PEB replacement and reprogramming
Re: PEB replacement and reprogramming
Hello,
I am new in this forum, because I am facing technical issues with my ZOE.
Unfortunatelly the discussion of this topic ends in the most interesting part. Hopefully you could add some pictures of the part of the PEB, which should not be changed, because it contains an electric code. In addition it would be interesting to know, what the cooling hoses are for. Is the PEB liquid cooled (water+antifreeze)?
For the people who are interested in my background: It seems that my Zoe Q210 has a problem with its DC/DC converter, which is part of the PEB. I always get the message, that the battey cannot be charged and that I have to check the electric system. I tried several things, but at least I recognized that the DC voltage of the 12V battery does not increase, when a awake or close the car. Measuring the voltage of the 12V output of the PEB shows, that voltage is at 0V. Driving the car is not possible anymore, because it does not start. Till last week driving was possible, but the Lithium Battery could only be charged till 20% and I always got the message that battery chargin is not possible.
I would be very grateful for some help.
- Danke erhalten: 7 Mal
Jinko, did you find a way to repair or get your repaired? I was thinking that because usually power electronics part(bottom half of PEB) is the one that fails, might it be possible to replace only bottom part of unit? Coding and motor matching memory chip is in upper part. Pamplonicadel13 can you post pics of IGBT transistors inside bottom part?
Tero Kaarlela
Finland
Tero Kaarlela
Finland
Zurück zu „Fluence Z.E. - Antrieb, Elektromotor“
R240 Ladestart löst FI aus - PEB BCB tauschen - Marderschaden?
Antworten: 8von MartinElektrisch » So 18. Jun 2023, 13:03 » in ZOE - Laden, Ladeequipment - 8
- 959
Letzter Beitrag von Rhyme
Di 20. Jun 2023, 18:08
Renault Zoe R90 charging and moving problem
von diesel89434 » So 24. Sep 2023, 21:10 » in ZOE - Garantie, Probleme - 0
- 663
Letzter Beitrag von diesel89434
EX30 , EX30 Cross Country and EX90 at eCarExpo
von eSaab » Di 21. Nov 2023, 20:22 » in EX30 - Allgemeine Themen - 0
- 813
Letzter Beitrag von eSaab
Charging in Deutschland and Osterreich
Antworten: 4von marx123 » Do 7. Dez 2023, 18:49 » in Öffentliche Lade-Infrastruktur - 4
- 366
Letzter Beitrag von marx123
Do 7. Dez 2023, 20:49
Plug and Charge - Nutzungs- und Fehlerberichte
Letzter Beitrag von Christian Ioniq « Do 4. Jan 2024, 12:23Antworten: 21
Verfasst in IONIQ 6 - Laden, Ladeequipmentvon tacjazo » Mo 11. Dez 2023, 09:10 » in IONIQ 6 - Laden, Ladeequipment - 21
- 1958
