Hat hier jemand den Chamäleon-Lader zum zweiten Mal erfunden?
Da hat doch Renault sicherlich Patentrechte drauf!
Scheint also nicht 1:1 Chamäleon zu sein, genau genommen Chamäleon ohne die Nachteile.The main idea is to introduce a multi-terminal device called motor/generator set to act like a motor in traction mode and like an isolated generator/transformer in charging mode. The so called motor/generator acts as an isolated three-phase power source after synchronization with the utility grid in charging mode. All machine windings are used in traction mode and are then reconnected in charging mode through a simple switching device.
