better UI responsiveness
- Hat sich bedankt: 49 Mal
- Danke erhalten: 29 Mal
Hi Max, with this version the update rate of the values is significantly improved. Nevertheless the update period of some values is still too slow to use it reasonably (e.g. battery power, speed or pedal throttle).
For suggestion:
It would be fine if the consumption can be calculated independent from the BC (over a defined period of time e.g. during a driving session, ...)
BMW i3 120 Ah mit Sportpaket (EZ 10/2020)
Energieverbrauch (inkl. Ladeverluste und Vorklimatisierung):
- Dr.Zoidberg
- Hat sich bedankt: 65 Mal
- Danke erhalten: 260 Mal
Now we need to persuade Max to put all of his work into a GSM-Dongle-thingy, so that all the data is available all the time.
i3 60 Ah Rex 2014 mein BMW i3 Farewell | Reiseplanung mit dem E-Auto
@GBrick
yeap, I have good thoughts here
@Dr.Zoidberg
are you aware about https://www.openvehicles.com/ ?
@Dr.Zoidberg
ISmart 2.0.1 Iphone IOS
von Elektronaut Ralf » So 24. Dez 2023, 09:10 » in MG - modellübergreifend - 0
- 632
Letzter Beitrag von Elektronaut Ralf
Android-App für OBD2 auslesen
Antworten: 1von ZeroEmil » Mi 23. Aug 2023, 17:32 » in Niro EV - Laden, Ladeequipment - 1
- 865
Letzter Beitrag von KippA
Mi 23. Aug 2023, 20:22
EVC04 mit der iOS App Drive Green Next verbinden
Antworten: 1von McGismo » Mi 19. Jul 2023, 07:33 » in Private Lade-Infrastruktur - 1
- 629
Letzter Beitrag von McGismo
Do 20. Jul 2023, 09:43
iSMART-App binden/koppeln (iOS)
Letzter Beitrag von m.a.v. « Mo 8. Jan 2024, 16:29Antworten: 4
Verfasst in Marvel R Electric - Allgemeine Themenvon dlareg37 » So 24. Dez 2023, 23:50 » in Marvel R Electric - Allgemeine Themen - 4
- 1045
Maingau ESL: Neu iOS App - Version 4.0.0
Letzter Beitrag von Fritzchen-66 « So 28. Jan 2024, 13:04Antworten: 28
Verfasst in Betreiber, Roaming und Abrechnungvon k_b » Di 23. Jan 2024, 20:09 » in Betreiber, Roaming und Abrechnung - 28
- 1989
