Tableau Online for I3 Trip info, SoC etc.
Hi,
Gespielt mit der Verwendung von Connected drive-Daten für Trend-SoC, kWh / 100Km usw.
Abrufen von Connectedrive-Daten mit Python -> Google Tabellen -> Tableau Online.
Nach jeder Fahrt wird ein Eintrag speichert.
Schau hier Live-Beispiel an:
https://public.tableau.com/profile/poul ... ublish=yes
mfg
mfg
Re: Tableau Online for I3 Trip info, SoC etc.
Hi,
I can give my notes from my Python Code telling some about whats needed. The Python code itself is a few 100 lines. I do not know how i can upload it here but i will send you a PN with it.
# Poul W. Nielsen 2018-07-29
# beta version - usage on your own responsibility
# Get data from your BMW cacr on BMWConnected Data Portal and moves them to a Google Sheet. The Google sheet can be used by e.g. the free Tableau Online for fancy dashboards.
# It will only store and entry if there has been updated.
# If automation is needed you most set up a Tske Scheduled job on a windows computer.
# call with i3toGoogle <VIN> <USERNAME> <PASSWORD> <GOOGLESHEET>
# if <GOOGLESHEET> is set to NONE progrma will return values only on screen - Good for testing w.o. Google Sheets
# <VIN> is 16 char VIN
# USERNAME / PWD your BMW CD account
#prerequisites:
# create Google Sheets and call it BMWI3 Make headerlines in row 1 as:
# vin updateTime mileage ssoc_hv_percent soc socMax lastTripKm actDistWoCharging lasttripkWH00 lasttripRegenAvg
# (you most have a free google account)
# make pygsheet authorization json file, name it I3toGoogleSheet.json and place in same folder as program.
# see https://github.com/nithinmurali/pygsheets and - see about "Obtain OAuth2" under Basic Usage )
# If you want to use Tableau you must make a tableau Online Account. make a copy of My tableu Public and change datasource to your own google BMWI3 sheet
# Otherwise you can just read the data in the Google Sheet or any other visualization tool you prefer
#If programming/want to make changes to program etc. (only relevant if you're not running the compiled executable)
# Python 3.6.x
# pip3 install https://github.com/nithinmurali/pygshee ... taging.zip
# pip3 install pyinstaller
# pip3 install requests
# pip3 install wheel
# pip3 install --upgrade oauth2client
# pip3 install https://github.com/nithinmurali/pygshee ... master.zip
# python -m pip install --upgrade pip
#prerequisites:
# Python 3.6.x
Verbrauch laut Trip A. Anzeige
Letzter Beitrag von Levanto98 « Di 27. Jun 2023, 16:50Antworten: 3
Verfasst in 500 Elektro - Batterie, Reichweitevon bene61 » Mi 3. Mai 2023, 21:44 » in 500 Elektro - Batterie, Reichweite - 3
- 1754
Road-trip DE-FR-IT-AT-DE 2023
Antworten: 7von KomaKona » Sa 6. Mai 2023, 12:12 » in Öffentliche Lade-Infrastruktur - 7
- 764
Letzter Beitrag von Helfried
Mo 8. Mai 2023, 08:34
Sommerferien Sonne Suda Road Trip
Antworten: 6 - 6
- 1100
Letzter Beitrag von Tarabass
Mi 15. Nov 2023, 02:03
Bitte um schnelle Info/Hilfe
Antworten: 25von muenchenlaim » Mi 15. Nov 2023, 17:42 » in IONIQ 5 - Laden, Ladeequipment - 25
- 2434
Letzter Beitrag von Fab5ter
Mo 20. Nov 2023, 15:18
Zusätzliches Cockpit Info-Display
Letzter Beitrag von UPE « Mo 8. Apr 2024, 23:07Antworten: 5
Verfasst in e-up!, Citigoe iV, Mii electric - Allgemeine Themenvon Efficiency_King » So 7. Apr 2024, 20:31 » in e-up!, Citigoe iV, Mii electric - Allgemeine Themen - 5
- 681
