Hacking into Zoe's CANbus
Zubehör für den Renault ZOE
Re: Hacking into Zoe's CANbus
Could one connect with the i907 once the car did shut down?jmeijer hat geschrieben:And what was really nasty is that the wakeup unlocked the charger cable!!
I do know that there are people out there securing their OBD (preventing car-theft) with Reed-switches so they can disconnect two data lines by placing a small magnet somewhere.
- Hat sich bedankt: 30 Mal
- Danke erhalten: 40 Mal
I was able to partially wake up the car and release the cable with the i907. Of course to do that, it had to be plugged in (D'uh ) and I had to be inside the locked car pressing buttons.
Monitoring what was happing, I was later able though to replay the same traffic with a connected ELM and that could be done from outside the car if the ELM was plugged in and switched on.
The reed switch scenario seems to be aimed at avoiding people breaking into your car and then do nasty things through the connector. I have not been able (have not been trying!) to i.e. start the car. But the cable was released!
Jeroen - ZOE Q210 Nov 2013 - PV powered - CanZE co-developer http://canze.fisch.lu
I am very happy to say that today, the team member that is working very hard on the "App" succeeded in getting data from the car using only an Android device and a "proper" (KW902) dongle. This really brings the entire display stuff into the realm of cheap, consumer oriented hardware. The proof of concept I showed earlier in that video is now "App"-able.
I am very excited about this. Also, the international team effort is fun!
More to follow!
More to follow!
Sneak previews!! No mockups, this is real data! (through some labels are wrong)
Start Icon
https://drive.google.com/file/d/1ELcZXj ... sp=sharing
Main menu (very silly, now two screens that two different people work on)
https://drive.google.com/file/d/13xiu1i ... sp=sharing
This will be the charging screen. Wrong labels, just a few fields, but this is real data (i.e. the max allowed charge current as communicated by the charger through the pilot signal)
https://drive.google.com/file/d/1NMzZ-c ... sp=sharing
Some random meters. Note my foot on the pedal and the wheel hard right.
https://drive.google.com/file/d/1IFtrX4 ... sp=sharing
Start Icon
Zuletzt geändert von jmeijer am Mo 7. Sep 2015, 13:59, insgesamt 1-mal geändert.
- Hat sich bedankt: 159 Mal
- Danke erhalten: 219 Mal
Wooooho, great to see this ongoing development! Thank you!
- Danke erhalten: 9 Mal
Hi, gutes Projekt!
Mich würde vor allem ein Datenlogger für die Ladevorgänge (Datum Start/Ende, Kilometerstand, Ladeposition, Stromstärke/Leistung, geladene Energie) und ein Nutzungs-Log/Fahrtenbuch mit tatsächlichem Kilometerstand und Geodäten interessieren. Wenn man dann noch ein "Tesla-ähnliches" Display für Tacho/Energieverbrauch machen könnte, wäre das spitze.
tango
4/2014 - 12/2014 10.000 km Twizy
12/2014 ZOE Intens black
07/2019 "alte ZOE" mit 41 kWh Batterie
12/2022 ID.3 Pro
02/2023 Tesla Model Y SR
tango
12/2022 ID.3 Pro
Im Gegensatz dazu würde Ich gerne eine Ferrari haben!
@DiLeGreen: Thank you, appreciated!
- 2725
Letzter Beitrag von zoe-gerer
Di 27. Jun 2023, 15:02
- 6766
Letzter Beitrag von quasimodo
Fr 15. Dez 2023, 17:10
Reichweite ZOE ZE40
- 2927
Letzter Beitrag von E-Fan66
So 11. Jun 2023, 21:52
Reichweite ZOE ZE40
- 723
Letzter Beitrag von tbline67
Di 13. Jun 2023, 11:08
- 551
Fr 16. Jun 2023, 07:28
