kW fur Heizung und AC
Re: kW fur Heizung und AC
- Hat sich bedankt: 156 Mal
- Danke erhalten: 79 Mal
Besides keeping the interior temperature at a certain level, for example 22 °C, the car's heater is also used to bring the temperature at that level in the first place. This happens when no preheating was applied. For example, when the car is at temperature +4 °C when you leave, then the heater has to increase the temperature by 18 °C until it is 22 °C. The amount of energy needed for this depends proportionally on the difference in temperature with a rate that is called the heat capacity of the car. The heat capacity is a parameter that indicates the amount of energy needed to increase the car's interior temperature by 1 °C.
Note the difference with the loss rate in the above post. Loss rate depends on the surface or 'skin' of the car's interior, such as the roof, the windows, the floor, the doors, and how well insulated this skin is. In contrast, capacity depends not on the surface, but on the volume and/or mass of the interior, how much heat energy the interior in a sense stores or absorbs by heating it. If some material stores a lot of energy, you need a lot of heat to let the temperature rise, if it stores less energy, less heat is needed to let it increase.
When for some cases you know the amount of heat delivered by the heat pump and/or resistance heater, and also how many degrees °C the interior has increased in temperature, you can estimate the heat capacity parameter. For example, when for 5 minutes the heater works at 6 kW, then the total amount of produced energy can be calculated by 5*6/60 = 0.5 kWh. This energy is taken from the battery, so that for a two hour trip as in the above post your battery spends a total of 1.0 (due to maintaining) + 0.5 (due to initial increase)= 1.5 kWh in total on heating during the whole trip. This is 1.5/28 = 0.054 of the whole battery, which is 5.4 %. By this percentage also your range will be reduced.
Assuming the increase in temperature was 18 °C (from 4 to 22), and the heat was produced only by the resistance heater, this gives an estimate for the heat capacity parameter of 0.5/18 = 0.028 kWh per °C increase. However, when the car also has a heat pump, then this will probably also contribute to the increase. As it increases very fast in only a few minutes time, it is probably not only the heat pump; maybe most (or almost the whole) of the increase is due to the resistance heater.
Zuletzt geändert von Jan Treur am Di 18. Apr 2017, 07:35, insgesamt 1-mal geändert.
Ordered a Project 45 Ioniq 5 Gravity Gold Matte
Since October 1, 2019: 2020 Hyundai Ioniq Electric 38.3 kWh
In the previous post I have shown an example calculation of one situation. I also made a computational model that gives an indication for each outdoor temperature what the initial heating to increase the car's temperature to 22 °C will cost you in kWh from the battery (when you did not do preheating). See the graph below; in this graph two cases are compared: heating only based on a Resistance Heater (RH) in purple, and heating based on a Heat Pump (HP) in combination with a Resistance Heater in light blue/grey.
It can be seen that the heat pump only has a very modest advantage over the resistance heater for this initial heating. Roughly spoken this initial heating may cost you from 0.5 kWh (for +5 °C) up to 1.5 kWh (for -20 °C).
I assumed that when a heat pump is available, the initial interior temperature increase is for 80% based on the resistance heater and for 20% on the heat pump (and only for -10 °C and higher). This is based on an assumption on the maximal power the heat pump can take (1200 W) and the related maximal production capacity of the heat pump. As the initial heating takes place very fast, as a kind of boost, I think it is reasonable to assume that the resistance heater plays a main role in it.
For these graphs the heat capacity of the car was assumed 0.0286 kWh per °C increase, which made that the data point from @pmiddeld mentioned in http://www.ioniqforum.com/forum/35281-post81.html (at +4 °C, it took about 5-6 kW for heating in the first 5-6 minutes before going down to 0.5 kW) is on the curve. Of course, more data points are welcome.
Lithium akku geöffnet um heizung nachzurüsten.
Antworten: 13von bambione » Do 21. Sep 2023, 09:10 » in Rocks-e - Antrieb, Elektromotor - 13
- 1654
Letzter Beitrag von Stwo
Di 3. Okt 2023, 16:40
Heizung
Antworten: 42von flash_08 » Do 21. Sep 2023, 10:32 » in Rocks-e - Allgemeine Themen - 42
- 4020
Letzter Beitrag von bambione
Sa 2. Dez 2023, 16:48
Heizung
Heizung: wann schaltet Zusatzheizer an / Innensensor Einflußnahme Temperatur
Antworten: 33von moschberger » Do 19. Okt 2023, 21:02 » in ZOE - Bedienung, R-Link, Easy Link - 33
- 2507
Letzter Beitrag von dell
So 19. Nov 2023, 16:14
Verbrauch Heizung
Antworten: 13von Bastel » Di 24. Okt 2023, 18:35 » in Combo-e - Batterie, Reichweite - 13
- 1680
Letzter Beitrag von Bastel
So 28. Jan 2024, 20:14
Verbrauch Heizung
"Wartung - Heizung" Meldung im Fahrer Display
Antworten: 16von schustero » Mi 15. Nov 2023, 20:21 » in Ampera-e - Allgemeine Themen - 16
- 1338
Letzter Beitrag von schustero
Mi 13. Dez 2023, 17:55
