Hacking Renault Zoe and other Renault vehicles (maybe also Nissan?)
Re: Hacking Renault Zoe and other Renault vehicles (maybe also Nissan?)
I found something here:
https://github.com/hacf-fr/renault-api/ ... i/const.py
de_DE:
3_7PLksOyBRkHv126x5WhHb-5pqC1qFR8pQjxSeLB6nhAnPERTUlwnYoznHSxwX668
de_AT:
3__B4KghyeUb0GlpU62ZXKrjSfb7CPzwBS368wioftJUL5qXE0Z_sSy0rX69klXuHy
de_CH:
3_UyiWZs_1UXYCUqK_1n7l7l44UiI_9N9hqwtREV0-UYA_5X7tOV-VKvnGxPBww4q2
I updated the app, but I don't understand if updates are immediately visible in published app, can you please check if you see a list of gigya keys in the app now?
de_DE:
de_AT:
de_CH:
Main objective is to allow access to features not available in official app, such as:
- viewing complete error messages rather than "ops, something went wrong"
- reset HVAC schedule and set a new schedule without need to be in the vehicle
- set HVAC temperature (but a bug on my vehicle automatically always reset it to 21°C...)
- setup HVAC start at a single specific date/time (not affecting schedule)
- download charges history
All above features have been already successfully tested in javascript version of the app.
Some additional features appears to be available in the Renault server but protected by a further security layer based on "SRP authentication" (currently under investigation):
- door lock/unlock
- windows open/close
- horn activation
- lights activation
- trips history
But it is also possible that these are only available for Nissan vehicles.
- Hat sich bedankt: 688 Mal
- Danke erhalten: 135 Mal
Which JavaScript App? You mean that copy & paste thing that sends the credentials unsecured to a PHP-script?
The "features" are all tested in several apps you can find at GitHub. Nothing new from your side, except no user experience.
Likewise I have to install the App Inventor App and load than your app. Not very user-friendly
Ahem, I am not the one who spit big words.
And I think I already suggested some things, but Okay.
Your code should be OpenSource, hosted at GitHub, Bitbucket or something where everybody is able to view, download and create Issues / Pull requests.
If you want ist user friendly, then make a user-friendly installation routine.
If you want it user-friendly, then create a user-friendly interface. Not a collection of controls without any UX/UI.
Don't use a unsecured connections. Don't store user-data in plain-text.
Write clean code, except it is a kind of testing branch, but your main should always be clean
Maybe you should think about your goals?
You want to dig into the API? Wonderful. Create a Repo at a hoster and push your information.
If you want something user-friendly? Then let ist look like it is user-friendly and has some benefits against the original app.
Maybe you should define your app-target devices and choose a programming language that fits your target. Cause there are ait off implementations of Renault API at GitHub.
There is one targeting IOS devices with a special app that let's you run JavaScript locally at your device.
Done. You find Javascript and PHP sources on github, and Appinventor source... well, in Appinventor.Your code should be OpenSource, hosted at GitHub, Bitbucket or something where everybody is able to view, download and create Issues / Pull requests.
Done. I have an APK ready for installation. Will you install it?If you want ist user friendly, then make a user-friendly installation routine.
Done in ApInventor: just paste your credentials, click 2 buttons and you have your vehicle data.If you want it user-friendly, then create a user-friendly interface. Not a collection of controls without any UX/UI.
Done, Appinventor app use HTTPS.Don't use a unsecured connections.
Done, I don't store anything.Don't store user-data in plain-text.
This is an experiment, already working fine for me; if it cannot work for anybody else due to limitations which I can't know/understand/solve, why bothering with "clean" version?Write clean code, except it is a kind of testing branch, but your main should always be clean
That's why I am looking for beta tester.
Done, listed in previous messages.Maybe you should think about your goals?
Are you repeating same things?...You want to dig into the API? Wonderful. Create a Repo at a hoster and push your information.
...yes, you are just repeating...If you want something user-friendly? Then let ist look like it is user-friendly and has some benefits against the original app.
I am experimenting with 3 different languages.Maybe you should define your app-target devices and choose a programming language that fits your target. Cause there are ait off implementations of Renault API at GitHub.
Now, as you see, you have just complains, no suggestions, no feedback, no testing, no improvements, no results, all of your posts are just noise.
That said....
...is anybody ELSE interested in beta-testing the Appinventor app to get data not available in official app?
APK attached, use it at your own risk. Source code available here: https://gallery.appinventor.mit.edu/?ga ... ead07c2545
- Dateianhänge
- RenaultDroid_1.zip
- (3.39 MiB) 28-mal heruntergeladen
Nope, still won't install your APK.
The Screenshot at App Inventor looks like the App is still in early Alpha stage.
Also I have seen your JavaScript/PHP approach and so your are not trustworthy to me at he moment.
And also I am not your target group. I am using my own implementation within my own ecosystem.
But maybe if I have a little bit of time I will have a look at your App with App Inventor.
And after giving you feedback to your JavaScript approach you will get feedback about your App Inventor approach.
If you are looking for Beta testers, maybe you should announce it not like a release
- Hat sich bedankt: 600 Mal
- Danke erhalten: 1454 Mal
No keys to choose in the new app. I tryed per c&p but nothing work.
Model 3 12/21 3D1/60kWh
Mii plus 03/20
8kWp PV
Mii plus 03/20
8kWp PV
Munro Vehicles (Offroad)
Antworten: 1von wisewizz » Mo 23. Okt 2023, 11:28 » in Serienfahrzeuge - 1
- 586
Letzter Beitrag von AbRiNgOi
Mo 23. Okt 2023, 12:43
Renault Zoe R90 charging and moving problem
von diesel89434 » So 24. Sep 2023, 21:10 » in ZOE - Garantie, Probleme - 0
- 727
Letzter Beitrag von diesel89434
EX30 , EX30 Cross Country and EX90 at eCarExpo
von eSaab » Di 21. Nov 2023, 20:22 » in EX30 - Allgemeine Themen - 0
- 1049
Letzter Beitrag von eSaab
Charging in Deutschland and Osterreich
Antworten: 4von marx123 » Do 7. Dez 2023, 18:49 » in Öffentliche Lade-Infrastruktur - 4
- 399
Letzter Beitrag von marx123
Do 7. Dez 2023, 20:49
Plug and Charge - Nutzungs- und Fehlerberichte
Letzter Beitrag von Christian Ioniq « Do 4. Jan 2024, 12:23Antworten: 21
Verfasst in IONIQ 6 - Laden, Ladeequipmentvon tacjazo » Mo 11. Dez 2023, 09:10 » in IONIQ 6 - Laden, Ladeequipment - 21
- 2331
