Simple EVSE Wallbox - Relais switching
Hi,
i have a question regarding the EVSE DIY wallbox. I setup everything, even with ESP8266, works fine in dry-run....means the LED changes blinking as soon as i start charging via button or in GUI.....what i was wondering, why the RELAIS does not switch in these moments.......my only guess is that the Wallbox-HW waits for a real car connected on the other end.....
Can that be the case (that relais really switches on/off only if the car is connected?)
Thanks Norbert
Thanks Norbert
Re: Simple EVSE Wallbox - Relais switching
- Hat sich bedankt: 273 Mal
- Danke erhalten: 741 Mal
Last question, does anybody know how the SimpleEVSE realizes that the car is connected.
PP is terminated with a resistor inside of the PLUG itself, so this line does not reach the Wallbox Controller.
L & N are outputs....the same i guess is valid for CP with the PWM signal....so these lines are not intended to get input from?
Cheers
Norbert
Cheers
Norbert
- Hat sich bedankt: 326 Mal
- Danke erhalten: 800 Mal
Unbekanntes Relais
Antworten: 2 - 2
- 299
Letzter Beitrag von Tarabass
Di 2. Apr 2024, 22:23
Unbekanntes Relais
EVSE WB ersetzen
Antworten: 15von Lullaby » Mo 29. Mai 2023, 15:10 » in Private Lade-Infrastruktur - 15
- 1022
Letzter Beitrag von Lullaby
Mi 21. Jun 2023, 16:00
EVSE WB ersetzen
EVSE-Wifi 1.x und SDM630 Inbetriebnahmeproblem
Antworten: 7von Ektus » Mi 7. Jun 2023, 09:17 » in Ladeequipment - 7
- 528
Letzter Beitrag von Ektus
So 11. Jun 2023, 13:43
EVSE WB begrenzt immer auf 12A
Antworten: 5von Bennysnaucum » Mi 18. Okt 2023, 16:37 » in Private Lade-Infrastruktur - 5
- 309
Letzter Beitrag von E-lmo
Do 19. Okt 2023, 14:17
evcc mit welcher Wallbox
Antworten: 28von Misse83 » Do 4. Mai 2023, 12:07 » in Private Lade-Infrastruktur - 28
- 5109
Letzter Beitrag von sasquuatch
Di 13. Feb 2024, 08:07
