Re: Hacking into Zoe's CANbus
jmeijer
24.11.2015 17:41The CanZe website is now available on tapatalk.
jmeijer
29.11.2015 12:46New version posted. If anyone of you have TPMS tyres and are using CanZE, please check the experimental section as we try to read out the tyres pressure. Any feedback on this is highly appreciate as none of us has those sensors installed.
29.11.2015 13:29I purchased the recommended dongle and it works with the CanZE app. Still some glitches in the app on my old Samsung S2 with Android 4.1.2 but I think the CanZE is still beta and not final.
Great tool and awesome work!
Zoe Intens R210 - schwarz - 17"- seit 04/2015
jmeijer
29.11.2015 13:32Thank you @holderer. Please report any issues you have on github. You need a (free) account for that, but then it will update you automatically with any changes that are reported on "your" issues.
https://github.com/fesch/CanZE/issuesRe: Hacking into Zoe's CANbus
02.12.2015 14:36Hi,
I have tried the following dongels:
dnt OBD2 (
http://www.elv.de/output/controller.asp ... ail2=43060) 55 Euro
maxiscan KW902 (see picture) 20 Euro
nothing worked. Is anybody around Rosenheim or Traunstein so I can test it and see if my Samsung is the problem or something else. I really would like to get access to my data
regards
Stefan
aktuell: Smart EQ4, Ioniq PHEV, bisher: Smart ED3, ZOE Q210, Lynch-Fiesta, Pinguin, City-El, Mini-El, div. Pflanzenöl-Fzge.
Elektromobilität einfach machen
jmeijer
02.12.2015 14:51From phone, so pardon terseness. Did you pair the device? And after that, selected it in canze? If you're not sure, please check the Q&A on the canze website, thanks!
02.12.2015 17:13jmeijer hat geschrieben:From phone, so pardon terseness. Did you pair the device? And after that, selected it in canze? If you're not sure, please check the Q&A on the canze website, thanks!
Yes, pairing with the phone went ok but after that no connection to canze or original KW902 Software. Sent it back. The effect is as you describe om Q&A: Power light comes on, bluetooth comes on for a short blink, pairing is confirmed with phone and thats it. Maybe it was a short circuit as you described in faulty KONNWEI. But I got it working in a BMW with the Torque-software, setting it up to "schnelle Kommunikation" and "disable ELM327 auto timimg adjust".
Do you think it makes sense to order another KW902 and try again?
regards, Stefan
02.12.2015 17:26jmeijer hat geschrieben:Thank you @holderer. Please report any issues you have on github. You need a (free) account for that, but then it will update you automatically with any changes that are reported on "your" issues.
@jmeijer:
Many Thanks for your reply. I already reported the issue on github, but it seems not to be an issue.
Just for my confirmation: There is currently no way to get the trip data or charge date logged on the smartphone?! Is this right?
Thanks and cheers
jmeijer
02.12.2015 17:37Correct, but it is the (slow) making.
jmeijer
02.12.2015 17:52In the section "stupid questions"
You did select the proper dongle in CanZE itself (in the settings screen, left top pull down menu in settngs) did you? Because until now the MAxiscans have worked mighty fine.
