Firmware-Versionen
Re: Firmware-Versionen
- Hat sich bedankt: 131 Mal
- Danke erhalten: 750 Mal
OK, thanks a lot for the very detailed feedback!SonicSpinner hat geschrieben: ↑ IF you want to update your headunit to the latest fw, you have to completly uninstall all app through the service menu - > app installation.
DElete data, then delete cache, then delete app.
After all app is deleted, you can Factory reset the android part also in the service menu. Once this is done you can also factory the head unit it self through the settings menu in the head unit.
My situation is that i ONLY need/use IoniqInfo which is rather small and i guess not the biggest trouble maker, but still i would remove it completely (+data/cache) before i visit my hyundai partner for the next update. Is it still with only this single APP required to go through this procedure?
Why is it required to FACTORY reset the android part if already all apps are removed - and data space is available again?
btw, factory reset needs to be done twice? directly in service menu (android) + in the "normal" HU menu somewhere in settings i guess?
KR Norbert
- Hat sich bedankt: 39 Mal
- Danke erhalten: 179 Mal
- Hat sich bedankt: 45 Mal
- Danke erhalten: 28 Mal
do you know that you will not be able to install any apps after the update?njordan hat geschrieben: ↑ My situation is that i ONLY need/use IoniqInfo which is rather small and i guess not the biggest trouble maker, but still i would remove it completely (+data/cache) before i visit my hyundai partner for the next update. Is it still with only this single APP required to go through this procedure?
Sure I know - very sad but it was clear that Hyundai was going to secure their cars after (stupidly) putting Howto's via Youtube so they get to know about this too soon.
But still i hope (even if its stupid as well) that there will be coming an update that is worth the effort of updating....like showing the charging power in the displays.
Cheers
not till now!
- Hat sich bedankt: 43 Mal
- Danke erhalten: 207 Mal
- Hat sich bedankt: 55 Mal
- Danke erhalten: 70 Mal
Verstehe das Problem nicht, so lange wir uns auf Deutsch und Englisch beschränken. Notfalls kannst Du Dir die Texte ja von einem Online-Übersetzer übersetzen lassen, z.B. https://www.deepl.com/translator
Ioniq FL Premium in Fiery Red - unter Strom seit dem 19.03.2020
- Hat sich bedankt: 293 Mal
- Danke erhalten: 284 Mal
- Hat sich bedankt: 86 Mal
- Danke erhalten: 48 Mal
Hallo, da es sich hier um ein deutsches Forum handelt, sollte auch deutsch geschrieben werden, die Verfasser können schließlich auch einen Online-Übersetzer verwenden..... Die nur englisch sprechenden Benutzer werden ja wahrscheinlich hauptsächlich in englischen Foren unterwegs sein.
Kona Elektro SX2 65 kWh Premium
Zurück zu „IONIQ - Infotainment“
Wallbe 2.0 ECOs streikt nach PH Firmware Update
Antworten: 2von wildcard512 » Di 2. Mai 2023, 23:18 » in Ladeequipment - 2
- 526
Letzter Beitrag von helmut.neukirchen
Mo 8. Mai 2023, 00:04
Firmware Update bei ABL eMH1 mit Federklemmen
Antworten: 5von steven11 » Do 6. Jul 2023, 09:35 » in Private Lade-Infrastruktur - 5
- 942
Letzter Beitrag von steven11
Do 6. Jul 2023, 14:20
Firmware Update für mein Firmenfahrzeug
Antworten: 6von Abims » Di 1. Aug 2023, 01:32 » in IONIQ 5 - Allgemeine Themen - 6
- 969
Letzter Beitrag von Abims
Mi 2. Aug 2023, 22:34
NRGkick Firmware updaten
Antworten: 12von Catter » Sa 28. Okt 2023, 11:34 » in Private Lade-Infrastruktur - 12
- 2097
Letzter Beitrag von Stelze
Mo 8. Jan 2024, 05:45
Elli Wallbox online, aber kein Firmware Update
von DonPromillo » Do 18. Apr 2024, 21:07 » in Private Lade-Infrastruktur - 0
- 134
Letzter Beitrag von DonPromillo
