OBD2 Diagnosegerät für Renault ZOE erhältlich!
Zubehör für den Renault ZOE
Re: OBD2 Diagnosegerät für Renault ZOE erhältlich!
- Hat sich bedankt: 280 Mal
- Danke erhalten: 213 Mal
Bei mir hat sich vor kurzem der SOH auch um 1% nach oben bewegt.
Eine wundersame Heilung, ich brauchte nur meine Hände ans Lenkrad legen. Stelle hiermit meine Fähigkeiten als Akkuheiler gegen Gebühr zur Verfügung (Es wird keine Garantie zur erfolgreichen Heilung übernommen, bereits bezahlte Gelder werden nicht refundiert).
- Hat sich bedankt: 30 Mal
- Danke erhalten: 40 Mal
My apologies, the question about the cell count had fallen through the cracks.
The car has 192 pouch cells made by LG chem. Each cell is 3.75 volt, 36 Ah.
They are paired to form 96 cells, 3.75 V, 72 Ah.
8 of those pairs are wired in series into a module, that has its own temperature sensor. A module is 30 V, 72 Ah.
12 of those modules are fitted in the battery modules, so the back is rated 360 V, 72 Ah = 25.92 kWh
Jeroen - ZOE Q210 Nov 2013 - PV powered - CanZE co-developer http://canze.fisch.lu
- Hat sich bedankt: 26 Mal
- Danke erhalten: 14 Mal
I am confused, the cell voltage "heatmap" works on my end, i don't think it has been changed in ages.
Please check or report in https://github.com/fesch/CanZE/issues with details if there's something going on.
Hi Jeroen!
It's not the heatmap, I was talking about, it is the "flying red dots" on the Battery-screen, lower left, titled "Cell Voltages (V)"
Regards
Manfred
Regards
Manfred
jmeijer hat geschrieben:I am confused, the cell voltage "heatmap" works on my end, i don't think it has been changed in ages.
Hi Manfred,
I then assume you are referring to issue #329. This has been fixed in release 1.12 which was released on April 11th. See screenshot. If the solution is not working, please ammend / reopen issue #329 https://github.com/fesch/CanZE/issues/329 (I know it doesn't describe this issue, but the fix was posted under that one). I am stressing to follow this route as this particular part was not build by me and I am not the "issue-dispatcher/controller"
Jeroen
Jeroen
Hi Jeroen!
I have installed: Version 1.12 // Build: 2016.04.11 @ 07:56
And the bottom left field is empty
I have read about a fix, and that it will be implemented in next release.
And because it is not working for me, I am waiting for the next release, and waiting, waiting............
So this led to my question: "I've heard, that there is a fix, but it is not yet published."
Now I know: it is already released
An I have to do research, why it does not work on my device
Thank you, for making that clear.
Regards
Manfred
Regards
Manfred
jmeijer hat geschrieben:Hi Manfred,
I then assume you are referring to issue #329. This has been fixed in release 1.12 which was released on April 11th. See screenshot.Screenshot_2016-05-15-14-52-50.pngIf the solution is not working, please ammend / reopen issue #329 https://github.com/fesch/CanZE/issues/329 (I know it doesn't describe this issue, but the fix was posted under that one). I am stressing to follow this route as this particular part was not build by me and I am not the "issue-dispatcher/controller"
Jeroen
Dera Manfred,
I can only say it works for my car - dongle - phone combination. There are always subtle differences that are sometimes hard to catch.
If you are up to it (but nobody expects this from you) you can get the source from github and have the day-to-day work. Otherwise, yeah, you have to wait until there is "enough" that warrants a release. I don't know if you have CanZE installed through the play store, but updating there is automatic. For manual updates, you'd have to follow the blog to be informed of new releases.
Again, if you would like us looking into this (and we love fixing bugs), we kindly request you to post as much details as possible, and do it in the issue tracker (i.e. screenprint and if the voltage heatmap works, because then we can exclude the dongle / car). Posting here will risk not being read, read later, not reaching the developer responsible and loosing other readers here because of overwhelming details about one issue.
Hi Jeroen!
It does not work for me, neither on phone nor on tablet, both with CanZE fresh installed from playstore.
Voltage heatmap O.K. on both.
Screen shot looks the same as yours, except the red, blue and green lines/dots, scaling is 3,4,5.
Manual updates: I would like to do, but what I read on github, seems to be far from my skills, I am no Android App Developer.
I will open a new issu (unable to reopen), with a reference to this thread.
Thank you taking my problem serious.
Regards
Manfred
Regards
Manfred
jmeijer hat geschrieben:Dera Manfred,
- Hat sich bedankt: 155 Mal
- Danke erhalten: 73 Mal
Hi,tommy_z hat geschrieben:
Was bleibt, ist raten und selber testen. ZUSATZINFORMATIONEN 1407 = 8.35 kW unter LBC (Batteriesteuerung) könnte z. B. die maximal zulässige Energie sein, die das Ladegerät zu einem bestimmten Zeitpunkt zulässt. Ist die Batterie leer und einigermaßen warm, könnte das Ladegerät 43 kW zulassen (zumindest beim Conti-Motor), bei SOC 99% evtl. nur noch 3 kW. Man müsste einen Ladevorgang mit angeschlossenem Gerät monitoren und den LBC-Punkt 34 über die Zeit beobachten, um zu testen, ob diese Annahme stimmt.
das i907 macht nur was die Renault CLIP Konfiguration hergibt. Das kann dieses Pythonapp auch.
Das ist der 1407:
LBC DataRead 1407 Input Possible Power (After Restriction) Sendbyte 221407
Unterlagen bei Citroen jetzt erhältlich, fehlende Ausstattungen
Antworten: 9von rmX » Fr 2. Feb 2024, 19:42 » in ë-C3 - Allgemeine Themen - 9
- 1267
Letzter Beitrag von Fu Kin Fast
Do 8. Feb 2024, 22:12
Passender OBD2 Dongle
Antworten: 2von BadSmiley » Mo 12. Jun 2023, 19:51 » in Niro EV - Infotainment - 2
- 1220
Letzter Beitrag von BadSmiley
Fr 16. Jun 2023, 08:55
- 1059
Letzter Beitrag von Vrabetz
Do 22. Jun 2023, 20:48
Torque Pro zum OBD2 Daten auslesen
Antworten: 6von s.krey@gmx.net » Mo 10. Jul 2023, 18:02 » in IONIQ 6 - Allgemeine Themen - 6
- 1191
Letzter Beitrag von sieg
Mi 12. Jul 2023, 15:15
Android-App für OBD2 auslesen
Antworten: 1von ZeroEmil » Mi 23. Aug 2023, 17:32 » in Niro EV - Laden, Ladeequipment - 1
- 872
Letzter Beitrag von KippA
Mi 23. Aug 2023, 20:22
