Charge not possible + motor controller noise
Hi all,
We have 2 Renault Fluence z.e
Both same age but recently one of the fluence get the BCI error (charge not possible) also when I compare one fluence with the one which has the problem makes more noise when put in drive..sound comes from controller I think is like high frequency tone but not normal..also this cause the error on the screen. Where can I check?
Re: Charge not possible + motor controller noise
- Danke erhalten: 57 Mal
Hi "jinko",
this could be an early symptom for a defective motor. Most Fluences seem to show a "Charge not Possible", possibly combined with "check Speed Limiter" error before it runs into a "Motor defective error.
It is likely to be an insulation problem with the motor brushes.
Cheers
Andreas
Cheers
Andreas
Zurück zu „Fluence Z.E. - Allgemeine Themen“
Smart EQ mit 22 kW Lader zickt am go-e controller
Antworten: 3von lamouette » Di 10. Okt 2023, 20:28 » in EQ fortwo - Laden, Ladeequipment - 3
- 1097
Letzter Beitrag von ms_smart
Do 30. Nov 2023, 17:10
Go-E Controller Kompatibilität mit Go-E Mobile
Antworten: 4von MasterGreen » Do 12. Okt 2023, 11:40 » in Ladeequipment - 4
- 438
Do 12. Okt 2023, 19:48
Go-controller Anzeige Solaranlage Wechselrichter: Leistung im Dunkeln
Antworten: 1von Jediborn » Sa 25. Nov 2023, 19:49 » in Ladeequipment - 1
- 439
Letzter Beitrag von SunPower2024
Sa 2. Mär 2024, 21:24
Kommastellen bei go-e Controller verrutscht
Antworten: 1von SunPower2024 » Sa 2. Mär 2024, 20:41 » in Ladeequipment - 1
- 277
Letzter Beitrag von koaschten
So 3. Mär 2024, 05:43
Open Source CCS Controller
Antworten: 6von uhi » Di 19. Mär 2024, 11:53 » in Ladeequipment - 6
- 564
Mi 20. Mär 2024, 12:38
