Hacking into Zoe's CANbus
Zubehör für den Renault ZOE
Re: Hacking into Zoe's CANbus
- Hat sich bedankt: 30 Mal
- Danke erhalten: 40 Mal
@Zoelibat: I don't know what the status is of the iOS version. The French gentleman developing it is doing this totally separately. I simply cannot say anything about it. Not because I don't want to, but because I honestly don't know.
There will be a new version indeed as soon as the diagnostics stuff stabilizes. For those into these things I can promise that while it will look very very "technical" and not "pretty screens" there will be a TRUCKLOAD of new information available.
@Jack76: way cool and thank you for that link! The things we specifically did for the 90 versions have more to do with charging planning. I am glad to see results are pretty neat already.
Jeroen - ZOE Q210 Nov 2013 - PV powered - CanZE co-developer http://canze.fisch.lu
- Danke erhalten: 446 Mal
but you can always message me when you are ready and i will translate it for youjmeijer hat geschrieben:Yes, all the code is already in for the '90 models. I have to say though for now we've only changed the various battery parameters, but we assume the computers are the same and use the same messages etc. As we have no 90 model to play with, that is a bit of a gamble.
Personally, I think the 90 will do great, though there will be price pressure soon.
Thank you so much for your offer for translation. To be bluntly frank, we have not put much effort in separating out language strings. I will put that into an issue request. Only after we have fixed that we can start thinking about a multi language version. It might be quite a while, there is still SO much to do and there are only two people developing in spare time.......
Right now, I am just wrapping up Diagnostics ans DTC displays, which was LONG overdue.
Thank you!
In the meantime, here is a teaser http://canze.fisch.lu/dtcs-unraveled-teaser-alert/ (DTC decoding)
- Hat sich bedankt: 95 Mal
- Danke erhalten: 80 Mal
Hallo!
Ich möchte mir ein preiswertes Android Pad zulegen. Gibt es schon eine Zusammenstellung, welche enthält mit welcher Android Version (Minimum) und welchem Gerät CanZ.E. stabil läuft.
Ich dachte, das bei canze.fisch.lu mal etwas gesehen hatte. Ich kann es aber nicht mehr finden.
Jürgen
Jürgen
Smart Fortwo Electric Drive 06/17
Kia EV6 reserviert … probegesessen … probegefahren… bestellt 05.11.21...geliefert 27.09.2022
EV6 RWD 77,4kWh Interstellar / Charcoal WP P1-4 LW 48/22
Google Tabelle Bestellungen...
- Danke erhalten: 10 Mal
Question about those DTC codes, I'm following up this Message:jmeijer hat geschrieben:Thank you!
http://www.goingelectric.de/forum/renau ... ml#p445289
In short after problems with his 12V-Battery and finding himself taking his Zoe to his Dealer, he noted that the Renault-Engineers found "PEB - Error: DTC0852F1"
Do you have some clue about the descriptive meaning of this error code?
many thanks
Jack
0 => Standardized error drivetrain (usually displayed as P0)
852 hex = 2130 decimal => Device= DCDC driver (the 12 volt charger)
F1 hex => Test = Safety Case 1
I have no idea what "Safety Case 1" means, but yes, it is saying the 12 volt charger is kaputt. But to be honest, if it is a 2013 ZOE, first thing I would do is change the battery.
Hope this helps
Hope this helps
http://canze.fisch.lu/android/Bullit hat geschrieben:Hallo!
Jürgen
Horribly outdated. Anything running Android 4 or higher and having a Bluetooth interface should work. For use in the car you might want to have one with a light sensor so it dims itself when driving at night. You do want one with play store installed though. I don't think many are sold nowadays without, just make sure. If it runs gmail and maps, it usually does.
- Hat sich bedankt: 44 Mal
- Danke erhalten: 189 Mal
Hi jmeijer,jmeijer hat geschrieben:0 => Standardized error drivetrain (usually displayed as P0)
Hope this helps
this is the original printed Version of the error-message.
There are some additional Information, perhaps they are useful.
My battery is 1 year as i wrote here http://www.goingelectric.de/forum/renau ... ml#p445438
Many Thanks
Werner
ZOE R240 10/2015 - Q90 ZE40 (D) 11/2017 - R135 ZE50 ab 07/2020 + TESLA M3P ab 08/2023
Alle sagten, das geht nicht! - Da kam einer, der wusste das nicht und hat´s einfach gemacht ... RENAULT schafft das sogar bei Fehlern ...
Brilliant, thank you for the screen print. For instance, 7034 means:
"Voltage demand for the DCDC converter from the EVC".
I didn't know a DTC relates back to additional measurements. Of course it makes total sense, but unfortunately, I have not seen any reference to those PR numbers.
- 2744
Letzter Beitrag von zoe-gerer
Di 27. Jun 2023, 15:02
- 6771
Letzter Beitrag von quasimodo
Fr 15. Dez 2023, 17:10
Reichweite ZOE ZE40
- 2957
Letzter Beitrag von E-Fan66
So 11. Jun 2023, 21:52
Reichweite ZOE ZE40
- 730
Letzter Beitrag von tbline67
Di 13. Jun 2023, 11:08
- 551
Fr 16. Jun 2023, 07:28
