Nachbesserung Schnelllader BMW Service Action – B61 31 14 KL
- HyperMiler
In den USA gab / gibt es offensichtlich eine Nachbesserungsaktion der auf < 5 kW gedrosselten eigentlich 7,4 kW Schnellader.
Ist die Drosselung und Nachbesserung hier auch erfolgt?
http://insideevs.com/bmw-to-finally-rep ... ging-rate/
BMW i3
With This Cord Plugged In, The BMW i3 Will Now Charge At Its Promised Rate After Onboard Charger Replacement
When the BMW i3 launched in the U.S., BMW promised a Level 2 charging rate of over 7.0 kW.
Promised Versus Delivered
While the promise was over 7.0 kW (7.4 kW to be precise), several U.S. i3s began to blow what’s known as the KLE (onboard charger). BMW’s response was to push through an update that effectively limited charging to between 4 and 5.5 kW. In essence, the i3 was no longer the electric car that BMW promised, at least for those who got the update. However, some i3 owners squeezed through the holes, managing to avoid the update as long as possible. Several of those owners later experienced onboard charger failure. There were even some i3 owners who demanded and received a buyback from BMW on the grounds that the car did not match the charging specifications released by BMW.
Resolution
BMW isn’t being open is regards to the actual issue. With years of testing electric cars under its belt, you’d think that the German automaker would’ve equipped the i3 with a robust onboard charger. However, the same issues that plagued BMW ActiveE owners continue to be problematic for new i3 buyers.
Fortunately, BMW finally claims to have fix for a problem that’s been irking i3 owners for a long time now.
BMW has issued a service campaign to replace the onboard chargers in affected vehicles. This, along with a software update, should restore the i3’s charging rate back to 7.0 kW or higher.
Beta Testing
Some i3 owners have been beta testing this replacement onboard charger for a few weeks now. To the best of our knowledge, no problems have been reported with this new unit.
What To Do
If you own an i3 in the U.S., contact your dealer to see if your vehicle is among the affected cars. Onboard chargers will be replaced free of charge. A software update will be needed to restore maximum Level 2 charging.
For reference, here’s the official service action. Your dealer should be made aware of this:
Service Action – B61 31 14 KLE Update
Audi Etron 55 2019
BMW i3 120 Ah
BMW PHEV 2016
LEAF I pearlwhite bis 9/16
BMW i3 120 Ah
BMW PHEV 2016
Re: Nachbesserung Schnelllader BMW Service Action – B61 31 1
- Hat sich bedankt: 16 Mal
- Danke erhalten: 10 Mal
Klar auch hier erfolgt und etliche Zeit diskutiert - ich war auch einer derjenigen, bei denen die KLE abgeraucht ist. Eine Drosselung hatte ich aber nicht (bekam eine neue KLE) - andere schon.
- HyperMiler
Radioempfang 500e Action
Antworten: 1von oliver9971 » Fr 18. Aug 2023, 11:38 » in 500 Elektro - Allgemeine Themen - 1
- 457
Letzter Beitrag von BOP
Fr 18. Aug 2023, 12:05
Fiat 500e Action "Miete" - Angebot Übernahme?
Antworten: 2von binderth » Fr 1. Sep 2023, 09:30 » in 500 Elektro - Allgemeine Themen - 2
- 624
Letzter Beitrag von binderth
Sa 2. Sep 2023, 09:32
Fiat 500e Action
Antworten: 2von TayTay » Mo 16. Okt 2023, 21:49 » in 500 Elektro - Allgemeine Themen - 2
- 741
Letzter Beitrag von Strompilot
Mi 18. Okt 2023, 18:31
Fiat 500e Action
Fiat 500 Action SOH
Letzter Beitrag von spidi360 « Fr 22. Dez 2023, 13:22Antworten: 7
Verfasst in 500 Elektro - Batterie, Reichweitevon spidi360 » Fr 17. Nov 2023, 18:18 » in 500 Elektro - Batterie, Reichweite - 7
- 1440
Fiat 500 Action SOH
Schnelllader Kärnten Raum Villach
Antworten: 8von klaus1 » Mi 7. Jun 2023, 16:44 » in Betreiber, Roaming und Abrechnung - 8
- 716
Letzter Beitrag von TransA
Do 27. Jul 2023, 14:15
