Latest CanZE update (Android), possibly better dongle control
Zubehör für den Renault ZOE
- Hat sich bedankt: 30 Mal
- Danke erhalten: 40 Mal
Verzeihung for the English please.
As a lot of you have probably noticed, we rolled out a new version of CanZE. I am particularly excited about a new, optional (and yet unproven!!) feature that might make far better use of the ELM dongles and might (MIGHT!!) even run on the crappiest of dongles; I ordered a 2 Euro one for kicks, but of course it will take weeks to arrive. Anyway, I would like to ask if some of you can set "Use ISOTP frames" in the settings and check if things run faster (especially in screens like Consumption), and/or more reliably. The dreaded ATMA errors should be gone.
If this proves to be a positive experience I am considering switching that option automatically on for ELM based dongles in the next release.
Note: In case you have build the CanSee dongle, you can use said option too, but it is faster with this setting off.
Danke vielmals,
J
Danke vielmals,
J
Jeroen - ZOE Q210 Nov 2013 - PV powered - CanZE co-developer http://canze.fisch.lu
Re: Latest CanZE update (Android), possibly better dongle control
- Hat sich bedankt: 13 Mal
- Danke erhalten: 18 Mal
Hi Jeroen,
But I usually need CanZE only for charging information, cell voltages, tyre pressures, ... - not for driving data. And this works well on both settings.
On one occasion, immediatly after turning off the motor, I got a complete freeze of communication with ISOTP switched on. There was an error messge, but that was gone to fast, so I cant tell what it was. Turning ISOTP off or restarting the app did not help, I had to turn the dongle off and on to reestablish connection. But that was only once and could not be reproduced. No clue, if it had something to do with ISOTP anyways - looked more like a crashed dongle.
Many thanks for this app!
Matthias
P.S.: Hardware: Zoe R90 (2017), Konnwei KW902 bluetooth
I tried the new setting using the pedal position bar on the driving information page. No Timeout on ATMA messages and a consistent 3 or 4sec update rate. Without the ISOTP setting, I got lots of timeouts and very inconsistent update rate/hangs on the pedal position bar.
Matthias
Danke Mattias.
Yesterday I got quite a few omissions out, so the next release will definitely be better again. I'll see if I can re-create the donge lockup.
J
J
- Hat sich bedankt: 591 Mal
- Danke erhalten: 1425 Mal
Die neue Version funktioniert tatsächlich schneller und ein paar Fehler wie die ptc Heizer die permanent als aktiv angezeigt wurden sind nun behoben.
Leider ist mit aber etwas neues aufgefallen siehe Screenshot. Der Ladestrom an einer 22kW Ladesäule wird mit 100A angezeigt. Hm. Ja...
Ansonsten gute Arbeit! Vielen Dank für die viele Entwicklungsarbeit die dahinter steckt!
Model 3 12/21 3D1/60kWh
Mii plus 03/20
8kWp PV
Mii plus 03/20
8kWp PV
Hi Athlon,
ich glaube, das ist inzwischen behoben: https://github.com/fesch/CanZE/issues/584
LG,
Matthias
LG,
Matthias
Correct. But I found new ones too
- Hat sich bedankt: 44 Mal
- Danke erhalten: 188 Mal
Habe gestern "aus Vesehen" die Version 1.49 installiert. Die Hardware ist unverändert. Jetzt gibt es massive Bluetooth-Probleme. Irgenwie geht es dann doch, (auch mal wieder nicht) - habe aber noch keine zielgerichtete Vorgehensweise zur sicheren Funktionalität gefunden.
Vesuche auf 1.42 oder 1.44 zurückzugehen https://apkpure.com/de/canze/lu.fisch.canze/versions
Beim Herunterladen auf PC wird die Version 1.44 als "unsicher" gekennzeichnet, die Versionen 1.42 und 1.41 dagegen nicht.
ZOE R240 10/2015 - Q90 ZE40 (D) 11/2017 - R135 ZE50 ab 07/2020 + TESLA M3P ab 08/2023
Alle sagten, das geht nicht! - Da kam einer, der wusste das nicht und hat´s einfach gemacht ... RENAULT schafft das sogar bei Fehlern ...
Berichtigung:R240Pe hat geschrieben: ↑ Habe gestern "aus Vesehen" die Version 1.49 installiert. Die Hardware ist unverändert. Jetzt gibt es massive Bluetooth-Probleme. Irgenwie geht es dann doch, (auch mal wieder nicht) - habe aber noch keine zielgerichtete Vorgehensweise zur sicheren Funktionalität gefunden.
Beim Herunterladen auf PC wird die Version 1.42 als "unsicher" gekennzeichnet, die Versionen 1.44 und 1.41 dagegen nicht.
Hat jemand das original APK-File der CanZE -Version 1.42 noch auf dem Handy installiert um es weiterzuleiten?
- Hat sich bedankt: 40 Mal
- Danke erhalten: 29 Mal
und das bedeutet was ???????
Mein "neues Navi" Phase 1 / Android Auto / veraltete Android Version
von C-Zer0 » Fr 12. Mai 2023, 10:37 » in ZOE - Modifikationen - 0
- 1632
Letzter Beitrag von C-Zer0
OBD Adapter für CanZe
Antworten: 32von Uwe_M » Mo 1. Mai 2023, 10:22 » in ZOE - Allgemeine Themen - 32
- 4100
Letzter Beitrag von goE
Fr 12. Mai 2023, 22:32
Canze: gefahrene Akkureichweite weicht von KM-Stand ab
Antworten: 1von Jens81 » Sa 23. Sep 2023, 18:20 » in ZOE - Batterie, Reichweite - 1
- 859
Letzter Beitrag von umberto
Sa 23. Sep 2023, 19:06
MG iSmart Android app update
Antworten: 5von maschenazi » Fr 11. Aug 2023, 17:02 » in Marvel R Electric - Allgemeine Themen - 5
- 1372
Letzter Beitrag von ranw
Fr 13. Okt 2023, 19:18
Update auf Android Automotive 12
Letzter Beitrag von KaMaKi « Di 31. Okt 2023, 18:00Antworten: 5
Verfasst in Mégane E-TECH Electric - Infotainmentvon Keksfamilie » Mo 4. Sep 2023, 22:02 » in Mégane E-TECH Electric - Infotainment - 5
- 2124
