BMW, eine echte Highttech Firma
Re: BMW, eine echte Highttech Firma
I have same problem - IP conflict between motherboard and touchscreen.
How did you solve this?
I got "factory" settings:
IP-Adress: 192.168.0.101
Subnet mask: 255.255.255.0
Standard gataway: 192.168.0.132
DNS: 192.168.0.1
After update - this IP details doesn't work.
Here is the link to my dropbox folder with movie, which shows how looks update process: https://www.dropbox.com/home/WALLBOX?pr ... izacji.MOV
The IP problem you can see at 9min 52 sec.
DNS: 192.168.0.1
- Danke erhalten: 12 Mal
Hi,
if 192.168.0.101 is the IP of your Wallbox, it is very likely that this also is in the IP Range of your DHCP Server.
Solution 1) For "technical" people: open your Router Webinterface and configure your DHCP Server in that way that it does not include the IP of your Wallbox.
Solution 2) Change the IP address of your Wallbox to maybe 192.168.0.8 or lets say 192.168.0.211(both just examples), so either very low or very high. In both cases it is very likely that there is no IP conflict anymore.
I don't have any DHCP server here.
Maybe I didn't write everything clearly enough.
My wallbox is not connected to IT connection or any different ways to Internet.
After update - touchscreen can't find a way to connect with motherboard - that's why it needs to get motherboard IP.
I wrote it wrong - writing about "IP conflict" - I should write about "missing IP"
Do you think is there any way to find motherboard IP?
Is there any address section which I should try for sure like your example from 192.168.0.8 to 192.168.0.211?
Hmm,
sorry this sounds like a real "hardware" problem.
Like i always tell to my clients here, there is no magic button "make it work".
And there is nothing to setup in the Wallbox to fix this problem, as far as i know.
The best way to get service from BMW is to call the Hotline through the I3 Teleservice.
They know very well how to handle problems with BMW Wallboxes.
At least here in germany.
- Hat sich bedankt: 25 Mal
- Danke erhalten: 16 Mal
Poolcrack hat geschrieben: [...]Ich habe meinen i3 trotzdem mit dem CCS Stecker eingesteckt, die Säule startete die Ladung (blau). Nach dem Ladevorgang war die dann auf dauergrün. Wollte mir nur bisher niemand glauben.
DAS würde viel erklären, ZOE am CCSiOnier hat geschrieben:Wahrscheinlich hatte vorher eine ZOE dran versucht zu laden ... ; -)
Meine ist jetzt 2 Jahre alt und hat erst ein einziges Mal gezicktmidimal hat geschrieben:Ist die neue ZOE auch so'ne Ladezicke wie die Ur-ZOE?
- Hat sich bedankt: 99 Mal
- Danke erhalten: 224 Mal
The wallbox pro is actually using two IP numbers. The one that is entered on the touchscreen, and then +1 for the internal board.
To make sure its not conflicting with other devices I would recommend to set a higher last digit like it was suggested before:
192.168.0.240
This will also cause the wallbox to use 192.168.0.241 - but as both IP numbers should not be in use by other devices in the network, this should do.
The wallbox will reboot anyway after setting this.
192.168.0.240
BMW i3 BEV 60Ah (2013 - 2019) • Model X 100D (2017 - heute; SOH 92,8%) • Polestar 2 LR (7/2020 - heute; SOH 96%) - PV Überschussladen seit 2014
- Hat sich bedankt: 73 Mal
- Danke erhalten: 1995 Mal
Wie, sind das keine Triple am Aldi?secuder hat geschrieben:DAS würde viel erklären, ZOE am CCSiOnier hat geschrieben:Wahrscheinlich hatte vorher eine ZOE dran versucht zu laden ... ; -)
... war aber trotzdem nicht ganz ernst gemeint
Werner
Werner
- Hat sich bedankt: 133 Mal
- Danke erhalten: 63 Mal
- Hat sich bedankt: 33 Mal
- Danke erhalten: 40 Mal
Es geht darum, dass die Mitarbeiter der BMW-Niederlassung annahmen, ein Softwareupdate für den OBC des BMW würde ein Problem beheben, das eindeutig von der Wallbox ausging.
Natürlich kann man das Fahrzeug danach nicht an die fehlerhafte Wallbox stecken und erwarten, dass diese dann wieder funktioniert.
ECHTE BMW i3 Spezis / Freaks / Profis ?
Antworten: 2von Jimbob_McCoi » Fr 25. Aug 2023, 17:24 » in i3 - Allgemeine Themen - 2
- 964
Letzter Beitrag von SvenSa
Do 21. Mär 2024, 07:25
Laden an CEE16, E-Werk zu "faul" für "echte" Ladestation
Antworten: 48von peon » Di 20. Jun 2023, 14:15 » in IONIQ 5 - Laden, Ladeequipment - 48
- 3336
Letzter Beitrag von Karlsson
Do 29. Jun 2023, 15:45
Echte AHK für ID3
Antworten: 72von motoqtreiber » Fr 30. Jun 2023, 19:53 » in ID.3 - Allgemeine Themen - 72
- 10671
Letzter Beitrag von alfman
Mi 24. Apr 2024, 14:17
Echte AHK für ID3
e-ROUTES: echte Erfahrungen, was spricht dafür, was dagegen?
Antworten: 50von Lockenfrosch » Mi 24. Jan 2024, 18:03 » in e-208 - Allgemeine Themen - 50
- 6049
Letzter Beitrag von Mfixix
Sa 16. Mär 2024, 18:19
Suche Firma für Reparatur einer CCS Ladesäule
Antworten: 3von geber » Do 29. Jun 2023, 10:10 » in Ladesäulen / Status - 3
- 1475
Fr 21. Jul 2023, 01:57
