Hacking into Zoe's CANbus
Zubehör für den Renault ZOE
Re: Hacking into Zoe's CANbus
- Hat sich bedankt: 498 Mal
- Danke erhalten: 357 Mal
New Version on Google PlayStore?
2014 - 2019: Renault Zoe Q210
2015 - 2020: Kangoo Maxi ZE
2019 - : Tesla Modell ≡ LR
https://ts.la/bernd30762
- Hat sich bedankt: 54 Mal
- Danke erhalten: 85 Mal
- Hat sich bedankt: 30 Mal
- Danke erhalten: 40 Mal
Communicating with other developers @most. If you want to know about "bleeding edge", it is here http://canze.fisch.lu/downloads/ Please not that the weekly builds are not longer made. They follow the releases. I will update that information.
Jeroen - ZOE Q210 Nov 2013 - PV powered - CanZE co-developer http://canze.fisch.lu
Hi Jeroen, okay understood! WHat do you think how long until this appears in the Google App Store?
Also great to see that you delvelop an iOS version as well. I vote for testing . Actually, I just bought a Google tablet to use CanZE. Crazy, eh? But I am more familiar with iOS (editing this on an iPad) and would love to use an iPad in my Zoe.
Thanks for all your excellent work and the dedicated time!!
Zero DS 13.0 => Energica EsseEsse 9+ => Energica Ribelle => Energica Experia
Rönoo Zoe => Opel Ampera-E 1st => Opel Ampera-E PLUS => TM3
Thank you!
Actually, it's not me doing the iOS. A French team member is. Problem is it has to be build up from the ground, needs a WiFi dongle, and is, in general a real PIA to develop for. So erm, sorry if this hits a nasty spot, no thanks
And it is certainly not crazy. If you got yourself a cheap tablet, you have payed as much as for a WiFi dongle, needed because Apple decided Bluetooth is not for developers. And for that money you can KEEP it in the car!! But I digress I have learned it's not cool to say things like this
ps: no planning yet for a new release. I have to implement your changes, a few others, and I want to build the charge planner.
Ich habe mir extra für Canze den konnwei kw902 unter ebay gekauft
http://www.ebay.de/itm/261993225241
Leider war der Adapter bei Ankunft schon defekt (keinerlei Reaktion auf die Spannungsversorgung)
Im Adapter ist ein pic18F25K80 verbaut, ohne eine ELM327 Kennzeichung.
Bedeutet dies, dass es eine Fälschung ist und ich mir besser das Geld erstatten lassen sollte, oder gehört dass so und ich soll nach einer Ersatzlieferung verlangen?
VG
Marinus
VG
Marinus
Defekte selbst zu reparieren, und erst reklamieren, wenn der Reparaturversuch nicht geklappt hat, ist nicht klug. Ganz ehrlich: Wäre ich der Händler, würde ich einen Ersatz verweigern. Der Verkäufer könnte den Standpunkt vertreten, dass der Artikel überhaupt erst durch den Öffnungsversuch Schaden genommen hat...
Aus der Artikelbeschreibung geht nirgendwo hervor, welche Kennzeichnung die Bauteile haben. Wieso glaubst Du, dass Du eine Fälschung hast? Was klassifiziert denn das vermeidliche Original als Original?
Ich habe ebenfalls einen "Konnewei KW902" bei eBay gekauft, er läuft klasse, stürzt aber immer wieder nach etwa ein bis eineinhalb Stunden reproduzierbar ab... Optisch im gleichen Gehäuse - aber anderer Händler und andere Farbe.
Die Chance ist groß, dass das alles aus einer Löthalle kommt. Daher könnte Dein Adapter durchaus gehen, wenn er denn geht...
Ganz blöde Frage: Du hast ihn aber schon eingeschaltet, oder? Den Taster... Er wollte anfangs bei mir auch nicht, erst seit ich aus Verzweiflung mal 5sek den Taster gedrückt hatte, ging es schließlich.
No/Yes. The ELM327 **is** a PIC. The Chinese stuff though is ALL bootlegged software. Read here http://canze.fisch.lu/elm327/
There is a common issue with these, have a look here. http://canze.fisch.lu/faulty-konnwei-maxiscan-dongle/
- 2720
Letzter Beitrag von zoe-gerer
Di 27. Jun 2023, 15:02
- 6759
Letzter Beitrag von quasimodo
Fr 15. Dez 2023, 17:10
Reichweite ZOE ZE40
- 2922
Letzter Beitrag von E-Fan66
So 11. Jun 2023, 21:52
Reichweite ZOE ZE40
- 720
Letzter Beitrag von tbline67
Di 13. Jun 2023, 11:08
- 550
Fr 16. Jun 2023, 07:28
