Upgrading Fluence battery with cells of Leaf GEN2 24kw battery
- Danke erhalten: 7 Mal
Hi,
Because SOH% in our Fluence is at 69% (And because of personal interest) I decided to take a route of replacing cells with ones from GEN2 Leaf 24kw battery. I already bought Leaf battery pack with 98% SOH out of 2015 Leaf. Should Leaf cells be same physical size and swapping cells be quite straightforward?
Tero
Tero
Re: Upgrading Fluence battery with cells of Leaf GEN2 24kw battery
- Danke erhalten: 57 Mal
Now I have these:
https://photos.app.goo.gl/cjFwPCoWvr8deDEf6
https://photos.app.goo.gl/Ftu54j4eY7c4V8Qr9
https://photos.app.goo.gl/Cc7y3NTux4K5dGYH8
Should these fit?
Should these fit?
Hi, they look very similar to the original Fluence cells but they are not identical.
I would expect the same issues that I had with the Leaf 30kWh cells:
- Different usage of the cooling mats
- Modification of the horizontal support bars
- Modification of the end-plates.
So, in the end, they will fit, but it's not a seamless replacement.
Cheers
Andreas
Cheers
Andreas
Hi Tero,
as I wrote in the modification thread I drove in summer 189km on a fully charged pack. That was 26kWh out of a 30kWh pack (SOH 102%). These values sound reasonable as the cells are only charged to 4.1V/cell in the Fluence.
For a healthy 24kWh pack you could expect getting about 20kWh.
Cheers
Andreas
Cheers
Andreas
It is done. And car still works Thank you very much Andi for great guide. Swap was similar to that you did. Only one minor difference was that cells with studs had bracket spot welded to other side so those had to be "flipped to get corret +-+-+- order for stacks. How soon should I expect SOH% to increase?
Tero
Tero
Congratulations - well done
But even without that you should see an increase every time you charge.
Cheers
Andreas
It will increase each time you charge. I did a full charge after I swapped and then dive the car until I was in turtle mode. Then I recharged.ow soon should I expect SOH% to increase?
Cheers
Andreas
Zurück zu „Fluence Z.E. - Batterie, Reichweite“
85 kWh battery
von john0032 » Mi 24. Mai 2023, 09:17 » in ID.Buzz - Batterie, Reichweite - 0
- 1312
Letzter Beitrag von john0032
85 kWh battery
App: Battery protection limit
Antworten: 6von mcluki99 » Mi 12. Jul 2023, 22:12 » in Enyaq iV - Allgemeine Themen - 6
- 1319
Letzter Beitrag von Enyaqee
Sa 15. Jul 2023, 11:59
eUp Steuergerät Battery Charger defekt
Letzter Beitrag von Rockevzel « Di 5. Dez 2023, 18:16Antworten: 10
Verfasst in e-up!, Citigoe iV, Mii electric - Allgemeine Themenvon mattes2570 » Di 21. Nov 2023, 18:56 » in e-up!, Citigoe iV, Mii electric - Allgemeine Themen - 10
- 1180
Battery pack heating system failure
Antworten: 2von k-EV-in » Do 30. Nov 2023, 20:06 » in MG4 Electric - Batterie, Reichweite - 2
- 634
Letzter Beitrag von k-EV-in
So 3. Dez 2023, 20:48
Battery Care Mode - bin ich zu doof oder das System?
Antworten: 24von Sneak-L8 » So 25. Feb 2024, 13:20 » in ID.3 - Laden, Ladeequipment - 24
- 1861
Letzter Beitrag von Sneak-L8
So 10. Mär 2024, 12:52
