Vorstellung SETEC 10KW mobiler CHAdeMO Lader
Re: Vorstellung SETEC 10KW mobiler CHAdeMO Lader
- Hat sich bedankt: 2453 Mal
- Danke erhalten: 1693 Mal
The problem of upgrading my leaf on board charger is, that i would have to cut the cables....in the moment there are just a few spare parts in europe...in the us you could get connectors and build your adapters....in case i would remove it for selling..
With the dc charger in the back ...you loose space and you have to juggle the cables...but you can remove it right a way..
I just received an offer for a sentec 10kw mobil charger.(3000 usd for ccs and chademo)..is there a way to push it to 15-20 kw....put just another ac-dc paralell?
Theoretically it should be possible.
I'll try and find another producer for mobile 20kw chargers. Most of them do not have CE and that is a problem.
20kw is about maximum you can get from 32amps at 380 which is a common value for CEE 5 pin plugs.
Zuletzt geändert von duud40 am Mo 17. Okt 2016, 11:08, insgesamt 1-mal geändert.
- Hat sich bedankt: 279 Mal
- Danke erhalten: 127 Mal
If there is european warranty and support (repair, spare parts) it would be more attractive to buy.
Same for the fixed 20kW and 50kW chargers.
We need to take a closer look at it.
The company I work for does exactly that. We offer OEM products under our own brands for electronics and home appliances.
This year we're negotiating an expansion to Hungary and Bulgaria.
I'll translate the menu into german and send you some pics. Let me know what you think.
What would you be willing to pay for the 20kw and 50kw versions ?
I know the cost of buying, transport and some of the cost of maintenance but what would be a margin we can safely practice ?
Could you be so kind as to answer a question ?
I have seen that some products require a different certification for sale in Germany.
I believe it's different than the TUV or the CE and is specific for Germany.
What is the name of the certificate ?
I may be wrong but please help me out.
The point is that we need to be 100% legal when selling this product within the EU.
It needs just CE. TÜV should not be required, TÜV is in this case more like a quality certificate. But it needs to be compliant to VDE rules.
Zuletzt geändert von Tho am Mo 17. Okt 2016, 14:05, insgesamt 1-mal geändert.
- Hat sich bedankt: 79 Mal
- Danke erhalten: 184 Mal
Leasingfahrzeug Fiat 500e, kann ich mit mobiler Rückfahrkamera „nachrüsten“? Oder geht auch ohne?
Antworten: 8von ABC » Fr 14. Jul 2023, 17:36 » in 500 Elektro - Allgemeine Themen - 8
- 1080
Letzter Beitrag von Toschi
Sa 15. Jul 2023, 23:02
- 587
Letzter Beitrag von Xentres
Di 31. Okt 2023, 11:49
Vorstellung eines neuen Mitglieds
Antworten: 7von Nitschi66 » Mo 24. Jul 2023, 15:06 » in Ampera-e - Allgemeine Themen - 7
- 881
Letzter Beitrag von Kehrmaschine
Mo 14. Aug 2023, 20:33
Vorstellung, nach Seat MII Kauf
Letzter Beitrag von et4410 « Di 10. Okt 2023, 07:44Antworten: 12
Verfasst in e-up!, Citigoe iV, Mii electric - Allgemeine Themenvon Tom MII » Mi 20. Sep 2023, 19:44 » in e-up!, Citigoe iV, Mii electric - Allgemeine Themen - 12
- 1367
Vorstellung innocept mobility
Letzter Beitrag von innocept mobility « Mi 3. Jan 2024, 17:31
Verfasst in Betreiber, Roaming und Abrechnungvon innocept mobility » Mi 3. Jan 2024, 17:31 » in Betreiber, Roaming und Abrechnung - 0
- 397
