Conversion of electric car
Alles über die Umrüstung zu einem Elektroauto
Hi everybody
I'm doing a research about the different regulamentations in europe regarding the conversion of combustion car into electric one, in this case, i would love to know what does a private persone should do to convert his car and have it approved and homologated to go on the public road in Germany(which test and laws does it have to pass).
Cheers
Carlo from Italy
Cheers
Carlo from Italy
Re: Conversion of electric car
dreamfish86
Ciao Carlo,
tanti saluti da Berlino ;o)
There are a couple of tests your electrified car has to pass. As a hint, watch this video on youtube, someone already made the job: http://www.youtube.com/watch?v=fnoH_QdXSyo
The main ones I remeber were:
All components must be properly fixed. The (huge) batterie pack should be in front of the driver so that in case of an impact it won't hit your back. There must not be any touchable high voltage components. The frequency inverter must be properly shielded (you have to pass an EMC-Test (electromagnetic compatibility)). You need at least a heater for the windscreen in case of invisibility due to moisture.
You need a vacuum pump making the brake booster working or you have to replace brake components, so that a normal person can force an emergence stop.
Finally you have to demontsrate this to the MOT (in germany the TÜV). That's all so far I know.
Ciao,
Peter
Ciao,
Peter
- Danke erhalten: 22 Mal
Here's a company that converts cars to electric at least they can support you doing so.
http://www.reevolt.de/produkte/okomobil ... -umrusten/
They also sell DIY conversion kits for VW Beetle, Fiat 500 and Ford Ka.
http://www.elektroauto-karabag.de/reevolt-shop/
Nissan Leaf Tekna 2013 - 2020, Seit 2020: Honda e
The TÜV is a must.
Mainly the TÜV checks the car for saftey.
Brakes, lights, ervry thing thight and no loose parts, no outstanding parts and so on.
Normally if one brings its car to the TÜV it costs about 90,-€ (varies locally), if the TÜV has no complains.
But as far as i know it exceeds this by far in most cases due to the TÜV has to register new parts in the papers.
Things get easier when you use parts that already have an approvment.
The electromagnetic tests are very expensive too.
In most cases you will be fine and done.
But you may run into some trouble:
In the cars licence papers it still will be approved as a car with a cumbustion engine.
Meaning you may get difficulties in case you want to have the tax exemption.
Tax and insurance fees will keep the same as approved in the papers.
In the case that the car is very old and never had a catalytic converter for exhaust cleaning, it may happen that you won't get the correct badge.
Thus you won't be allowed to drive in some environmental city zones.
No matter if the car now runs electric without any exhaust pipe, just due to the licence papers.
Relicensing the car and changing the papers may get very expensive.
But I am not sure about all this licensing process.
I highly recomend to ask someone with experience in converting cars.
Find some reports in this board here:
http://www.goingelectric.de/forum/umbau/
At that point after the mechanical transformation and the Electromagnetical compatibilty you should simply having it affirmed by the TUV? is it an exacting or costly test? much obliged for the appropriate responses!!
Wireless Android Auto & Apple Car Play ab 4. Quartal 2023
Antworten: 8von E-lefantastisch » Di 27. Jun 2023, 00:31 » in Hyundai - modellübergreifend - 8
- 3767
Di 27. Jun 2023, 14:18
Android auto und Apple Car play via WLAN im Mokka e
Antworten: 1von ratschi » Do 13. Jul 2023, 13:19 » in Mokka-e - Infotainment - 1
- 1645
Letzter Beitrag von Mokka e
Fr 21. Jul 2023, 17:18
Toyota C+Pod Kei-Car
von AQQU » Do 10. Aug 2023, 18:43 » in Toyota - modellübergreifend - 0
- 866
Letzter Beitrag von AQQU
Installation Wireless Android Car play
Antworten: 4von ThomasE. » Sa 19. Aug 2023, 12:52 » in i3 - Infotainment - 4
- 1175
Letzter Beitrag von MiJo
Mo 21. Aug 2023, 11:55
Apple Car Play mit Iphone 15 (USB-C)
Antworten: 41von Dave69 » Di 17. Okt 2023, 06:51 » in IONIQ 5 - Infotainment - 41
- 3019
Letzter Beitrag von Tim_Taylor
Sa 28. Okt 2023, 18:03
