Model 3 lädt mit bis zu 250kW
- Hat sich bedankt: 166 Mal
- Danke erhalten: 532 Mal
Bin ich blind oder hat es noch niemand erwähnt?
An den neuen Superchargern (V3) lädt das Model 3 nach einem Software Update mit bis zu 250kW.
Alte Supercharger werden offenbar nur auf 145kW erhöht und nicht ersetzt. Nur neue sind dann 250kW
https://www.tesla.com/de_DE/blog/introd ... edirect=no
V3 is a completely new architecture for Supercharging. A new 1MW power cabinet with a similar design to our utility-scale products supports peak rates of up to 250kW per car. At this rate, a Model 3 Long Range operating at peak efficiency can recover up to 75 miles of charge in 5 minutes and charge at rates of up to 1,000 miles per hour. Combined with other improvements we’re announcing today, V3 Supercharging will ultimately cut the amount of time customers spend charging by an average of 50%, as modeled on our fleet data.
Supercharger stations with V3’s new power electronics are designed to enable any owner to charge at the full power their battery can take – no more splitting power with a vehicle in the stall next to you. With these significant technical improvements, we anticipate the typical charging time at a V3 Supercharger will drop to around 15 minutes.
On-Route Battery Warmup
New Supercharging infrastructure isn’t the only way we are improving our customers’ charging experience. Beginning this week, Tesla is rolling out a new feature called On-Route Battery Warmup. Now, whenever you navigate to a Supercharger station, your vehicle will intelligently heat the battery to ensure you arrive at the optimal temperature to charge, reducing average charge times for owners by 25%.
This combination of higher peak power with V3, dedicated vehicle power allocation across Supercharger sites, and On-Route Battery Warmup enables customers to charge in half the time and Tesla to serve more than twice the number of customers per hour. Additionally, we are also unlocking 145kW charge rates for our 12,000+ V2 Superchargers over the coming weeks.
M3 LR 2022
Re: Model 3 lädt mit bis zu 250kW
- Hat sich bedankt: 12 Mal
- Danke erhalten: 12 Mal
- Hat sich bedankt: 26 Mal
- Danke erhalten: 25 Mal
- Hat sich bedankt: 66 Mal
- Danke erhalten: 83 Mal
- Hat sich bedankt: 583 Mal
- Danke erhalten: 513 Mal
Na vom TAYCANBest_Buddy hat geschrieben: ↑ Da bin ich auf die nächsten Cannonball-Fahrten gespannt, wenn die V3 aufgestellt wurden. Ist dem M3 der erste Platz zu nehmen?
sofern er käuflich erwerbbar ist, nicht signifikant mehr verbraucht als ein M3, ausreichend freie Ladesäulen entlang der Strecke findet, die funktionstüchtig sind und bei denen die Freischaltung funktioniert und es nicht zu zu vielen Ladeabbrüchen kommt.Auch die DC-Ladeleistung steht nach Informationen von electrive.net schon fest: Sie wird bei 250 kW liegen.
https://www.electrive.net/2019/01/25/po ... ord-haben/
Twizy, Zoe, Leaf 1/2, eUp/Golf/Trans, Ampera-e, i3, ID3/4, Ioniq1/5, Model S/3/X/Y, eNV200
Ich denke, dass die aktuelle Preissenkung ein Vorzeichen auf die neuen MS + MX ist. Dauert wahrscheinlich nicht mehr lange, nehme ich an. Bin sehr gespannt, was die neuen Modelle dann alles bieten, neben der V3-Fähigkeit und der Hardware 3 !
Das könnte sein. Aber ich dachte eher an ältere MS+X. Diese fühlen sich durch die Preispflege ja jetzt schon benachteiligt.Best_Buddy hat geschrieben: ↑Ich denke, dass die aktuelle Preissenkung ein Vorzeichen auf die neuen MS + MX ist. Dauert wahrscheinlich nicht mehr lange, nehme ich an. Bin sehr gespannt, was die neuen Modelle dann alles bieten, neben der V3-Fähigkeit und der Hardware 3 !
Seit 07/2019 Model 3 SR+ Firmenwagen
Seit 02/2021 VW e-up! Style (Partnerin)
Seit 02/2021 Voll elektrisch fahrender Haushalt
Elektromeister
Elektromeister
- Danke erhalten: 120 Mal
Mit 250 kW sieht die Konkurrenz dann wirklich alt aus. Dem Polestar 2 als der einzige direkte Konkurrent, der durchaus attraktiv erscheint, würde das schon den Wind aus den Segeln nehmen. Wenn dann bald noch Model Y kommt...
Viel hat ja nicht auf ein großes Update für S und X gesprochen, da man sich gerade auch auf Model Y konzentrieren wollte. Bei der aktuellen Schlagzahl an Neuigkeiten bin ich mir da aber dann doch nicht mehr so sicher.
Das ist ja nun auch schon angegraute Technik. Es ist ja bekannt, dass man da nicht auf die neuen Zellen setzt. Dass man noch Early Adopter ist und gerade bei Tesla immer viel Dynamik drin ist, ist ja auch allen bewusst. Man hat sich ja zu einem gewissen Preis für das Produkt entschieden. Und schlechter wird es auch nicht. Ich kann nachvollziehen, dass die Nachrichten bei dem ein oder anderen schon mulmige Gefühle hinterlassen. Aber das kann man Tesla nicht wirklich ankreiden. Evtl. haben zumindest neuere S/X ja doch schon die neuere Chemie im Kasten? Der geringere Kobaltgehalt wäre ja sicherlich ein finanzielles Argument für Tesla. Und das sollte sich in der Zellfertigung auch beim 18650-Format relativ einfach umstellen lassen. Allerdings muss dann auch die Kühlung des S/X mitspielen.
Zuletzt geändert von zitic am Do 7. Mär 2019, 10:18, insgesamt 1-mal geändert.
Wenn die aktuellen MS+MX keine Hardware-Änderung benötigen, werden sie wohl über ein Software-update V3-fähig werden. Ob sich die Besitzer danach sehnen, hängt wohl vom Preis der V3-Ladung ab. Wird nicht billig werden, glaube ich.Furlinger hat geschrieben: ↑Das könnte sein. Aber ich dachte eher an ältere MS+X. Diese fühlen sich durch die Preispflege ja jetzt schon benachteiligt.Best_Buddy hat geschrieben: ↑Ich denke, dass die aktuelle Preissenkung ein Vorzeichen auf die neuen MS + MX ist. Dauert wahrscheinlich nicht mehr lange, nehme ich an. Bin sehr gespannt, was die neuen Modelle dann alles bieten, neben der V3-Fähigkeit und der Hardware 3 !
- Hat sich bedankt: 87 Mal
- Danke erhalten: 74 Mal
Ich wäre da jetzt noch nicht zu euphorisch. Aktuell wird der noch gestestet - dann soll der Ausbau in Nordamerika beginnen und nach Europa soll er Ende des Jahres kommen. Und dann ist fraglich wo und wie schnell der ausgerollt wird. Ein reiner Austausch der Hardware reicht ja nicht - da müssen neue Stromzuführungen usw her. Das wird sicherlich seine Zeit in Anspruch nehmen. Allerdings wird man wohl bald das Model 3 verstärkt bei IONITY usw an deren HPC Säulen sehen Und beim nächsten Cannonball gibts dann Stau an den 350 KW Säulen
In God we trust - all others pay cash!
Zurück zu „Model 3 - Laden, Ladeequipment“
500e 2016 lädt nicht mehr
Antworten: 3von awn » Do 18. Mai 2023, 19:00 » in 500e (US-Modell) - Allgemeine Themen - 3
- 1211
Letzter Beitrag von awn
Mi 28. Jun 2023, 14:23
DC-Ladesäule lädt über das Ladelimit hinaus
Letzter Beitrag von muenchenlaim « Mi 28. Jun 2023, 11:29Antworten: 3
Verfasst in IONIQ 6 - Laden, Ladeequipmentvon Adler » Di 27. Jun 2023, 18:22 » in IONIQ 6 - Laden, Ladeequipment - 3
- 763
- 695
Letzter Beitrag von Phlummi
Do 3. Aug 2023, 16:03
e-Golf lädt an Hypercharger zunächst nur mit 3,7 kW
Letzter Beitrag von Schreibmaschine « Mo 24. Jul 2023, 19:13Antworten: 6
Verfasst in e-Golf - Laden, Ladeequipmentvon Schreibmaschine » Do 20. Jul 2023, 16:51 » in e-Golf - Laden, Ladeequipment - 6
- 1416
Akku lädt bis 99% - Ph2/52kW
Antworten: 29von PentaStar » Di 25. Jul 2023, 18:50 » in ZOE - Batterie, Reichweite - 29
- 2634
Letzter Beitrag von PentaStar
Mo 11. Sep 2023, 08:04
