Hacking into Zoe's CANbus
Zubehör für den Renault ZOE
Re: Hacking into Zoe's CANbus
- Hat sich bedankt: 123 Mal
- Danke erhalten: 328 Mal
Have you considered to publish your apk's also on F-Droid?
https://f-droid.org/
Many of the open source "big players" are published there. I.e. the owncloud client or the Afwall firewall for Android.
F-Droid has a similar standing in publishing apk's for Android as what github is for control versioning and publishing the source code. It is set up in the "open source" way of thinking.
Perhaps you can take a look at it (if you don't know them already)? I would be very pleased to see CanZE also there in the future
Thanx
marxx
Thanx
marxx
http://www.arachnon.de/wb
Tesla Model 3 09/2019, LR AWD AHK,
T@B 320 Wohnwagen.
T@B 320 Wohnwagen.
- Hat sich bedankt: 30 Mal
- Danke erhalten: 40 Mal
@Marxx: I will pass that message to the team. I am not ducking, but I am personally less involved with publishing.
All: The braking implementation was completely off. The new implementation will hopefully make it in tonight's release. I have learned a lot of new information last week (from Renault) and since there is a lot of interest in the braking system I have written a technical blog post on it. http://canze.fisch.lu/the-zoe-braking-system/
Jeroen - ZOE Q210 Nov 2013 - PV powered - CanZE co-developer http://canze.fisch.lu
@p.hase: if you mean, will it switch off the phone's BT adaptor? No it won't and it shouldn't, maybe it is used for handsfree calling? But I suspect that is NOT what you meant, so, if you mean: will CanZE continue talking to the ELM while it is closed, the answer is: yes/no, meaning:
1. If the App is truly closed (using the return button in Android), the connection is torn down and will be reopened when the App is started again, including initialization of the ELM
2. If the App is not closed but moved to the background, i.e. by pushing the home button or opening another app through the status bar, the connection stays open (EDIT: wrong. As stated by fesch below, the BT links is torn down too). However, the fast querying done by the current screen is paused and will be resumed when CanZE is on top again.
Things do occasionally go wrong and you have to either kill CanZE (press and hold home and swipe away CanZE) or power cycle the ELM.
Zuletzt geändert von jmeijer am So 1. Nov 2015, 20:59, insgesamt 2-mal geändert.
In that case, would you please be so kind to report it as an issue to https://github.com/fesch/CanZE/issues ? I am not being lazy, but it's easier to track progress, it will be team-followed, and you will be getting emails when the status has changed. Thank you!
In tomorrow's release there is an option (in settings) to keep all communication running in the background, so that changes said behaviour.
The first screenshot is obviously wrong. As you can see the car seems to report that the pilot to charger sends indicates 51kW No wonder it concludes 3 phases. It should be somethign like 7 phases actually In my experience, these mis-reports usually go way after a few rounds of queries.
The second screen is absolutely correct, and so are you. Cosphi deteriorates very badly at the low end of charging. When I put mine on 16A single phase, I actually get something like 3.2 kW.
Very nice SOH by the way.
- 6910
Letzter Beitrag von quasimodo
Fr 15. Dez 2023, 17:10
Reichweite ZOE ZE40
- 3130
Letzter Beitrag von E-Fan66
So 11. Jun 2023, 21:52
Reichweite ZOE ZE40
- 769
Letzter Beitrag von tbline67
Di 13. Jun 2023, 11:08
- 585
Fr 16. Jun 2023, 07:28
Kaufberatung Zoe für Rentner
Antworten: 43von MasterGreen » Fr 16. Jun 2023, 15:14 » in ZOE - Allgemeine Themen - 43
- 2755
Do 29. Jun 2023, 19:12
