OVMS für den Soul
Re: OVMS für den Soul
I have now tested the OVMS for a while, and it works great, i have some questions regarding the last functions GOEV added. The door lock status in the app, and also in the DEBUG sms does not seem to work. It seems my doors are always locked.
The open/closed status works in the IOS app, but i only see the front two doors.
And i still do not see any charging stations in the map, i have tried to uninstall the app and install it several times, and this is the same both for the IOS and the android app.
Is it like this for all you others as well?
When talking about apps, i was wondering if anyone knows if there is and update for the IOS app on the way, in the Andriod app I have a timer when charging that i really would like to have in the IOS app as well.
Again thank you for all that have contributed to making this possible.
- Hat sich bedankt: 16 Mal
Ich habe das OVMS nun mit Dexters verlinkten Version für die 808er Version ein paar Tage testen können. Die hier im Thread beschriebenen Funktionen BATT, BTMP, BCV oder TPMS funktionieren hiermit nicht oder muss ich dazu spezielle Feature einstellen?AlKl hat geschrieben:Hy, every firmware is overwriting the complete programm, so you only need the latest version from Goev. It includes the whole programm.
Are the other commands (BATT, BTMP, BCV, TPMS) working?
Ich würde mich gern an der Arbeit hier beteiligen und eine "Command overview" wie für den Twizy erstellen - als Ergänzung zur schon erstellten tollen Bedienungsanleitung. Woher kann ich den Input dafür bekommen, welche Funktionen es überhaupt gibt?
Grüße
Gunnar
- Hat sich bedankt: 89 Mal
- Danke erhalten: 212 Mal
I think Geir isn't following this thread, maybe you should contact him directly. My build contains Geir's latest submission to the master repository, if there is a newer version he just needs to merge that with the master.
Michael
Twike 3 (2001) … Emco Novum (2009) … Twizy 80 (2012) … Mii electric+ (2020)
https://dexters-web.de
- Danke erhalten: 8 Mal
Puhhh, so ich hab jetzt mal den ganzen Thread überflogen, mir raucht gerade der Kopf
Ich will mir das OVMS auch einbauen, da mir die App aucch abgeht (hatte mein i-MiEV zwar auch nicht)
gibt es eigentlich für die Android App ein Foto vom Soul, oder muss ich damit angeben das ich einen Roadster besitze
Werde mich heute abend noch mal insetzen und die Anleitung studieren, und mir eventuell gleich die Teile dazu bestellen.
Einzig was ich ncith will ist im Soul irgendwelche Kabel anknabbern wenn es möglich ist alles über den OBD zu machen bin ich glücklich
elektrische Grüße
Thomas (Elko)
elektrische Grüße
Thomas (Elko)
2012-2013 Tazzari Zero
2013-2016 Mitsubishi i-MiEV
seit 2015 CityEL
seit 2016 Kia Soul EV
http://www.elko-electric.at
"Wer braucht V6 oder V8 ?
Ich hab 360V DC!"
seit 2015 CityEL
Ich hab 360V DC!"
- Hat sich bedankt: 125 Mal
- Danke erhalten: 177 Mal
Dann hast du alles richtig gemacht!Elko hat geschrieben:Puhhh, so ich hab jetzt mal den ganzen Thread überflogen, mir raucht gerade der Kopf
So wird es sein, ohne knappern etc. OBD einstecken und mittels Kabel auf das OVMS, dort drann eine GMS und eine GPS Antenne, dann mittels SIM und Datenverbindung auf mein Handy OVMS App (so bei meiner alten Version).Elko hat geschrieben: Einzig was ich ncith will ist im Soul irgendwelche Kabel anknabbern wenn es möglich ist alles über den OBD zu machen bin ich glücklich
38m2 FlachK. > 260'000kWh
1.5kWp PV > 10'000kWh
09.14 - 07.15 i-MiEV 13500km
gibt es noch die alte version mit SIM und Server ?
wer weiß da bescheid ?
Danke
elektrische Grüße
Thomas (Elko)
Danke
elektrische Grüße
Thomas (Elko)
seit 2015 CityEL
Ich hab 360V DC!"
seit 2015 CityEL
Ich hab 360V DC!"
- Danke erhalten: 14 Mal
Ja gibt es, alle verfügbaren FarbenElko hat geschrieben: gibt es eigentlich für die Android App ein Foto vom Soul, oder muss ich damit angeben das ich einen Roadster besitze
Was meinst du mit alter Version?Elko hat geschrieben:gibt es noch die alte version mit SIM und Server ?
Die OVMS Hardware gibt es nur mehr mit der neuen Version (2.5) zu bestellen, funktioniert aber gleich wie die alte Version, es wird aber eine neue "Firmware" benötigt. Ob die schon kompiliert wurde weiß ich nicht, könnte aber Dexter fürn Soul machen?
VG, Alex.
Zurück zu „Soul EV - Allgemeine Themen“
OVMS 3.x für Zoe ph1 , in Kürze auch mit Vorklimatisierung
Antworten: 17von BinKino » Mi 21. Feb 2024, 21:19 » in ZOE - Zubehör - 17
- 1211
Letzter Beitrag von Dimitrie78
Mi 28. Feb 2024, 21:11
"Soul EV PE (MY'23)" versus "Soul EV (MY'23)"
Antworten: 2von eHannes » Mi 18. Okt 2023, 21:32 » in e-Soul - Allgemeine Themen - 2
- 1061
Letzter Beitrag von eHannes
So 22. Okt 2023, 19:24
(Kosten-) Fazit nach 2 Jahren e-Soul
von Alfa.Tiger » Fr 12. Mai 2023, 15:07 » in e-Soul - Allgemeine Themen - 0
- 1267
e-Soul gebraucht – Kilometer vs. Baujahr
Antworten: 7von alexander7 » Do 7. Sep 2023, 12:02 » in e-Soul - Allgemeine Themen - 7
- 1480
Letzter Beitrag von ManuelF
Mo 13. Nov 2023, 07:12
KIA e-Soul Dyno - Leistungsprüfstand
Antworten: 5von prrinz » Do 16. Nov 2023, 11:14 » in e-Soul - Antrieb, Elektromotor - 5
- 791
Letzter Beitrag von prrinz
Fr 17. Nov 2023, 08:51
