OTA For ioniq 5 is planned for December 16th
- Hat sich bedankt: 131 Mal
- Danke erhalten: 750 Mal
Evening fellas.
I just got info sent to me directly in private, coming from a hyundai dealer in Europe, stating that an update for ioniq 5, is coming on 16th of December, which will enable the ota on ioniq 5.
A portal was mentioned for download. It was not clear to me if that's a dealers portal or customer portal (self update).
Edit: both portals will have the new update.
After this update, ota for map should become active.
But nevertheless, it's a good news. Early Xmas present
Oh and it's ota for map only...
Zuletzt geändert von SonicSpinner am Di 14. Dez 2021, 00:03, insgesamt 1-mal geändert.
Re: OTA For ioniq 5 is planned for December 16th
- Hat sich bedankt: 364 Mal
- Danke erhalten: 392 Mal
- Hat sich bedankt: 185 Mal
- Danke erhalten: 626 Mal
I am sorry, but that has nothing to do with your title "OTA", OTA means "over the air", that is, when your car informs the driver the next morning, that an update has been downloaded and ask you, if you want to install it now or later.SonicSpinner hat geschrieben: ↑ Evening fellas.
I just got info sent to me directly in private, coming from a hyundai dealer in Europe, stating that an update for ioniq 5, is coming on 16th of December.
OTA means directly over the air to your car, over the air.
What you mean, that is quite a normal self-conducting upload process by internet, by cable, not over the air from a server from Hyundai to your computer, download it by yourself, upload the data on a USB-stick by yourself and stick this USB-device into the socket of your car, that is miles away from an OTA-process.
- Hat sich bedankt: 2891 Mal
- Danke erhalten: 886 Mal
@michelsberg: Yes, that is clear. But I don't know, if Hyundai will make that happen und if, when that will come true.
On the other hand, I am not sure, if I want that, Hyundai or who ever might have hacked the code, can send to your car what ever they want, that can also be by example a reduction of the maximum speed or your battery will be smaller after an update or a hacker might block your car or wahtever.
Maybe I am paranoid, maybe .....
Ok...Udomann hat geschrieben: ↑I am sorry, but that has nothing to do with your title "OTA", OTA means "over the air", that is, when your car informs the driver the next morning, that an update has been downloaded and ask you, if you want to install it now or later.SonicSpinner hat geschrieben: ↑ Evening fellas.
Sorry, I didn't explain my self clearly.
I just edited the first post
Definetly paranoid as hell. You shouldn't even be online. Kim jun ung is watching you!Udomann hat geschrieben: ↑ @michelsberg: Yes, that is clear. But I don't know, if Hyundai will make that happen und if, when that will come true.
Problem nach OTA Update
Antworten: 40von MathiKralli » Di 9. Mai 2023, 09:53 » in IONIQ 6 - Allgemeine Themen - 40
- 8081
Letzter Beitrag von ExOctavianer
Do 24. Aug 2023, 06:50
Auto. Infotainment OTA-Download - HAKEN setzen?
Antworten: 6von drehstrom » Fr 19. Mai 2023, 16:50 » in e-Niro - Allgemeine Themen - 6
- 1410
Do 30. Nov 2023, 06:47
OTA Update startet nicht
Antworten: 5von cvoelker » Sa 8. Jul 2023, 20:24 » in ID.3 - Allgemeine Themen - 5
- 2930
Letzter Beitrag von Hajo46
Di 27. Feb 2024, 18:00
OTA-Funktion aus?
Antworten: 9von mgraeber » Do 20. Jul 2023, 09:36 » in EV6 - Allgemeine Themen - 9
- 1539
Letzter Beitrag von EV6-Joerg
Sa 22. Jul 2023, 14:29
OTA-Funktion aus?
OTA/FOTA - Gibt es eine Aussage von MG dazu?
Antworten: 17von FoodHill » Mi 2. Aug 2023, 10:45 » in MG4 Electric - Allgemeine Themen - 17
- 1946
Letzter Beitrag von galu
Do 3. Aug 2023, 14:37
