EVNotify - überwache den Ladezustand Deines Elektroautos!
Re: EVNotify - überwache den Ladezustand Deines Elektroautos
- Hat sich bedankt: 80 Mal
- Danke erhalten: 143 Mal
Wieso? Du brauchst noch irgendein Gerät dazwischen. Wenn Du nur ein Smartphone hast, dann ist es das Smartphone, andernfalls ein anderes, ein Tablet oder ein TV Stick oder so.
Version 1.0.3. geht jetzt live
Entwickler der EVNotify-App
Folg mir auf Twitter
Hopefully the new version 1.0.3. which was released several minutes ago will now work fine - there was still the connection issue. I'm curious - I don't know why - the debug version (the version before getting signed with the release key to make it ready for upload to the play store) is literally the same as the release version. The debug version is workiing fine without problems.
I've changed the connection management - the data to the dongle will no longer be sent automatically when the app starts. You have to click on the play button once on the top to start the monitoring.
Hopefully this works - because this was the very old management in the prototype version.
The new version also comes with telegram integration.
Have fun!
More features will be added soon - but first the connection issue must be eliminated completly.
If you can try the new version, please report if it is working. And please try it several times (disconnect and connect the dongle again).
The car must be on or while charging!
Have fun!
I tested the version 1.0.3 and it works! Bluetooth connection was established manually with the "play" button in the upper right side. I also got the e-mail notification that the desired state of charge was reached! So basic functionality runs fine.
However, when I switch then to another app and came back later to the app, reconnection could not be established. Had to restart the ODB2 dongle first.
The app looks very nice. Already now!
Good work!
Good work!
Hyundai Ioniq Electric Comfort, seit Februar 2017
I'm so glad to hear that the new version works fine!
And also glad to hear that you received the notifications.
Do you still have the connection issue when switching to another app, when you restart the app? Or is a connection then not possible anymore and you have to reconnect the obd2 dongle? This information would help me to find a solution.
I think that switching back reconnects and reconfigures the connection even when there is a connection. That would be simple to fix
To stay up to date you can subscribe to the public telegram channel: https://telegram.me/evnotify
Closing (and killing) the app doesn't help. Just restarting the dongle works.
After I got the e-mail message about the desired charge, I restarted the dongle since the display still showed the target charge. Then I got a new e-mail about reaching the desired charge status.
Sent from my SM-G901F using Tapatalk
Okay thank you. I will try to find a solution for this.
Killing the app will reset the notification_sent information. So the app thinks you are not notified. This is a normal behavior. But reconnectiong the dongle shouldn't reset the notifcation_sent information. I think this is a problem again of this bluetooth plugin and its variable references. It might be possible that a disconnection and a reconnection will cause to a lost of any references.
Maybe I will find a workaround for this.
Thank you for the report
Also können iPhone-Nutzer trotzdem damit arbeiten, wenn sie für's Auto ein Android-basiertes Gadget haben, was die Kommunikation übernimmt. Richtig?GcAsk hat geschrieben:Wieso? Du brauchst noch irgendein Gerät dazwischen. Wenn Du nur ein Smartphone hast, dann ist es das Smartphone, andernfalls ein anderes, ein Tablet oder ein TV Stick oder so.
EVnotify Aktualisierung
von John2000 » Fr 13. Aug 2021, 22:11 » in andere Komponenten -
Letzter Beitrag von John2000
EVNotify wird den eGolf direkt unterstützen
von ePhilipp69 » Sa 11. Sep 2021, 20:35 » in e-Golf - Allgemeine Themen -
Letzter Beitrag von Vrabetz
Sa 11. Sep 2021, 21:43
Twingo und OBD-Daten z.B. EVNotify
von Fremderregt » Do 25. Nov 2021, 09:56 » in Twingo Electric - Batterie, Reichweite -
Letzter Beitrag von svrroot
Mi 26. Jan 2022, 05:52
OBD2 - MCE200 + EVNotify?
von luig » Sa 26. Mär 2022, 21:17 » in IONIQ 5 - Infotainment -
Letzter Beitrag von luig
Fr 8. Apr 2022, 13:17
Ladezustand über App aktualisiert nicht. Was tun?
von Bernd_1967 » Mo 18. Okt 2021, 15:13 » in Polestar 2 - Laden, Ladeequipment -
Letzter Beitrag von Gisela
So 8. Mai 2022, 12:30
