BMW EV - Neue OBD2 iOS/iPhone app für den i3
Re: BMW EV - Neue OBD2 iOS/iPhone app für den i3
AC charging:
Charged with go-eCharger at 11 kW, so I think the charging power is plausible. What I was confused about, are the zero values (AC Voltage and AC Current) and the values of DC Voltage and DC Current. Is this because of the AC/DC-Converter?
Today I checked odometer two times and it matched with the odometer of the car.
Has the i3 somewhere data for the charging ratio (for example 70 % AC, 30 % DC)?
- Hat sich bedankt: 1632 Mal
- Danke erhalten: 1114 Mal
Twitter
How do you detect the charging power on DC
FAQ-Thread für den BMW i3
- Danke erhalten: 36 Mal
new updated build pushed,
noticably : WiFi adapters should be supported
(app does NOT provide WIFI setup and assumes that you've done setup pre-work)
Code: Alles auswählen
- v1.0 (5)
- Switches between BT(default) and WIFI adapters by clicking top-left icon
- Prevents sleeping after StateDiscovering until StateGone
- Charge DC / Phases visualization fix
- Charging time: format fix
- StatusLabel contains version(build) details
- Explicit option to share internal log over email as simple text format
logs are cleared this action.
- WIP: Log charts design
Zuletzt geändert von MaxD am Fr 15. Jan 2021, 12:51, insgesamt 1-mal geändert.
@M1289
these are needed for testing only over different data sources, w
will be removed later,
Charging is "AC" or "DC" only,
pretty much, not all at once...
@Fridgeir
OBD interface has several sources...
not sure if this answers your question at full
@Fridgeir
- Danke erhalten: 83 Mal
The new BT/WiFi icon is a bit confusing, as while using BT, it shows WiFi (for switching to that), and vice versa. Is there room to rather have a toggle switch where both options are visible at all times, and the active one is highlighted?
How should the "Cell aging factor" be interpreted (showing [0.6985])?
Feature request: When showing battery cell data, also show which cell that reports the min/max values. E.g. is the cell with the lowest voltage/SoC/capacity also the one with the lowest temp?
Anyhow, this is by far the simplest and quickest app I've used for OBD2. Sets up both BT and car connectivity really quick, and no need to mess with various protocol settings. Some of that benefit come from being targeted to a specific car.
Bug: When charging at >16A single phase (in this case 30A), only one L-wire has mains voltage, but two chargers in the car are splitting the load. The app then shows "Charging Power 3.27 kW", likely by calculating 14.8A * 221V. Correct should be (14.9A+14.8A)*221V = 6.56 kW. That also aligns with the power to the battery, 15.56A * 392.70V = 6.11 kW (after AC/DC losses).
Feature request: Calculate and show charging loss in % or kW (in this case 6.11/6.54 - 1 = 6.6% or 6.56 kW- 6.11 kW = 0.45 kW)
@Orbit
point about icons taken ,
already thinking about better way...
formally:Current aging factor of the serial and parallel ohmic resistance as well as the parallel capacitance (1.5 =
increase of the current resistance by 50%)
checking yet if needed for detailed battery health evaluation...
a cell, hmm - let me see....
@Orbit
interesting and should be fixed next build, Danke!
let me consider it
let me consider it
- Hat sich bedankt: 49 Mal
- Danke erhalten: 29 Mal
@MaxD Thanks for providing the update of your app. It seems that v1.0 (5) is very slow. It takes more than 2 Minutes to transfer the initial data record via BT and also the update of the data records is extremly slow. With v1.0 (2) the transfer rates were significantly faster.
How can I access the internal log? I can't find the function in the app.
BMW i3 120 Ah mit Sportpaket (EZ 10/2020)
Energieverbrauch (inkl. Ladeverluste und Vorklimatisierung):
@GBrick
I believe I could improve pulling/refreshing speed and next version should be faster
about logs :
these are mostly dev. related: you can press 6th than 4th cell - app will popup email dialog with question to send by email logs.
you can cancel send and delete or place email to drafts.
Logs are easily readable, plain text.
the only option to share corner cases
about logs :
ISmart 2.0.1 Iphone IOS
von Elektronaut Ralf » So 24. Dez 2023, 09:10 » in MG - modellübergreifend - 0
- 693
Letzter Beitrag von Elektronaut Ralf
Android-App für OBD2 auslesen
Antworten: 1von ZeroEmil » Mi 23. Aug 2023, 17:32 » in Niro EV - Laden, Ladeequipment - 1
- 930
Letzter Beitrag von KippA
Mi 23. Aug 2023, 20:22
EVC04 mit der iOS App Drive Green Next verbinden
Antworten: 1von McGismo » Mi 19. Jul 2023, 07:33 » in Private Lade-Infrastruktur - 1
- 665
Letzter Beitrag von McGismo
Do 20. Jul 2023, 09:43
iSMART-App binden/koppeln (iOS)
Letzter Beitrag von m.a.v. « Mo 8. Jan 2024, 16:29Antworten: 4
Verfasst in Marvel R Electric - Allgemeine Themenvon dlareg37 » So 24. Dez 2023, 23:50 » in Marvel R Electric - Allgemeine Themen - 4
- 1108
Maingau ESL: Neu iOS App - Version 4.0.0
Letzter Beitrag von Fritzchen-66 « So 28. Jan 2024, 13:04Antworten: 28
Verfasst in Betreiber, Roaming und Abrechnungvon k_b » Di 23. Jan 2024, 20:09 » in Betreiber, Roaming und Abrechnung - 28
- 2031
