Are Finland winters too cold for Fluence battery?
- Danke erhalten: 7 Mal
Hi,
I have been thinking winter times with our Fluence. Here in northern Finland we get very low temps during winter. Can -34 celsius temperature break fluence battery pack? Is is safe to drive Fluence when battery is this cold(Does it even "GO" if battery is this cold)? Should I arrange battery heating system that activates if ambient temp goes below -10 celsius?
Tero
Tero
Re: Are Finland winters too cold for Fluence battery?
- Hat sich bedankt: 307 Mal
- Danke erhalten: 3105 Mal
Hello, I read in an article that cell temperatures below -25°C can be critical because the electrolyte can freeze and destroy the inner cell structures, so it should be ensured however that cell temperature does not fall below -25°C.
Ist das nicht gut ?
Ja ! Das ist nicht gut !
- Danke erhalten: 57 Mal
Hi,
I found this interesting Fluence battery spec sheet. It confirms what you two said before.
https://drive.google.com/file/d/1sRraWK ... sp=sharing
Tero
Tero
In Austria they are not equipped with battery-heating-funtion. I checked the cableharness and there is no possibility to reverse the electrical current in the peltier elements. There is also no additional heater equipped.
I can imagine that this functionality could be available for cars in northern countries (like Nissan Leaf GEN1).
If I would be in your shoes, I would phone "Reanult Service Center" from Finland. I am sure they can forward you to an specialist.
You can't see the heating from outside. Leafs use Heatmats that are attached to the cell blocks. They are operated directly by the 400V and the relay for turning them on is in the battery. However, I guess this relay is triggered via an external connector.
I removed these heatmats when I dismantled a battery from a norwegian leaf to put the cells in my fluence. I've thrown them away as I had no use for them.
It's the white elements on the cells:
Cheers
Andreas
Cheers
Andreas
- Hat sich bedankt: 1374 Mal
- Danke erhalten: 1509 Mal
Zurück zu „Fluence Z.E. - Batterie, Reichweite“
Maxus EV80 "Temperature too low, cannot charge"
Antworten: 1von peregrines » Mi 20. Mär 2024, 12:28 » in Serienfahrzeuge - 1
- 342
Letzter Beitrag von Multimedianer
Mi 10. Apr 2024, 12:16
85 kWh battery
von john0032 » Mi 24. Mai 2023, 09:17 » in ID.Buzz - Batterie, Reichweite - 0
- 1457
Letzter Beitrag von john0032
85 kWh battery
App: Battery protection limit
Antworten: 6von mcluki99 » Mi 12. Jul 2023, 22:12 » in Enyaq iV - Allgemeine Themen - 6
- 1427
Letzter Beitrag von Enyaqee
Sa 15. Jul 2023, 11:59
eUp Steuergerät Battery Charger defekt
Letzter Beitrag von MartinSi « Di 23. Apr 2024, 16:39Antworten: 11
Verfasst in e-up!, Citigoe iV, Mii electric - Allgemeine Themenvon mattes2570 » Di 21. Nov 2023, 18:56 » in e-up!, Citigoe iV, Mii electric - Allgemeine Themen - 11
- 1669
Battery pack heating system failure
Antworten: 2von k-EV-in » Do 30. Nov 2023, 20:06 » in MG4 Electric - Batterie, Reichweite - 2
- 748
Letzter Beitrag von k-EV-in
So 3. Dez 2023, 20:48
