Engineers Menü
Re: Engineers Menü
- Hat sich bedankt: 39 Mal
- Danke erhalten: 179 Mal
You have to enable "wireless adb" in the engineering menu.
Next you have to find out the IP address of your car.
On your pc you have to install the Android SDK. Then open a command prompt an enter "adb connect CAR_IP", if that fails try "adb connect CAR_IP:5555".
Then you can use "adb pull /system/framework" to load all the framework files on your computer.
Thats how I did it. Another way could be to install a filemanager app on the car, connect a usb stick and copy the directory/files to the usb stick. Didn't try that myself but I think that should work too.
Re: Engineers Menü
- Hat sich bedankt: 85 Mal
- Danke erhalten: 214 Mal
Re: Engineers Menü
HI,g4rb4g3 hat geschrieben: ↑ Good news!
It's possible to communicate with the com.lge.ivi.server! I implemented some listeners and manged to get everything working... (forgot to pull the new lib from my car after it received a firmware update )
Attached is a screenshot from logcat showing the listener calls of my app.
Whats required to get it working?
First you have to pull the com.lge.ivi.jar & com.lge.ivi.odex library (better the whole (/system/framework folder) from the car.
Then you have to deodex it.
Next you have to convert it back to java (dex2jar is your friend).
Pull repo https://github.com/g4rb4g3/ivireceiver
Put the deodexed and converted com.lge.ivi.jar into ivireceiver\app\externallibs.
Open the project in Android Studio, compile it and let it run!
I've tried to deodex the com.lge.ivi.odex to obtain com.lge.ivi.jar, but once I put it on ivireceiver\app\externallibs
Android Studio gives me two errors in the import of:
Code: Alles auswählen
import com.lge.ivi.carinfo.CarInfoManager;
import com.lge.ivi.hvac.HvacManager;
import com.lge.ivi.greencar.GreenCarManager;
Re: Engineers Menü
Re: Engineers Menü
- Hat sich bedankt: 3691 Mal
- Danke erhalten: 2984 Mal
Der Intersection Split Screen ist auf jeden Fall sehr interessant. Nochmals kurz erwähnt für die vielen neuen Ioniq-Fahrer im Forum! Kennt bestimmt kaum jemand...
Man bekommt damit 100 Meter vor der Kreuzung eine super 3D-Übersicht über die Kreuzung, die viel besser ist als der herkömmliche automatische Zoom-Modus. Speziell, wenn mehrere Kreuzungen in kurzen Abständen sind oder komplexe Doppelabbiegungen anstehen.
Re: Engineers Menü
- Hat sich bedankt: 131 Mal
- Danke erhalten: 750 Mal
So guys i need your advice..
My ioniq 2019 ev still has the 2nd latest firmware where i have access to hidden menu . I have played around with it for some time, and i have also bircked my headunit once and also unbricked it with SIGTERM linus command. and put it back to life again, Anyways..
I also have my iphone jailbroken and installed the carbridge tweak, which opens up the carplay completly. no ristriction no limitation.
i can choose what app to display on my headunit. like, safari, chrome, messenger, whatsapp, gps,youtube, movieplayers etc etc.
it workss fantastic. So my question do i need the hidden menu anymore? i was thinking of resetting the headunit and install the latest software/firmware. just so the car is up to date, and also for the future, so my can can get updates.
is there anything that i MUST have the hidden menu for? what do you guys think.
thanx
thanx
Re: Engineers Menü
Ja, der besondere Intersection Screen-Modus bleibt dauerhaft (das heißt, er wird dann immer in der Nähe von Kreuzungen eingeblendet, ausgenommen auf Autobahnen).
Das andere Goody, die Zwangs-Auswahl zwischen Kurz- und Schnellmodus, verschwindet leider jedes Mal, wenn man den Ioniq ausschaltet.
Zurück zu „IONIQ - Infotainment“
MG4 Standard System Menü
Antworten: 1von fischi9 » Do 4. Mai 2023, 11:23 » in MG4 Electric - Allgemeine Themen - 1
- 594
Letzter Beitrag von thei
Do 4. Mai 2023, 18:17
neuer EV6 / neue Original-AHK-Elektrodose ist tot! /Anhänger-Menü im Infotainment-Display unauffindbar!
Antworten: 9von KiwiSix » So 14. Mai 2023, 11:57 » in EV6 - Allgemeine Themen - 9
- 1436
Letzter Beitrag von Jens.P
Mo 26. Jun 2023, 10:39
Anleitung neues Navi Menü
Antworten: 1von HJBr » Mo 15. Mai 2023, 14:33 » in IONIQ - Infotainment - 1
- 887
Letzter Beitrag von NICE TRY
Mo 15. Mai 2023, 16:07
EV Menü im Setup
von Kona2020HP » Sa 21. Okt 2023, 21:10 » in Kona - Infotainment - 0
- 845
Letzter Beitrag von Kona2020HP
EV Menü im Setup
Klima Menü sehr dominant :-I
Antworten: 17von Jens_14 » Di 5. Dez 2023, 21:38 » in ZS EV - Infotainment - 17
- 1261
Letzter Beitrag von schmiedel
Mi 20. Dez 2023, 11:06
