Fluence BCI battery charge impossible
Hi. Dose anyone solve the problem with BCI. I have isolation level 2 problem. The car starts normal but after 5 mile drive I get first message BCI. I can drive even 50 miles but once I stop and turn the ignition off and start again I get message Electric motor fault. After 20 minutes all errors are gone and I can drive again. Can I put used parts, motor, charger and peb to fix my car?
Re: Fluence BCI battery charge impossible
- Danke erhalten: 7 Mal
Hi,
Ok pls let us know. I have been thinking that it might be possible to swap PEB from another vehicle if you take control PCB(upper pcb) from your old PEB and all other parts from another one. I am not sure if it is possible just my own thinking... Power electronics that usually fail are in lower part of PEB unit.
Also would it Be possible to swap PEB from another car If you also swap EVC from same car...
Tero
Tero
Hi,
If I have understood correctly EVC is synonym for ECU in electric cars. I do not know where it is located in Fluence. How did your motor replacement go? Here is a good video of PEB dismantling and explanation of its functions:
https://www.youtube.com/watch?v=drS3sEsxOO8&t=2s
Tero
Tero
- jmbpinto73
- Hat sich bedankt: 20 Mal
85 kWh battery
von john0032 » Mi 24. Mai 2023, 09:17 » in ID.Buzz - Batterie, Reichweite - 0
- 1417
Letzter Beitrag von john0032
85 kWh battery
App: Battery protection limit
Antworten: 6von mcluki99 » Mi 12. Jul 2023, 22:12 » in Enyaq iV - Allgemeine Themen - 6
- 1410
Letzter Beitrag von Enyaqee
Sa 15. Jul 2023, 11:59
eUp Steuergerät Battery Charger defekt
Letzter Beitrag von Rockevzel « Di 5. Dez 2023, 18:16Antworten: 10
Verfasst in e-up!, Citigoe iV, Mii electric - Allgemeine Themenvon mattes2570 » Di 21. Nov 2023, 18:56 » in e-up!, Citigoe iV, Mii electric - Allgemeine Themen - 10
- 1273
Battery pack heating system failure
Antworten: 2von k-EV-in » Do 30. Nov 2023, 20:06 » in MG4 Electric - Batterie, Reichweite - 2
- 708
Letzter Beitrag von k-EV-in
So 3. Dez 2023, 20:48
Battery Care Mode - bin ich zu doof oder das System?
Antworten: 24von Sneak-L8 » So 25. Feb 2024, 13:20 » in ID.3 - Laden, Ladeequipment - 24
- 2063
Letzter Beitrag von Sneak-L8
So 10. Mär 2024, 12:52
