BMW EV - Neue OBD2 iOS/iPhone app für den i3
Re: BMW EV - Neue OBD2 iOS/iPhone app für den i3
- Hat sich bedankt: 49 Mal
- Danke erhalten: 29 Mal
Hi Max, many thanks for adding me in your test group.
Today I've installed your app on my IPhone 8 and it runs smoothly so far. The connection with my OBD adapter VGate 4.0 was established immediately after starting the app and the values are transmitted to the IPhone.
My experience with the app during my 13km ride was as follows.
Register EV:
At beginning (i3 on, Position P, heating off, driver seat heating on, Eco mode) At end (i3 on, Position P, heating off, Eco + mode) - Different capacities, cell temperatures and cell voltages are shown
=> Do you know why 3 different values for each item are available?
- What is the Cell Res. Factor and is it plausible that the first value is strongly deviating from the two others?
- Cell at SOC is deviating from the BMW Connected App and the Electrified App (71.99 to 73.19% app vs. 68.0% BMW app & Electrified app)
- Battery temperatures seems not to be updated while driving (7,99 °C at beginning and end with driving distance of 13km and 250m elevation meters)
- Battery power seems not to be plausible (-14.25 kW when the i3 is not running and heating is off; Electrified app is showing -0,27 kW)
Electrified App for comparison (i3 on, Position P, heating off, Eco + mode) Register General:
During driving (heating off, driver seat heating on, Eco mode, cruise control 82 km/h) - Pedal throttle is shown as "not available"
- Consumption: This is the average consumption (since starting the OBD connection), correct?
=> Value seems not to be correct, because vehicle's BC is showing a significantly higher value (132 Wh/km app vs. 169 Wh/km BC)
- Temperature effective inside is a nice feature
=> Do you know where the temperature sensor is located in the cabin?
- Speed is deviating from the vehicle speedometer (79.2 km/h app vs. 82 km/h speedometer)
=> Do you measure the speed with the GPS of the vehicle?
- Various ranges are very confusing:
=> What's the differences between the different MCV ranges?
=> Combi Ranges: Min. range seems to be the range in the Comfort mode, max. range seems to be the range in the Eco + mode
=> But max. range is lower as the range in the vehicle display in Eco + mode (233km app vs. 265km vehicle display)
Charging:
- not tested yet
REX:
- not available in my i3
Thanks again for this promising app and your great work. I look forward about the future progress of this project. I would be happy if you have the possibility to implement a logging function for the different values (over the running period of the app) giving the possibility to analyse e.g. the power consumption of the i3 subject to driving speed and temperature.
Register EV:
Charging:
- not tested yet
REX:
BMW i3 120 Ah mit Sportpaket (EZ 10/2020)
Energieverbrauch (inkl. Ladeverluste und Vorklimatisierung):
- Danke erhalten: 36 Mal
you are welcome and thank for detailed feedback.
these are in the form: avg/min/max
these are:
I feel that it is last-known-average one, from trip on-board computer, and over On-board computer route....testing yet....
good question and see it located as "button"
(try to put your finger on top to heat a bit and see how crazy air condition system will be)
it is Display speed
charging: different phases and AC/DC should be working but please check if possible
logging function - I am for it, just need to find good UI solution and how to dump the data collected,
may be over email to post-process on PC....not sure...
these are:
yet in observation mode values.Output of the current minimum measured resistance factor of all cells / Ausgabe des aktuellen minimalen
gemessenen Widerstandsfaktors aller Zellen
- button.png (29.92 KiB) 1521 mal betrachtet
it is Display speed
new version should be available soon.
v1.0 (2) changes:
- Fixed Dark mode
- new calculation for Odometer
- added "Charging finish time"
- internal start of WiFi adapter support implementation
Summary
- not only i3 but Cooper SE seems to be supported,
thanks,AQQU for checking.
v1.0 (2) changes:
- Fixed Dark mode
Summary
- Hat sich bedankt: 166 Mal
- Danke erhalten: 110 Mal
nice to hear and see so many progress. Due to security limitations of my business phone I need to wait for the official playstore version...
By the way: I very aprreciate the indication of all the digits regarding voltage values. Despite of the true values behind they show more precisely what the BMS sees and does in special situations.
@SU-N_i3 thanks for good words
JFYI, TestFlight is official Apple's test approach
- Danke erhalten: 83 Mal
If Cell Res Factor also are in format avg/min/max, the average is obviously wrong.MaxD hat geschrieben: ↑ >Do you know why 3 different values for each item are available?
these are:Output of the current minimum measured resistance factor of all cells / Ausgabe des aktuellen minimalen
In general, would min/avg[or median]/max make mose sense for all numbers? I guess this is just a test UI for testing data collection, and not how it will be shown in a more polished version?
that is correct, final UI design - yet to come...I guess this is just a test UI for testing data collection, and not how it will be shown in a more polished version?
Thanks for your feedback and your efforts to implement the logging function
I've tested update v1.0 (2) with following feedback:
- new calculation for Odometer => there is a discrepancy between Odometer in app and Odometer in vehicle display (app is showing ~2km more)
- added "Charging finish time" => working
Beginning of DC-charging process (at 20kW DC charging pole): End of DC-charging process:
- Hat sich bedankt: 806 Mal
- Danke erhalten: 661 Mal
I like the app electrified but I have an iPhone and do not want to buy android. So I would be happy to get your app for i3.
Would be cool if you could also support the new VW ID. If you plan to sell the app this is a faster growing market.
Ciao,
motoqtreiber
motoqtreiber
@GBrick thanks for info,
Odometer, still interesting...yet need to collect more details...
Charging power is important and actually was one of the triggers to make the app
heh, I've spotted "Charging finish" format issue , should be fixed at next build.
sneaky peaky spoiler:
with upcoming build - WiFi people should be happy
ISmart 2.0.1 Iphone IOS
von Elektronaut Ralf » So 24. Dez 2023, 09:10 » in MG - modellübergreifend - 0
- 699
Letzter Beitrag von Elektronaut Ralf
Android-App für OBD2 auslesen
Antworten: 1von ZeroEmil » Mi 23. Aug 2023, 17:32 » in Niro EV - Laden, Ladeequipment - 1
- 939
Letzter Beitrag von KippA
Mi 23. Aug 2023, 20:22
EVC04 mit der iOS App Drive Green Next verbinden
Antworten: 1von McGismo » Mi 19. Jul 2023, 07:33 » in Private Lade-Infrastruktur - 1
- 671
Letzter Beitrag von McGismo
Do 20. Jul 2023, 09:43
iSMART-App binden/koppeln (iOS)
Letzter Beitrag von m.a.v. « Mo 8. Jan 2024, 16:29Antworten: 4
Verfasst in Marvel R Electric - Allgemeine Themenvon dlareg37 » So 24. Dez 2023, 23:50 » in Marvel R Electric - Allgemeine Themen - 4
- 1117
Maingau ESL: Neu iOS App - Version 4.0.0
Letzter Beitrag von Fritzchen-66 « So 28. Jan 2024, 13:04Antworten: 28
Verfasst in Betreiber, Roaming und Abrechnungvon k_b » Di 23. Jan 2024, 20:09 » in Betreiber, Roaming und Abrechnung - 28
- 2036
