Setting up Torque to show BMS data
Re: Setting up Torque to show BMS data
I recommend the Konnwei KW902 for use with Torque Pro.Olaffit hat geschrieben:...Which OBD adapter do you use in the IONIQ? I noticed that the space is very limited. Were you able to close the fuse cover?
I wonder if one of these adapter cables would help to place the obd adapter a little a side and close the cover.
Available for 16 USD here https://www.amazon.com/KW902-ELM327-Blu ... 45-6635569
I have had one of these for a year. I use it connecting to an android phone over bluetooth.
I added an OBD extension wire with a switch. Tonsiki OBD 2 Cord 16 pin M/F Male to Female Right Angle Diagnostic Extension Cable with Power Switch to avoid battery drain
I pushed the OBD connector back out of its clip to allow room for the plastic cover to be closed. The OBD extension wire is threaded under the steering column so that the switch and adapter can sit under the navigation by the accessory ports.
The free app ELM327 Identifier is useful to test that your adapter will work with Torque. Many do not.
See recommended obd2 adapter?
The codes for using Torque Pro with an OBD2 adapter to display battery info are here - https://github.com/JejuSoul/OBD-PIDs-for-HKMC-EVs
There is a new section on github for the Hyundai Ioniq Hybrid. It also uses the same BMS as yours.
Data provided by Rene Scheffers - Anybody try to use Torque Pro?
The graphic below shows test data using the Kia Soul EV PID codes.
Battery Data above verified using an image from manual. 64 * 3.8V = 243.2V
Cool @JejuSoul.
Unfortunalely (for me fortunately) I have the electric version of the IONIQ and I use a Konnwei KW902 adapter like this one: http://e3.at/obd2
Do you know why I can't get the OBD Speed? It doesn't show any data of the car's speed.
I know that I can use GPS speed (that works), but I'd like to get OBD speed as well.
And is it possible to get the inside/outside temperatures in Torque pro?
There is one display to show ambient temp (or something like similar) but it doesn't work either...
Do I need another (better) OBD2 adapter which supports even more protocols?
Quantum Leap — Schwarzer Hyundai IONIQ Electric (Sangl #95, Abholung 2. Juni 2017) — YouTube Kanal mit IONIQ Videos
Yes. I don't have a PID for Real Vehicle Speed on the Ioniq.boeselhack hat geschrieben:...Do you know why I can't get the OBD Speed? It doesn't show any data of the car's speed.
...[/attachment]
All the Hyundai / Kia EVs use the same BMS (Battery Management System) , but the VMCU (Motor Control Unit) is different.
No one has decoded the VCMU for the Ioniq yet.
Oh, okay. Thank you! Good work btw!
Greetings from Austria
Markus
Markus
Thanks Markus.
When did you buy your Konnwei KW902 . You have the same brand as me. It is the one I recommend, but there have been problems with this recently in America. - Warning: Defective Konnwei KW-902 on the market
In the last month I know people in Korea, France and Holland have bought this brand without problem.
Thanks Markus.
- Hat sich bedankt: 227 Mal
- Danke erhalten: 506 Mal
Is there anything we can do to help decoding the VMCU?JejuSoul hat geschrieben: All the Hyundai / Kia EVs use the same BMS (Battery Management System) , but the VMCU (Motor Control Unit) is different.
I don't have my Ioniq now but I just started to write an app for remote accessing the vehicle data.
I'm very interested in getting the VMCU PIDs.
Gesendet von meinem Nexus 5 mit Tapatalk
I don't know! Will have to test it, I don't have the equipement atm...JejuSoul hat geschrieben:-
Thanks Markus.
- Hat sich bedankt: 407 Mal
- Danke erhalten: 791 Mal
One question:
Is the PID for the OBD Speed correct? In my Torque only the GPS Speed works, OBD Speed stays at Zero.
- Hat sich bedankt: 1890 Mal
- Danke erhalten: 1329 Mal
Ich glaube die Geschwindigkeit war in den PIDs gar nicht dabei. Ich denke das sind die PIDs von der Torque Verbrenner Grundausstattung wo auch noch andere typische Verbrennerwerte mit dabei sind.
Man bräuchte noch zusätzliche Ioniq PIDs, da gäbe es noch jede Menge interessante SensorMesswerte. Bei VW hat man mit der VDCS Software Zugriff auf fast alle Sensoren.
Zuletzt geändert von gekfsns am Di 18. Jul 2017, 19:55, insgesamt 1-mal geändert.
Problem A/C setting
Antworten: 2von JeroenS » Mi 1. Nov 2023, 10:11 » in Marvel R Electric - Infotainment - 2
- 758
Letzter Beitrag von JeroenS
Do 2. Nov 2023, 10:57
Problem A/C setting
Tesla Light Show World Record
Antworten: 6von Tommy73_ » Mi 27. Dez 2023, 21:16 » in Elektroauto Videos - 6
- 815
Letzter Beitrag von Tommy73_
Di 2. Jan 2024, 20:28
Torque Pro zum OBD2 Daten auslesen
Antworten: 6von s.krey@gmx.net » Mo 10. Jul 2023, 18:02 » in IONIQ 6 - Allgemeine Themen - 6
- 1205
Letzter Beitrag von sieg
Mi 12. Jul 2023, 15:15
Update BMS Marvel
Letzter Beitrag von Tom77 « Di 1. Aug 2023, 15:43
Verfasst in Marvel R Electric - Batterie, Reichweitevon Tom77 » Di 1. Aug 2023, 15:43 » in Marvel R Electric - Batterie, Reichweite - 0
- 1159
Update BMS Marvel
Twingo der Vogelkäfig + BMS / "Akku lädt sich selbst mit Magie"
Letzter Beitrag von efachkraft « Fr 29. Mär 2024, 13:02Antworten: 19
Verfasst in Twingo Electric - Allgemeine Themenvon Dancer123 » Di 21. Nov 2023, 09:12 » in Twingo Electric - Allgemeine Themen - 19
- 2089
