Hacking into Zoe's CANbus
Zubehör für den Renault ZOE
Re: Hacking into Zoe's CANbus
- Hat sich bedankt: 30 Mal
- Danke erhalten: 40 Mal
AFAIK there is no Bluetooth emulation in Android Studio.
So right now, it's walking back and forth
I am building a Bluetooth to http transport interface based on an arduino nano so I could use the emulator and do not need to walk to the other side of the house 10 times per hour.
On the back burner though.
Jeroen - ZOE Q210 Nov 2013 - PV powered - CanZE co-developer http://canze.fisch.lu
Ich habe zwei ZOEs (einen 210er und einen 240er) und eben gerade mal nach jeweils 3 Tagen Standzeit die CanZE-App genutzt. Beide standen 3 Tage nebeneinander im freien. Beide haben -2°C Batterietemperatur. Den Rest seht ihr hier:
Die Available Charging Power beim R240 passt nicht. Die kann nicht bei 51kW liegen, während sie beim 210er nur mit 8,4kW angegeben wird. Tatsächlich geladen hat der 210er laut Stromzähler allerdings nur mit ca. 2,2kW (dreiphasig!). Und zwar in Summe. Nicht etwa pro Phase. Die Außentemperatur betrug laut Cockpitdisplay zu der Zeit -9°C.
Thank you for those screen prints!! 7 degrees difference, it illustrates how long it takes to equalize temperature differences with 280 kg of mass with lots of air insulating!
The 210 looks very logical. At this temperature and SOC, the car tempers charging to the absolute minimum (2 kW) to avoid damaging the cells. Fast charging is absolutely useless, the car simply will not take it. Same with the R240.
Were both cars charging when you made these screen shots?
I have seen the 51 before. It seems like it is an "unavailable" value, though the documentation states very differently. It might be a difference between the 240 and 210, I don't know yet, as I do not have a 240 at my disposal. I would appreciate if you (and other 240 owners) could let me know, here or in a private message, if the "Available Charging Power" is always wrong / 51 or this is more incidental.
Hier sieht man den Außentemperaturverlauf an meinem Standort. Diese lag sehr lange (über 36h) bei konstant ca. 0°C. Die ZOEs wurden da nicht bewegt. (ZOE-Akku: 0°C). Erst am Nachmittag ab 16 Uhr wurde es kälter.
01:30 Uhr:
Luft lauf Temperaturmessung: -7°C
Luft laut ZOE Bordcomputer: -9°C
ZOE-Akku: -2°C
09:00 Uhr:
Luft kaut Temperaturmessung: -8°C
ZOE-Akku: -3 bis -4°C
Der 210 hat geladen von 00:20 bis 01:20 Uhr. Dann Ladung beendet und Fahrzeug gestartet und CanZE ausgeführt. Screenshot um 01:23 Uhr.
Der 240er hat vorher nicht geladen und während des Screenshot auch nicht.
01:30 Uhr:
ZOE-Akku: -2°C
09:00 Uhr:
OK, danke!
At least the "51" is not crazy then, I don't think the charger sends a pilot signal when no charge is requested (by the car pulling down the CP line). It seems it represents a DC signal on the CP line. Interesting, I don't think I ever saw that on my Q210, but I will try tomorrow morning when charging is finished.
- Hat sich bedankt: 562 Mal
- Danke erhalten: 4686 Mal
Hi,
My ELM327 dont work at low temperatures... so I set the CAN (thank you to Jeroen for the CAN-Matrix within the CanZE Sourcecode ) into my old Twizplay. It lokks not so cool like a Smartphone display, but here are the same information now. I checkt the values with a warm ELM327, that works somtimes a minute in the cold car... You see, it was very cold yesterday here in vienna, and my battery is old... By now, there is only this one display. But I think, I'll work for more. I just got the information about the Transportprotocoll, it is a very special one, with mode $21..., it seems to be a renault special. but I will try to use it like the mode $22 to start the transportprotokoll with single response, because more would be to fast for good old Twizplay.
(Jeroen, now it is to me, to confuse my zoe via CAN... I hope my wife will be as understanding as yours )
Good luck to your CanZE project, and ones more thank you for your help!
Aktuell: 150.000 km
Aktuell: 150.000 km
Great job! I really like it that our hard analytic work on how the Zoe's CANbus operates is mashed into something completely new. Fanatasic. Please make a youtube soon!
- Hat sich bedankt: 498 Mal
- Danke erhalten: 357 Mal
So eine fest installierte einfache Anzeige fände ich auch sehr interessant.
Magst du in einem (neuen) Beitrag mal ein paar mehr Informationen geben?
2014 - 2019: Renault Zoe Q210
2015 - 2020: Kangoo Maxi ZE
2019 - : Tesla Modell ≡ LR
https://ts.la/bernd30762
Ich bin erst am Anfang, etwas daraus zu machen. Die einzelnen Zellspannungen sind noch schwierig...Berndte hat geschrieben:So eine fest installierte einfache Anzeige fände ich auch sehr interessant.
Aber als Info zu der Hardware, ich habe eine Hardware genommen, die eigentlich für den Renault Twizzy gebaut wurde. Infos dazu: http://www.TWIZPLAY.de
Aktuell: 150.000 km
Aktuell: 150.000 km
- Hat sich bedankt: 279 Mal
- Danke erhalten: 213 Mal
- 2718
Letzter Beitrag von zoe-gerer
Di 27. Jun 2023, 15:02
- 6759
Letzter Beitrag von quasimodo
Fr 15. Dez 2023, 17:10
Reichweite ZOE ZE40
- 2916
Letzter Beitrag von E-Fan66
So 11. Jun 2023, 21:52
Reichweite ZOE ZE40
- 720
Letzter Beitrag von tbline67
Di 13. Jun 2023, 11:08
- 550
Fr 16. Jun 2023, 07:28
