Ladeleistung Hyundai IONIQ
Re: Ladeleistung Hyundai IONIQ
- Hat sich bedankt: 1890 Mal
- Danke erhalten: 1329 Mal
Yes, that would be great.Roland81 hat geschrieben:...If you are interested in some real data please just contact me. I'm glad to record and share...
First a hope. Do you live near a 100kW charger. Can you record data from a charge.
Example -DigitalDrucker - 30.08.2016: Erneute Ladung bei KIA FFM
KIA Soul EV • Ladeleistungskurve 100 kW SIGNET-Ladesäule KIA Deutschland Zentrale Frankfurt am Main
Second. Could you post data from a longer session at a Chademo. So we can compare with the Kia Soul EV.
Image by SoulEV2016 on the mykiasoulev forum here - Some graphics about Chademo Charge Station.
The codes for using Torque Pro with an OBD2 adapter to display battery info are here - https://github.com/JejuSoul/OBD-PIDs-for-HKMC-EVs
- Hat sich bedankt: 64 Mal
- Danke erhalten: 26 Mal
Hi JejuSoul,
just found a 150kW Charger just around 120km away in Switzerland.
I asked the Swiss members of this forum to confirm that it´s working.
Depending on reply I can do a test charge maybe end of week.
A longer charge at 50kW is no problem.
Just for info..in Germany the Ioniq is not equiped with Chademo but CCS.
Roland
Roland
Ioni(q)siert seit 18.11.2016 07/2018 29 x 320Wp QCells Duo - Kostal Piko BA - BYD 7,7 kWh
This one. 150kW at the Gotthard pass --- http://www.gofastcharge.com/de/Roland81 hat geschrieben:...just found a 150kW Charger just around 120km away in Switzerland.
Here in South Korea the massive majority of EVs sold are Chademo. Ray EV, Soul EV, Ioniq EV and Nissan Leaf. But the government intends to begin a switch to the American CCS combo 1 standard. see - http://www.zdnet.co.kr/news/news_view.a ... 1228103054
CCS 1 looks like this -
Presumably you have CCS 2 on your Ioniq EV in Germany
- Hat sich bedankt: 37 Mal
- Danke erhalten: 31 Mal
- Hat sich bedankt: 21 Mal
- Danke erhalten: 115 Mal
@trischmiw: Danke für die Ladekurve! Hast du auch geschaut, wie viele kwh über den Zähler geflossen sind, und wie viele davon in der Batterie angekommen? Könntest du das gleich auch mit dem Schuko-Ladekabel machen?trischmiw hat geschrieben:Für die, die mal eine Ladekurve ansehen wollen. Der Ioniq lädt mit dem Bordlader sehr schön gleichmäßig. Es wird auch am Ladeende wohl kaum gebalanced, liegt aber vermutlich auch an der krachneuen Batterie. Die blaue Kurve ist der Ioniq, auch wenn da noch Zoe steht
Hintergrund: Ich wohne zur Miete und kann deshalb nur per Schuko laden. Deshalb interessieren mich insbesondere die Ladeverluste bei Schuko Ladung. Hatte mal eine Woche eine Zoe zum testen und war erschüttert über die hohen Verluste, deshalb die Frage, wie es beim Ioniq aussieht.
Dankeschön!!
e-NV 200 Camper und Ioniq FL
- Danke erhalten: 20 Mal
Ich kann dir noch sagen, dass es 22,97 Kwh waren, die ich am Zähler geladen habe. Aber leider weiß ich nicht, wieviel Verbrauch das Auto angezeigt hatte, insofern nutzt das nichts. Es war am Abend, als ich ihn abholen war und mein erster Ladevorgang zuhause. Da hab ich noch nicht daran gedacht, den Verbrauch im Auto abzulesen.
Und da es bislang auch mein letzter Ladevorgang zuhause war, konnte ich es auch noch nicht wieder beobachten.
Beim Schuko Laden kann ich dir leider nicht helfen, die Ladekurve samt Messung kann ich nur an meiner Box machen und da kann ich kein Schuko daran anschließen. Vielleicht findet sich ja sonst jemand, der das mal messen kann.
Willi
2020er VW E-Up seit 3/2020
JejuSoul:
Yes, thats correct we have the CCS2.
The charger I want to use is this one:
http://www.goingelectric.de/stromtankst ... -63/18124/
It is from the same manufacturer as the charger you linked in your post.
I contacted the manufacturer today.
They will do some rewiring of the charger on the 14th January and the charger will be back in operation on the 16th with then 80kW on the CCS as long as nobody is charging at the Chademo at the same time.
They offered to add some additional logging during my charging to have more information.
If the test will show that the Ioniq can charge with more then 80kW they offered me to visit them at their site where they have the possibility to charge with 100kW for a short time.
Small Update:
Charging at a 50kW ABB Charger:
Starting at 20% SOC BMS
Temperature -1°C, driven ~50km before. (heating etc. turned off during charging)
Second graph is showing the difference between SOC BMS - SOC Display at different SOC. From my point of view it seems that the "buffer" of the battery is only at the upper end.
IONIQ 6 AC-Ladeleistung nur 8,5kW
Antworten: 8von anbe » So 16. Jul 2023, 15:10 » in IONIQ 6 - Laden, Ladeequipment - 8
- 1494
Letzter Beitrag von anbe
Fr 21. Jul 2023, 12:43
Erfahrungen Kombination Go-e Gemini 11kw und Hyundai Ioniq 6
Antworten: 10von BoxSon » So 9. Jul 2023, 22:53 » in IONIQ 6 - Laden, Ladeequipment - 10
- 1878
Mo 2. Okt 2023, 11:22
2023 Hyundai Ioniq 6 Doesn't Impress In Moose Test With Nexen Tires
Antworten: 6von hagu » Di 29. Aug 2023, 17:16 » in IONIQ 6 - Allgemeine Themen - 6
- 646
Mi 30. Aug 2023, 17:55
Ioniq 6 Verbesserungswünsche an das Christkind bzw. Hyundai – langer Text!
Antworten: 24von hagu » Mi 18. Okt 2023, 12:10 » in IONIQ 6 - Allgemeine Themen - 24
- 2613
Letzter Beitrag von Anthropo
Mo 6. Nov 2023, 08:18
Live Video eines Hyundai Ioniq Autodiebstahls - Keyless Decoder
Antworten: 3von Singing-Bard » Fr 3. Nov 2023, 23:39 » in Hyundai - modellübergreifend - 3
- 1237
Letzter Beitrag von LOUDisOUT
So 5. Nov 2023, 07:58
