OBD2 Diagnosegerät für Renault ZOE erhältlich!
Zubehör für den Renault ZOE
Re: OBD2 Diagnosegerät für Renault ZOE erhältlich!
- Hat sich bedankt: 30 Mal
- Danke erhalten: 40 Mal
Please forgive me for posting in English. I would make a fool of myself posting in German really.
I am considering reverse engineering some of the functions that are available through the i907. For this (slow and tedious) process, I am either considering a true ELM 327 chip http://www.elmelectronics.com/obdic.html (most of the CN plugs are bootlegs of their 1.0 firmware, which is horribly outdated and will not run on the Zoë at all), or using a CAN library that was developed for the Arduino Due last year. http://forum.arduino.cc/index.php?topic=131096.0
I would be very interested in the following items:
1) are there other people who have tried, or are trying to hack into the Zoë's CAN bus? If so, what have you already learned?
2) has anyone tried a true ELM327 or Arduino Due with CAN tranceiver (or maybe another controller) succesfully on the Zoë?
3) are people interested in working on a project like this? *)
Thank you!
Jeroen
ps: my personal drive for this project is that I want to know, in real time, what the SOC is of the battery while it is charging at my house. I need this information for energy managment in combiation with the PV system and would probably connect with the house network through WiFi. However, I do understand that many more usages can be envisioned once there is a programmable query tool available.
*) I am the first to admit my time is limited and I cannot fully commit to a project like this. As I have not heard of a working solution yet on a programmabale device or a PC, it requires some hardware building **), substantial software development, and tedious hacking through the message hex data. On the other hand, as soon as sending and receiving CAN data is working, work can be distributed a bit more, especially to people who own a i907 (or a true working CLIP system ) and are willing to hack around.
**) maybe the hardware interface between the Due and the CAN bus can be bought, i.e. as these http://www.ebay.com.au/itm/281524910459 (tranceiver only) or http://www.ebay.com.au/itm/221529570072 (controller and tranceiver, so a Due would not be needed, but then again, I am not aware of any existing arduino CAN library for this controller)
Thank you!
Jeroen
Jeroen - ZOE Q210 Nov 2013 - PV powered - CanZE co-developer http://canze.fisch.lu
Today, I did my second measurements on the Zoë's OBD2 bus (the first one being the unsuccessful ELM327 plug experiment).
Long story short, there are definately two CAN busses on the Zoë. One on the pin 6/14 pair (which is considered standard), and one on the pin 12/13 pair (which are basically manufacturer's discretion pins). Both have a 60 ohm impedance when the car is powered down (wait 3 minutes after all off and doors locked), which is a very clear hint of CAN. The busses are not connected.
Another hint is this page: http://pinoutsguide.com/CarElectronics/ ... nout.shtml which I found after my measurements They seem to suggest a secondary CAN bus indeed on pins 12/13, mainly for multimedia but
Anyway, I think the next step is to hook up a oscilloscope to both busses to see the data rate and what is happening. Also, if I can find my ELM327 <> bluetooth plug , I will try to rewire it to pin 12/13, see what happens. I will keep you posted.
ps: If you think I should open a new thread for this, please let me know.
There is a lot of confusing info on that page suggesting the speed of the multimedia bus is faster, then slower depending on where you look. Also note that the page is specific for Renault, but not for the Zoë.Pins 12, 13 used for low speed CAN bus, also called as multimedia CAN bus, in some new cars, as Megane 3, Fluence and other... this bus also important for diagnostic.
Mit Hilfe von euch (Danke!), sieht der Grafik "Maximum charge power" jetzt schon so aus:(Vorherige Beitrage)
hab mir auch das i907 gekauft und schon ein bisschen was ausgelesen.
Die Grafik sieht interessant aus, allerdings hätte ich die Daten glaub ich lieber als Tabelle. Meine gesammelten Werke liegen unter https://dl.dropboxusercontent.com/u/350 ... ePower.xls.
LG Sven
LG Sven
Danke schön Sven!
Im moment verarbeite ich die Daten bisher erhalten. Ich versuche ein 2D-Grafik zu machen der man einfacher lesen kann statt der 3D-Grafik.
In der Zwischenzeit las bitte die Daten kommen!
Vor allem, wenn jemand Daten hat um eine Batterietemperatur von <= 5°C oder >= 17°C.
EVC 95 - Max charge power [kW]
EVC 109 - T battery [°C]
EVC 112 - Battery %
EVC 112 - Battery %
ich weis ja nicht ob für irgendwem interessant, aber ich habe mal die verfügbaren Datenpunkte von dem i907 zusammengeschrieben. bei Interesse sende ich gerne das komplette xls per PN
hier ein kleiner Auszug daraus:
iCarSoft i907
PEB
1 Sperre Erregung Geschlossen
2 +nach Kontakt Steuergerät Vorhanden
3 Sperre Spiderbox Geschlossen
4 DCDC-Zustände Ein
5 DCDC-Fehlerklasse A
6 Code Anlasssperre gespeichert Ja
7 DCDC-Aktivierungsanforderung Ein
8 geschaltetes Plus vorhanden Ja
9 Schutz Nicht geschützt
10 Fehlerklasse elektrische Maschine A
11 Spannung Antriebsbat. gemessen d. PEB 394 V
12 Messung der 14 V-DCDC 13.53 V
13 Messung der 14 V-DCDC-Stroms 1.33 A
14 Temperatur des DCDC Leistungsmodul 19.34 C
15 DCDC-Temperaturanzeige 39%
16 Motordrehzahl 0 rpm
17 Anzugsmoment angefordert 0 Nm
18 AUF Anzugsmoment angezogen 0 Nm
19 Tatsächliche Ondulatortemperatur 19.30 C
20 Batteriespannung 13.63 V
21 DCDC-Steuerspannung 13.60 V
22 Ondulatormodul Aus
23 STROM gemessen durch PEB 0 A
24 Zusatzinformationen 301E 0
25 Zusatzinformationen 301F 0.06
26 Zusatzinformationen 3021 0.06
27 Zusatzinformationen 3022 -0.03 A
28 Zusatzinformationen 3023 0.10 A
29 Zusatzinformationen 3029 14 %
30 Zusatzinformationen 302A 17 %17%
31 Zusatzinformationen 302D 0
32 Zusatzinformationen 302E 0
EVC
1 Magnetventil Kühlkreislauf Fahrgastraum inaktiv
2 Rückmeldung Geschwindigkeit Gebläse 43690 Hz
3 Steuerkreis Gebläsemotor 42 Hz
4 Bremse Servolenkung-Druck Zustand 3
5 Vakuumpumpe Aus
6 Einges. Leist. Oder Starttaste gedrückt Nein
7 Geschw.Regler von EVC gesperrt Nein
8 Geschw.Begrenzer v EVC gesp. Nein
9 Geschw.Regler von EVC gesperrt Ja
zeigt schon ganz interessante Daten das kleine Ding
iCarSoft i907
PEB
4 DCDC-Zustände Ein
EVC
5 Vakuumpumpe Aus
Die reinste Form des Wahnsinns ist es, alles beim Alten zu lassen und gleichzeitig zu hoffen, dass sich etwas ändert. (Albert Einstein)
bestellt: ZOE ZEN 17.jänner 2013 >>> seit 26.Juni.13 Freude pur!!!
- Danke erhalten: 18 Mal
- Hat sich bedankt: 425 Mal
- Danke erhalten: 450 Mal
Und als .xls.png hochladen und entsprechend kennzeichen? Umbenennen kann's ja jeder selber.
Gruss
Umbi
Gruss
Umbi
Unterlagen bei Citroen jetzt erhältlich, fehlende Ausstattungen
Antworten: 9von rmX » Fr 2. Feb 2024, 19:42 » in ë-C3 - Allgemeine Themen - 9
- 1287
Letzter Beitrag von Fu Kin Fast
Do 8. Feb 2024, 22:12
Passender OBD2 Dongle
Antworten: 2von BadSmiley » Mo 12. Jun 2023, 19:51 » in Niro EV - Infotainment - 2
- 1234
Letzter Beitrag von BadSmiley
Fr 16. Jun 2023, 08:55
- 1067
Letzter Beitrag von Vrabetz
Do 22. Jun 2023, 20:48
Torque Pro zum OBD2 Daten auslesen
Antworten: 6von s.krey@gmx.net » Mo 10. Jul 2023, 18:02 » in IONIQ 6 - Allgemeine Themen - 6
- 1204
Letzter Beitrag von sieg
Mi 12. Jul 2023, 15:15
Android-App für OBD2 auslesen
Antworten: 1von ZeroEmil » Mi 23. Aug 2023, 17:32 » in Niro EV - Laden, Ladeequipment - 1
- 899
Letzter Beitrag von KippA
Mi 23. Aug 2023, 20:22
