Greenway Polska - 75 Schnelllader in Polen
Re: Greenway Polska - 75 Schnelllader in Polen
- Volker.Berlin
- Hat sich bedankt: 532 Mal
- Danke erhalten: 424 Mal
Heute kam von GreenWay Polska folgenden Kundeninformation. Meines Wissens ist GreenWay Polska somit der erste Anbieter überhaupt, der für ganz Europa einen einheitlichen Tarif anbietet!
https://greenwaypolska.pl/wp-content/up ... 2019-1.pdf
Aktualisierte Preisliste:
Terms and conditions:bok@greenwaypolska.pl hat geschrieben:First of all, we implement the roam like at home policy for customers using Benefit Price Programs. Benefit Price Programs are those pricing plans in which in exchange for a monthly subscription fee you can benefit from lower rates for DC charging and longer charging time without a minute fee (currently Energia Max and Energia Plus). Roam like at home is a rule that has been in force for some time on the telecommunications market in the European Union.
Thanks to roam like at home you will be able to travel around Europe using attractive prices for charging services. When you will charge your vehicle at our roaming partner's station, you will pay the same price as on the GreenWay network.
- Hat sich bedankt: 583 Mal
- Danke erhalten: 513 Mal
- Danke erhalten: 87 Mal
http://data.greenway.sk/clientzone/pricelist_EN.pdf
Hier die Preisliste in Euro und englisch von Greenway Slovakia.
- Volker.Berlin
- Hat sich bedankt: 2006 Mal
- Danke erhalten: 950 Mal
Man sollte auch auf jeden Fall die Fair-use-Policy beachten (Artikel 3):
"You may be deemed to be in breach of this policy if, during any two-month time period, (i) the volume of recharging services (in kWh) used by you in the roaming partners' networks exceeds the volume of recharging services in our network by at least 50%, or, (ii) the volume of recharging services used by you in the roaming partners' networks exceeds 1,000 kWh, while you don’t use our network at all or use our services at low amount (50 kWh or less)."
Wenn man also nicht regelmäßig in Polen bei Greenway vorbeikommt und dort die Hälfte seiner kWh lädt, ist das Roaming mit den Greenway-Tarifen keine dauerhafte Option.
TESLA-Leerverkäufer erstellen falsche "Kunden" - Beschwerden bei der US-Aufsichtsbehörde
Wie TESLA-Leerverkäufer das öffentliche Bild von Tesla manipulieren
= illegale Strategie namens "Short and Distort" (s. Investopedia)
- Danke erhalten: 9 Mal
- Volker.Berlin
Ich habe eine Greenway-Karte. Wenn ich mit der lade, bekomme ich eine detaillierte Bestätigung über Dauer, kWh und Kosten per Email innerhalb von Minuten nach dem Beenden des Ladevorgangs. newmotion ist bekannt dafür, dass Abrechnungen manchmal erst Monate nach dem Ladevorgang kommen, hat nichts mit Greenway zu tun.
Auf die Rechnung aus Polen warte ich bereits Monate. In Deutschland sehe ich die Rechnung von NewMotion meistens recht schnell. Aber auch hier fehlt mir eine Abbuchung seit längerer Zeit. Ich habe in einer Stadt am selben Tag beim gleichen Anbieter an zwei gleichen Säulen geladen. Eine davon wurde abgerechnet, die andere bisher nicht. Erscheint mir sehr seltsam.
- Shortseller
- Hat sich bedankt: 171 Mal
- Danke erhalten: 122 Mal
Neu eingeweihte Säulen sind bei Greenway manchmal für eine Zeit lang gratis. Wenn die Ladung nicht in deinem Greenway Account zu sehen ist, dann hast du wohl so eine erwischt. Da Greenway selbst der Betreiber und Abrechner ist, gibt es keinen Zeitverzug zwischen Ladung und Erscheinen im Backend. Die Ladung ist dort zu sehen, sobald du sie startest.
Früher erschienen auch die Gratisladungen dort mit 0 Euro. Hatte schon seit geraumer Zeit keine Gratisladung mehr, darum kann ich nicht wissen, ob es immer noch so ist.
Laden in Polen
Antworten: 8von Clyde » Mi 10. Mai 2023, 07:22 » in Ladesäulen / Status - 8
- 2184
Letzter Beitrag von tm7
Do 1. Feb 2024, 09:08
Laden in Polen
Von Wien über Tschechien, Polen, Slowakei, Ungarn - welche Ladekarten?
Antworten: 5von maexxx » So 28. Jan 2024, 22:48 » in Betreiber, Roaming und Abrechnung - 5
- 398
Letzter Beitrag von env20040
Mo 29. Jan 2024, 09:48
Schnelllader Kärnten Raum Villach
Antworten: 8von klaus1 » Mi 7. Jun 2023, 16:44 » in Betreiber, Roaming und Abrechnung - 8
- 715
Letzter Beitrag von TransA
Do 27. Jul 2023, 14:15
Schnelllader Allego Wittenberg
Antworten: 6von thundang » Mo 12. Jun 2023, 09:07 » in Ladesäulen / Status - 6
- 1776
Letzter Beitrag von thundang
Mo 19. Feb 2024, 09:10
Ladeleistung am Schnelllader
Letzter Beitrag von Cyrius « Fr 18. Aug 2023, 16:12Antworten: 10
Verfasst in Marvel R Electric - Laden, Ladeequipmentvon Ek4turbo » Di 15. Aug 2023, 09:58 » in Marvel R Electric - Laden, Ladeequipment - 10
- 1658
