OVMS für den Soul
Re: OVMS für den Soul
- Hat sich bedankt: 89 Mal
- Danke erhalten: 212 Mal
I just did a quick check, it seems we forgot to add the KIA module to the default build configurations.
To add user confusion, the vehicle configuration will still accept the "KS" code, silently falling back to the stub code...
I'll create & upload a new firmware hex file set this evening.
Michael
Twike 3 (2001) … Emco Novum (2009) … Twizy 80 (2012) … Mii electric+ (2020)
https://dexters-web.de
Thank you for answers. I have tried while charging, and it still said the same with STAT?
I also had GPS issues with the production version 808, and that is now working with the experimental version from gig hub.
I have tried the production version several times and it seems to have the result for the GPS. And as far as I have understood the GPS is not connected to the vehicle type?
Has anyone the new hw working with a kia soul?
So here's the firmware set including (hopefully) the KIA module:
https://dexters-web.de/f/kiasoul/V2_exp ... iasoul.zip
Please let me know if these images work.
Michael
First charge station data sync may need some minutes if you've got a slow phone or connection. To speed up, reduce the "max results" setting. The charger type filter does not affect the data download, only the display. If you've been using an older App release before, you may need to clear the App data once to init the database.
Data is from openchargemap.org, if you miss a station, simply add it.
Michael
Nun klappt es auch bei mir!
Ich erhalte mit STAT?
Standard - Charging
216V/26A
Full: 126 mins
SOC: 56%
Ideal Range: 100 km
Est. Range: 100 km
ODO: 3,026.4 km
diese Daten. Aber nur bei Zündung an. Sollte dies nicht auch auch nur beim Laden funktionieren.
Now, everything is fine. I get with the message STAT?
Standard - Charging
216V/26A
Full: 126 mins
SOC: 56%
Ideal Range: 100 km
Est. Range: 100 km
ODO: 3,026.4 km
this data. But only with ignition on. it should not only function when loading the car?
Standard - Charging
216V/26A
Full: 126 mins
SOC: 56%
Ideal Range: 100 km
Est. Range: 100 km
ODO: 3,026.4 km
Standard - Charging
216V/26A
Full: 126 mins
SOC: 56%
Ideal Range: 100 km
Est. Range: 100 km
ODO: 3,026.4 km
- Hat sich bedankt: 125 Mal
- Danke erhalten: 177 Mal
Das sollte beim Laden sowieso funktionieren.Woody_AT hat geschrieben:Nun klappt es auch bei mir!
Standard - Charging
216V/26A
Full: 126 mins
SOC: 56%
Ideal Range: 100 km
Est. Range: 100 km
ODO: 3,026.4 km
Standard - Charging
216V/26A
Full: 126 mins
SOC: 56%
Ideal Range: 100 km
Est. Range: 100 km
ODO: 3,026.4 km
Und das OVMS funktioniert auch wenn der Wagen steht und verriegelt ist.
38m2 FlachK. > 260'000kWh
1.5kWp PV > 10'000kWh
09.14 - 07.15 i-MiEV 13500km
Vielen Dank, für eure Hilfe.^tom^ hat geschrieben:
Nun klappt alles!
Über das OVMS iOS App erhalte ich nun die Daten.
Das ganze klappt aber nicht mit Dexters Server? Ich meine es gibt gibt kein iOS App dafür? Wäre mir fast sympathischer.
Zurück zu „Soul EV - Allgemeine Themen“
OVMS 3.x für Zoe ph1 , in Kürze auch mit Vorklimatisierung
Antworten: 17von BinKino » Mi 21. Feb 2024, 21:19 » in ZOE - Zubehör - 17
- 1302
Letzter Beitrag von Dimitrie78
Mi 28. Feb 2024, 21:11
"Soul EV PE (MY'23)" versus "Soul EV (MY'23)"
Antworten: 2von eHannes » Mi 18. Okt 2023, 21:32 » in e-Soul - Allgemeine Themen - 2
- 1136
Letzter Beitrag von eHannes
So 22. Okt 2023, 19:24
e-Soul gebraucht – Kilometer vs. Baujahr
Antworten: 7von alexander7 » Do 7. Sep 2023, 12:02 » in e-Soul - Allgemeine Themen - 7
- 1573
Letzter Beitrag von ManuelF
Mo 13. Nov 2023, 07:12
KIA e-Soul Dyno - Leistungsprüfstand
Antworten: 5von prrinz » Do 16. Nov 2023, 11:14 » in e-Soul - Antrieb, Elektromotor - 5
- 844
Letzter Beitrag von prrinz
Fr 17. Nov 2023, 08:51
E-Soul Starterbatterie selber wechseln?
Antworten: 5von Foschi » So 24. Dez 2023, 09:34 » in e-Soul - Allgemeine Themen - 5
- 1023
Letzter Beitrag von iOnier
So 24. Dez 2023, 16:48
