Wo werden die Ladepreise hin gehen?
Re: Wo werden die Ladepreise hin gehen?
- Hat sich bedankt: 405 Mal
- Danke erhalten: 467 Mal
- Hat sich bedankt: 434 Mal
- Danke erhalten: 282 Mal
Komisch in Indien scheint der Standart CCS 2 sich auch durchzusetzen.
https://www.moneycontrol.com/news/techn ... 84881.htmlThe types of EV chargers that will be mandatory at each charging station make the latest EoI distinct from the earlier one. Successful bidders will have to install CCS 2 and CHAdeMO chargers in addition to Bharat Chargers.
A CCS 2 fast charger earmarked for the programme (minimum 50 kW) can fully charge the Tata Nexon EV or a Hyundai Kona EV, for instance, in about 60 mins. CCS 2 is the most favoured charger in India with every electric car being compatible with it.
The EOI also gives interested parties the option to set up a CHAdeMO (minimum 50 kW) charger. CHAdeMO chargers are favoured by Japanese car manufacturers and powers models such as the Nissan Leaf and Honda Fit. No electric car in India is compatible with CHAdeMO.
Es sollte auch kein Geheimnis sein, das Süd Korea auch auf CCS 1 setzt.
Achja, Auszug aus der englichen Wikipedia.
https://en.wikipedia.org/wiki/Combined_Charging_SystemThe Combined Charging System is primarily driven by European and North American car manufacturers. Type 1 and Combo 1 chargers are primarily found in North and Central America, Korea and Taiwan, while Type 2 and Combo 2 can be found in North and South America, Europe, South Africa, Arabia, India, Oceania and Australia. For DC charging the competing standard GB/T is used in China, while Japan uses CHAdeMO. In many remaining countries no standard is preferred yet, however, a recommendation from CharIN is to use Type 2 and Combo 2.[32] In the European Union according to Directive 2014/94/EU[33] all high-power DC charging points installed after November 18, 2017 shall be equipped for interoperability purposes at least with Combo 2 connectors. However, this does not prohibit the provision of other charging points using e.g. CHAdeMO or Tesla Superchargers.
- Hat sich bedankt: 494 Mal
- Danke erhalten: 391 Mal
Ich habe heute in Göttingen via Roaming an CCS wie folgt geladen:
Ladeleistung nicht berauschend für die Zoe aber normal bei der Menge und den Temperaturen. Bei anderen dürfte da durchaus mehr gehen.
Der Hammer ist aber der Preis: 35c DC. Daran sollten sich die anderen Mal ein Beispiel nehmen.
Leider ist das von mir super weit weg.
Edit: hab grad noch einmal nachgesehen. Ist "nur" ein alter 50kW CCS.
Renault Zoe Z.E. 50 r110 Life + CCS
seit Nov. 2020
seit Nov. 2020
- Hat sich bedankt: 430 Mal
- Danke erhalten: 722 Mal
Ist ja exakt der ehemalige Einheitspreis bei Maingau ESL und schön, dass es so ein Beispiel für DC noch gibt. Bei welchem Anbieter war das denn und mit welcher RFID/APP hast du die Säule aktiviert? Wird also wohl eher ein sehr regionales Angebot sein.
Model 3 SR+, MidnightSilver/black 06/2019, EAP 09/2020, 15,3 kWh/100 km (netto) @65 Tkm
Tesla-Referral: https://ts.la/erik66594 für SuC-Freikilometer u.a. Prämien; BeCharge Einladungscode: ZMLRUS9
Freigeschaltet mit der Shell-App (Tag ging nicht) und Anbieter ist EAM. Mit der Maingau-app/Karte wären es 48c. Bei EnBW ist er gar nicht gelistet.
Hab Grad noch Mal in die App geschaut und dort ist der ladepunkt mit 42c angegeben. Keine Ahnung warum die Abrechnung dann deutlich günstiger war.
Edit: war ja klar, dass ich blind bin. Die Angabe in der App nach dem Ladevoegänge ist ohne Steuer. Sind also 42c. Ist für DC aber trotzdem noch günstig.
seit Nov. 2020
seit Nov. 2020
Danke für die Korrektur. Ist etwas tückisch mit Shell ReCharge. Startgebühr kommt glaube ich auch noch dazu.
Die EAM ist ja gut aufgestellt/verbreitet. Ich habe selber einigemale in Kirchheim (A5/A7/A4) an einer EAM geladen (DC 100 kW). Den Pries finde ich für die Leistung auch erträglich.
Ich muss ehrlich sagen, ich bin von den Strompreisen in D ziemlich enttäuscht. Wir haben einen ZOE ohne CCS, daher lade ich nur AC. Mit ADAC 29Ct/kwh. Aktuell liegt unser Verbrauch bei ca. 18kWh/100km, mit Ladeverlusten gehen vielleicht 19-20kWh/100km drauf. D.h. 5,80EUR/100km.
Ich hatte vorher einen Citroen C-4 E-HDI, der brauchte 5.4L Diesel auf 100km. --> bei aktuellem Preis 6,48EUR/100km. Im Vergleich lohnt sich das E-Auto fahren daher meiner Meinung nach vor allem wegen der geringeren Wartungskosten.
Wenn ich überlege was wir für den ZOE trotz staatlicher Förderung hingeblättert haben und dafür nur Life und 40kWh Akku.
Das ist schon ein wenig enttäuschend. Würden wir noch CCS Laden...um Gottes Willen! Da frage ich mich, wie will man dann eine "Mobilitätswende" schaffen??
Wie ist dein Fahrprofil denn? Ich nehme an überwiegend Kurz- und Mittelstrecke. Je mehr man fährt und je höher der Autobahnanteil, desto mehr lohnt sich ein Diesel, weil die Wartungskosten dann immer weniger ins Gewicht fallen, zumal der Verbrauch bei E-Autos dann auch tendenziell hoch geht weil der Sweet Spot im Stadtverkehr liegt. Das ist auch ein großer Kritikpunkt meinerseits, dass man inzwischen fast überall 30-40ct pro kWh zahlt, wobei ich sogar glaube dass der Preis mittelfristig noch weiter steigen wird.
- Hat sich bedankt: 393 Mal
- Danke erhalten: 1335 Mal
@FreaXter und was zahlst du für die kWh zu Hause und wieviel % des Stroms lädst du daheim? Gibt ja Leute hier mit Fahrstromtarifen mit an die 21c/kWh.
CEE und geplante Ladezeiten, bekomme ich das irgendwie hin?
Antworten: 14von vorsommer » Sa 16. Dez 2023, 23:33 » in Ladeequipment - 14
- 1020
Letzter Beitrag von vorsommer
Mo 25. Dez 2023, 22:03
Stromnetz Hamburg Ladesäulen gehen zu Hamburg Energie, deswegen Karten nicht akzeptiert,z.B. Entega und Schneider Solar
Letzter Beitrag von jason_bourne « So 14. Apr 2024, 11:37Antworten: 25
Verfasst in Betreiber, Roaming und Abrechnungvon asci » Mi 13. Dez 2023, 16:41 » in Betreiber, Roaming und Abrechnung - 25
- 3911
Lade Led´s gehen nicht mehr
Letzter Beitrag von mhochhold « So 25. Feb 2024, 10:54Antworten: 12
Verfasst in MG4 Electric - Laden, Ladeequipmentvon jausek » Sa 16. Dez 2023, 17:06 » in MG4 Electric - Laden, Ladeequipment - 12
- 1652
Nun muss er gehen...
Letzter Beitrag von spoeh-man « Mo 29. Jan 2024, 09:54Antworten: 2
Verfasst in e-up!, Citigoe iV, Mii electric - Allgemeine Themenvon Vagant » So 28. Jan 2024, 08:30 » in e-up!, Citigoe iV, Mii electric - Allgemeine Themen - 2
- 697
Gehen bei euch die Twingos auch genau nach 2 Jahren kaputt ?
Letzter Beitrag von Singing-Bard « Mo 4. Mär 2024, 15:58Antworten: 7
Verfasst in Twingo Electric - Allgemeine Themenvon Torsten73 » Fr 1. Mär 2024, 18:15 » in Twingo Electric - Allgemeine Themen - 7
- 1066
