Mercedes e 350 e limousine ES-LS 2007 hybrid
Hi everyone,
I have a strange problem with a Mercedes e350 hybrid when I try to charge it. When I connect the car to the charging point, the charging point do not detect that the car is connected. Then I restart the charging point (disconnecting and connecting again) and then the charging point detects the car and it is possible to initiate the charge.
I find this really strange because for other electric/hybrid cars I have no problems. This Mercedes is new from this year, what can be the problem? Does anyone have the same issue?
Thank you all in advance,
Nacho
Nacho
Re: Mercedes e 350 e limousine ES-LS 2007 hybrid
- Danke erhalten: 12 Mal
Hi,
maybe i have a similar behavior.
For me it seems if i Start/Stop the charging several times in a short period of time, the car blocks the charging for some minutes and then tries again.
I could only observe this behavior if my Wallbox, who is controlled via Solar, was hovering around the 1KW solar power.
If above charging starts if below charging stops and after several on/off the car does not start the charging anymore but also recovers automatically.
Besides that i had no problems so far.
- Hat sich bedankt: 207 Mal
- Danke erhalten: 402 Mal
Zurück zu „andere Plug-In Hybride“
Heizung im Plugin-Hybrid C5 Aircross Hybrid 225
von UpHillHugo » Mi 17. Jan 2024, 16:32 » in Citroën - modellübergreifend - 0
- 650
Letzter Beitrag von UpHillHugo
Mercedes EQS und S-Class mit Level 3 gesucht
- 0
- 1221
Letzter Beitrag von RikeHKM
Fr 23. Jun 2023, 15:01
Mercedes Me Profile?
Letzter Beitrag von BEV4ever « So 21. Apr 2024, 17:49Antworten: 7
Verfasst in Mercedes-Benz - modellübergreifendvon Triple-M » Di 15. Aug 2023, 20:02 » in Mercedes-Benz - modellübergreifend - 7
- 1621
CCS defekt? Odysse Mercedes Werkstatt
Antworten: 10von Up-Up-Baby » Mo 21. Aug 2023, 08:22 » in EQV - Allgemeine Themen - 10
- 3041
Letzter Beitrag von env20040
Di 24. Okt 2023, 01:49
Eva Greiner, Mercedes-Benz Mobility über Bidirektionales Laden
von Petterson » Sa 28. Okt 2023, 19:43 » in Elektroauto Videos - 0
- 800
