225 kW limit on alpitronic ?
Re: 225 kW limit on alpitronic ?
- Köln Bonner
- Hat sich bedankt: 1212 Mal
- Danke erhalten: 1594 Mal
Alpitronic Hyperchargers have 75 kW power modules; the larger Hypercharger HYC 300 can have up to four but customers can choose to install less, so 225 kW could be three power modules in total or maybe one power modules being used by someone using the other plug.
- Hat sich bedankt: 15 Mal
- Danke erhalten: 136 Mal
- Hat sich bedankt: 30 Mal
- Danke erhalten: 57 Mal
Deutscher Text siehe unten..
An interesting question that I have already asked in the Kia EV6 forum.
In the meantime I've done almost 200 HPC charges, mainly on HYC300 - chargers and I didn't have more than 225kW with any of them.
Only with IONITY did I see a peak of 243kW.
Despite the fact that the maximum charging capacity was not used, charging strokes of 10-80% in 18 minutes were regularly possible, even in winter.
The temperature development during the charging process and its effect on the charging curve is more decisive than the peak charging power.
The coldest cell must have reached 25 degrees at the start and 35 degrees by the end of the peak charging power, which drops in a range of 45-60% SOC from e.g. 225kW to around 180kW. Only then does the charging curve fall relatively flat after the peak charging power, to the 180kW mentioned. Otherwise, when the temperature is below 35 degrees or in the warmest already above 50 degrees, it drops to 30kW and stays there for a few minutes.
Overheated cells are worse than cells that are too cold. If the cells are below 35 degrees, the charging power drops to 130kW instead of 180kW until the 35 degrees are reached and then it increases again.
This means that even if only 3 modules of 75kW each are activated on the HYC300 for the vehicle that is charging alone, the 18 minutes can be achieved.
Because even in the ideal case, if the car drives to the HYC300 charger with 26-29 degrees warm cells without preconditioning, the battery overheats at 79.5% by exceeding the 51 degrees in the warmest cell and just achieves this with the drop in charging capacity nor the 18 minutes to 80%.
If the car had driven to the IONITY charger under these initial conditions and had charged from 10%-80%, it would have seen the peak charging power of 243kW, but the 18 minutes might not have been achieved because the battery then already at 70% SOC would have overheated and the charging power would have had to be throttled.
However, charging at IONITY is a guess on my part, so far I have mostly charged at HYC300 because they are cheaper for me than IONITY.
I hope the information helps?
Best regards
Dirk
Eine interessante Frage, die ich auch schon im Kia EV6 Forum gestellt habe.
Mittlerweile habe ich fast 200 HPC-Ladungen, hauptsächlich an HYC300 - Ladern gemacht und bei keiner einzigen hatte ich über 225kW.
Lediglich bei IONITY habe ich in der Spitze mal 243kW gesehen.
Trotz der fehlenden Ausnutzung der maximalen Ladeleistung waren regelmäßig Ladehübe von 10-80% in 18 Minuten möglich, selbst im Winter.
Entscheidender als die Spitzenladeleistung ist die Temperaturentwicklung während des Ladevorganges und ihre Auswirkung auf die Ladekurve.
Die kälteste Zelle muss 25 Grad beim Start und bis zum Ende der Spitzenladeleistung, die in einem Bereich von 45-60% SOC von z.B. 225kW auf rund 180kW abfällt, 35 Grad erreicht haben. Nur dann fällt die Ladekurve nach der Spitzenladeleistung relativ flach, auf die genannten 180kW ab. Ansonsten, wenn die Temperatur unter 35 Grad ist oder im der wärmsten schon über 50 Grad, fällt sie auf bis 30kW ab und verweilt einige Minuten dort.
Schlimmer als zu kalte Zellen sind überhitzte, bei unter 35 Grad kalten Zellen fällt die Ladeleistung anstatt auf 180kW auf 130kW bis die 35 Grad erreicht sind und dann steigt sie wieder.
D.h. auch wenn an den HYC300 offensichtlich nur 3 Module a 75kW für das allein ladende Fahrzeug freigeschaltet werden, können die 18 Minuten erreicht werden.
Denn selbst im Idealfall, wenn das Auto mit 26-29 Grad warmen Zellen ohne Vorkonditionierung an die HYC300-Säule fährt, überhitzt die Batterie bei 79,5% durch das Überschreiten der 51 Grad in der wärmsten Zelle und erreicht mit dem Abfall der Ladeleistung gerade noch die 18 Minuten bis 80%.
Wäre das Auto mit diesen Ausgangsbedingungen an den IONITY-Lader gefahren und hätte dort von 10%-80% geladen hätte es zwar die Spitzenladeleistung von 243kW gesehen, die 18 Minuten wären womöglich jedoch nicht erreicht worden, weil die Batterie dann schon bei 70% SOC überhitzt worden wäre und die Ladeleistung gedrosselt hätte werden müssen.
Die Ladung bei IONITY ist allerdings eine Vermutung von mir, ich habe bisher meist an HYC300 geladen weil die günstiger für mich sind als IONITY.
Ich hoffe die Infos helfen weiter?
Viele Grüße
Dirk
Best regards
Dirk
Viele Grüße
Dirk
Kia EV6 seit 10/2022 Laufleistung bis 08/23 30.000km bei >220 HPC-Ladungen
Tesla Model S75, von 6/2017 - 10/2022 146.000km
Smart ED 451 4/2016 von 1/2020 - 09/2022 25.000km
BMW i3 94Ah, 2017-2019 30.000km
Thanks!
These are two persons confirming the phenomena. Thus I can stop worrying about individual stations being mismanaged. Instead time to reframe the question as to why alpitronic stations do this?
I am not complaining, 225 is plenty in fact, but I do like things working properly and up to their face value
I am quite sure the station is assigning three stacks to the output. Yesterday I had a charging session on HYC_300 up to 98% (unexpectedly longer fast food dinner than anticipated) and I have seen the station deassign stacks, first down to two stacks at 92.5% SoC and then down to a single stack at 95.5% SoC. Second cable was not in use. See the CarScanner recording here
https://blu.oook.cz/ev6/20230805_plzen_olympia_cez_300
Also note how in precharge the station downgrades it's own peak values to match values reported by the car, current to 310A, and power limit to 243130 W, always on any HYC_300 unit. For comparison Tritium Ionity station will send 826V 310A and 256060W (826*310=256060 exact).
https://blu.oook.cz/ev6/20230804_d1_pav ... ionity_350
Does alpitronic somehow calculates the car maximums as 310A 784,29V (= 243130)? Where does 784,29V comes from? Is it almost exactly 95% of 826V, suspicious!
There must be a formula in the alpitronic software that counts how many stacks to assign. But what is it?
- Hat sich bedankt: 97 Mal
- Danke erhalten: 369 Mal
It would be interesting to see what happens when a Lucid Air, Lotus Eletre or Porsche Taycan / Audi GT drive to the HYC_300 for charging.
Do they only get 225kW or more because they can call off up to 355kW?
Taycan does pull its usual 270 kW from HYC_300 installations, local CPO's technician confirmed this to me and also see numerous Youtube videos, for example https://www.youtube.com/watch?v=C37-YJOuEhI time 1:09:55
- Hat sich bedankt: 2865 Mal
- Danke erhalten: 912 Mal
The maximum ist 305/306A.
Zurück zu „EV6 - Laden, Ladeequipment“
Felgen - 17" mit 205 oder 225 realer Mehrverbrauch?
Antworten: 7von AlleInsGold » Do 7. Dez 2023, 11:37 » in Hyundai - modellübergreifend - 7
- 1172
Letzter Beitrag von AmperaEoderZoe
Mi 3. Jan 2024, 00:00
Heizung im Plugin-Hybrid C5 Aircross Hybrid 225
von UpHillHugo » Mi 17. Jan 2024, 16:32 » in Citroën - modellübergreifend - 0
- 735
Letzter Beitrag von UpHillHugo
Mein Auto wurde während des AC-Ladens abgesteckt (ALDI Süd, Alpitronic)
Antworten: 45von mini.ch » Mi 7. Jun 2023, 13:59 » in Öffentliche Lade-Infrastruktur - 45
- 4601
Letzter Beitrag von MaXx.Grr
Mo 31. Jul 2023, 18:53
Q8 e-tron 55: Laden max. 150kW an alpitronic?
Antworten: 2von Ju146 » So 10. Dez 2023, 14:15 » in Q8 e-tron - Laden, Ladeequipment - 2
- 1317
Letzter Beitrag von twulf
Mi 20. Dez 2023, 17:26
"Fehler Elektrosystem" nach Ladeversuch an alpitronic 400kW Ladesäule
Antworten: 3von tibe » Fr 29. Dez 2023, 20:35 » in e-Golf - Laden, Ladeequipment - 3
- 1100
Letzter Beitrag von ZehAhEss
Mo 1. Jan 2024, 00:41
