PEB replacement and reprogramming
Hi,
So far I know the PEB is one time programming, I heard it's possible to replace a used PEB with the broken one and somehow reprogramming it.
Can someone confirm? And maybe know how it works, I'll pay 1000 euro for someone who can do it
The PEB is normally not replaceable with a used one because of the Vin lock and should be removed out of the software.
New one cost 2200euro insane
Most people cannot fix their 2011-2014 ZE for normal prices
jinko
jinko
Zuletzt geändert von jinko am Fr 20. Jul 2018, 21:18, insgesamt 1-mal geändert.
Re: PEB replacement and reprogramming
I have the same problem in a Renault Zoe.
Engine failure plus PEB.
Budget out of warranty for two months € 7900.
I think there are 2 possibilities.
Remove the chip with hot air and insert it into the new one.
Or with the clip.
https://youtu.be/dekUhqfgRkE
If you get it, please post it.
You have information about safely removing the battery fuse.
Many Thanks
Sorry for my language, but I speak from Spain.
http://foroev.com/index.php?topic=10008.0
Ich habe das gleiche Problem in einem Renault Zoe.
Motorausfall plus PEB.
Budget außerhalb der Garantie für zwei Monate 7900 €.
Ich denke, es gibt 2 Möglichkeiten.
Entfernen Sie den Chip mit heißer Luft und legen Sie ihn in den neuen ein.
Oder das mit dem Clip.
Wenn Sie es bekommen, veröffentlichen Sie es bitte.
Sie haben Informationen zum sicheren Entfernen der Batteriesicherung.
Vielen Dank
Sorry für meine Sprache, aber ich spreche aus Spanien.
Renolink posible solution?
https://youtu.be/9p1lLMBlk6E
Or with the clip.
Many Thanks
Vielen Dank
Check this ad in Spain
https://www.milanuncios.com/renault-de- ... 284608.htm
Possible it is but we do not know how.
With CAN CLIP I think it is not possible without access to the Renault network.
Other possibilities:
RENOLINK 1.52
Renault clip tool 2.6
RenaultCOM
Renault reprog v126
LINK
https://carprotool.com/forum/forum/cpt/ ... 985109511r
http://webcache.googleusercontent.com/s ... clnk&gl=es
http://smok.com.pl/index.php?id_product ... &id_lang=2
https://etacsdecoder.com/forum/index.php
https://cartechnology.co.uk/
https://www.autorepairmanuals.ws/arm/
https://www.youtube.com/watch?v=eYdNNvYuH9Q
https://premium-tools24.com/RET_Keys_for_Clio4
http://www.digital-kaos.co.uk/forums/fo ... dio-SatNav
https://es.slideshare.net/simobouala/re ... cedure-eng
RENOLINK 1.52
RenaultCOM
Renault reprog v126
LINK
Hi guys,
To make the topic more clear,
1) it's impossible with Can Clip even with Renault online USB stick (I whas at Renault)
2) the car has no ECU, but instead it's EVC all is different then fuel car..
3) the PEB is the DC DC converter between the electric engine and charger.
I tried to dismantle the PEB the only thing I can replace whas one pcb board with more chips on it.. I putted this pcb from the old peb and mounted in the new pcb.
I need to reset the canbus I will let u know.
But it should be via other way.. I think the pcb replacement still has no luck
Zurück zu „Fluence Z.E. - Antrieb, Elektromotor“
R240 Ladestart löst FI aus - PEB BCB tauschen - Marderschaden?
Antworten: 8von MartinElektrisch » So 18. Jun 2023, 13:03 » in ZOE - Laden, Ladeequipment - 8
- 969
Letzter Beitrag von Rhyme
Di 20. Jun 2023, 18:08
[S] Renault "PEB 420V" Inverter für Kangoo/Fluence/Zoe
von Admini » Mo 29. Apr 2024, 11:32 » in Marktplatz - 0
- 102
Letzter Beitrag von Admini
Renault Zoe R90 charging and moving problem
von diesel89434 » So 24. Sep 2023, 21:10 » in ZOE - Garantie, Probleme - 0
- 682
Letzter Beitrag von diesel89434
EX30 , EX30 Cross Country and EX90 at eCarExpo
von eSaab » Di 21. Nov 2023, 20:22 » in EX30 - Allgemeine Themen - 0
- 862
Letzter Beitrag von eSaab
Charging in Deutschland and Osterreich
Antworten: 4von marx123 » Do 7. Dez 2023, 18:49 » in Öffentliche Lade-Infrastruktur - 4
- 377
Letzter Beitrag von marx123
Do 7. Dez 2023, 20:49
