Re: PEB replacement and reprogramming
jinko
09.08.2018 23:30People stop posting about ECU!! Electric cars don't have a ECU but a EVC (electric vehicle controller)
Please if you don't know what a PEB is don't post about ECU!
Renault overall has 2 major issues! Aftermarket replacement parts, and fixing issues because most engineers not work at Renault anymore!
This is a major huge problem
Also reprogramming the PEB will solve a lot of issues! Really allot! 70% of the main errors is in there.. This is the heart of the car
And by reprogramming the peb it means reprogramming it what renault can't do! Vin replacement and start lock removal
goE
12.08.2018 07:01Re: PEB replacement and reprogramming
jinko
12.08.2018 12:07? This post is not about peb but charger replacement
17.08.2018 20:09jinko hat geschrieben:? This post is not about peb but charger replacement
@jinko I'm new here, is it posible to send a pn to you?
Where are you located?
Are your 6 Fluence running again?
Fluence, 2012er, "Laden nicht möglich" (orange), "Panne Elektromotor" (rot)
jinko
17.08.2018 20:46Hey,
I've just replied u,
Iam near border of Germany nearby Emmerich am rein,
And 2 of the fluences still error and 1 kangoo peb reprogramming need
Pamplonicadel13
18.08.2018 15:47I'm dismantling my Renault Zoe.
Motor failure, open winding in the rotor.
Does anyone know if it is necessary after winding rotor to make a swing?
Does anyone know how to do it?
Does anyone have the VISU 5.0 of Fluence, Zoe, Kangoo or know how to get it?
You can get help from the Clip through Pyren.
There is also a lot of help in Dialogys.
jinko
26.08.2018 10:22Second hand motor is not so expensive,
I buyed a complete engine incl wires for 2700,-
This is cheap
This incl charger, peb, elekrtic motor, orange wires and more
Pamplonicadel13
06.09.2018 09:38I found the fault in the rotor.
I have reassembled the motor, but now the rotor position sensor fails.
Has someone made a Reset to the PEB?
A reprogramming or only the Reset is necessary.
With the ddt4all in the position learning the motor begins to move but immediately puts the error.
Jinko after dismantling your engine returned to work?
As?
jinko
06.09.2018 10:17The engine always runs, the position sensor is only for fine tuning the engine.
So this means there is another error in the engine.
Does someone know how to bypass the Renault.net with can clip
Pamplonicadel13
07.09.2018 12:20With ddt4all I have managed to modify the angle, and start an engine learning.
I still have a Dtc problem that appears when I want to start moving the engine.
I think that the PEB power electronics, something may be broken.
