Das große Update 2.x oder 3.0 wie und wann geht es weiter?
Re: Das große Update 2.x oder 3.0 wie und wann geht es weiter?
- Hat sich bedankt: 144 Mal
- Danke erhalten: 100 Mal
Eben in der Facebook Gruppe:
Dear all,
The rollout of the next ID. software 3.0 OTA-wave will start this week. Please note that the rollout will take some time. Within the next few days, you will receive a confirmation via email as soon as your ID. is ready to receive the update.
As promised, and based on your feedback, please find a few helpful tips & tricks for an easier installation process below.
Once you have received the notification in the infotainment system that a new software update is available, please keep in mind the following tips:
1. Ensure a minimum SOC (State of Charge) of at least 50 % when parking your ID.
2. A stable mobile connection (at least 2 bars, 4G) must be established at the beginning of your trip and when parking your car.
3. The charging cable must not be plugged in before and during the installation process.
4. Your ID. must be “enrolled” (linked to your We Connect account via the We Connect ID. app) at any time.
5. In case you receive the notification “Software update available” in the infotainment system but the installation button does not appear, please check again if all previous tips have been considered. If so, you can trigger the installation button to appear by following these steps:
Leave and lock the car for at least 15 minutes with the keys out of the car's reach. Then go back to the car.
After entering the car, do not press the brake pedal. Instead, please wait at least 90 seconds before turning on the ignition using the ignition button behind the steering wheel.
Then wait again for at least 90 seconds before turning off the ignition.
You should now find the "update available" button in the exit panel.
6. If your ID. tells you to close all windows, please follow these steps:
Open all windows.
Now close one window after another. Each time a window is closed, shortly release and then pull again the window switch.
These tips & tricks will continue to be expanded over time thanks to your feedback. Thank you!
Our updates are designed in a way where you as the owner decide when to start the installation. Please remember that due to the holiday season, roadside assistance may be limited, so please keep that in mind when choosing a time slot for the installation.
Best regards,
Your Volkswagen ID. team
Dear all,
Open all windows.
Best regards,
Skoda Enyaq iV 80 (MJ21)
VW ID.3 Pro Performance (MJ22)
VW T1 "Westy" 1965
VW T1 "Westy" 1965
- Hat sich bedankt: 42 Mal
- Danke erhalten: 41 Mal
Bei mir kam soeben eine Mail rein ich wäre mal dran mit 3.0:
Hallo xxx,
ID. Software 3.0 – das neue Over-the-Air Update für Ihren ID.
Software-Updates bringen neue Funktionen und Optimierungen in Ihren ID.
Profitieren Sie davon, ganz einfach Over-the-Air!
Sie haben bereits die ID. Software 2.4 mit der neuen 12 Volt Batterie in der Werkstatt erhalten? Dann sind Sie jetzt vorbereitet für das nächste große Update.
Das ID. Software 3.0 Over-the-Air Update bringt zahlreiche Vorteile:
Batterieoptimierungen sorgen für eine verbesserte Ladeleistung und verkürzte Ladezeiten.
Der neue Batterie Care Mode unterstützt die Schonung der Hochvolt-Batterie.
Das optionale Augmented-Reality-Head-up-Display wird um zusätzliche Funktionen erweitert.
Die Zuverlässigkeit der Spracherkennung und Reaktionsgeschwindigkeit des Systems wird stark verbessert.
Das Navigationssystem bietet auf Autobahnen eine fahrstreifengenaue Routenführung.
Das neu strukturierte Lademenü macht Ladeeinstellungen- und Informationen für den Fahrenden schneller und intuitiver zugänglich.
Das ID. Light bekommt weitere Funktionen, wie zum Beispiel zusätzliche Signale zur Gefahrenwarnung und Parklückensuche.
… und viele mehr.
usw....
Hallo xxx,
… und viele mehr.
usw....
11/20-: ID.3 Max Makena-Türkis
12/22-: Tesla Model Y LR
https://www.tesla.com/referral/dennis785343 Tesla-Empfehlungslink
- Hat sich bedankt: 449 Mal
- Danke erhalten: 244 Mal
- Metal-Mike
- Hat sich bedankt: 68 Mal
- Danke erhalten: 139 Mal
Dito
noch ID.3 1.st Max - ID.3 GTX Performance bestellt, vsl Lieferung 01/25 - TONITY 4 Wochen Probezeitraum
- Hat sich bedankt: 31 Mal
- Danke erhalten: 49 Mal
Die Mails scheinen seit 10:30 rauszugehen bei vielen. Wegen des Update Tages bin ich noch verunsichert also 2.1 auf 2.3 ist mein Update Tag ein Dienstag.Ich meine aber auch Samstags schon was bekommen zu haben. Bin nicht mehr sicher.
ID.3 Fastlane Life Weiß ohne WP bestellt 24.07.
Bestellbestätigung 28.07. Fin seit 23.09.
Übergabe 13.10. Michelin Crossclimate
Gebaut KW37 Tag 2 Software 3.2
- Hat sich bedankt: 47 Mal
- Danke erhalten: 147 Mal
Laut Berichten aus der FB Gruppe ja es gibt viele die ein Update haben auch ohne Mail. Auch ohne i want ota geschickt zu haben.
Ist so ruhig geworden hier im Forum wundert mich.
- Hat sich bedankt: 241 Mal
- Danke erhalten: 518 Mal
Na so viele sind es nicht- ich habe nur von 2 usern in der Gruppe gelesen die das Update ohne „I want OTA“ und ohne Bestätigungsmail gerade bekommen haben.
I want OTA verschickt, nicht in der 1. Welle, und habe auch gestern die Bestätigungsmail bekommen.
Noch keine Software bisher angekommen.
VW id3 1st Max mit WP seit 10/2020. AHK nachgerüstet. Software 3.2 seit 5/23. Elli Pro wallbox, 70.000km.
max. Größe USB Stick
Letzter Beitrag von andreashab « Do 8. Feb 2024, 18:14
Verfasst in Mégane E-TECH Electric - Infotainmentvon andreashab » Do 8. Feb 2024, 18:14 » in Mégane E-TECH Electric - Infotainment - 0
- 1230
Superschicke Alu-Winterkompletträder für große SUVs zu verkaufen
von lordhelmchen » Di 8. Okt 2024, 14:04 » in Marktplatz - 0
- 78
Letzter Beitrag von lordhelmchen
Update Google Maps
Letzter Beitrag von Chris21 « Mi 11. Okt 2023, 15:35Antworten: 1
Verfasst in XC40 Recharge Pure Electric - Infotainmentvon JoeID » Mi 11. Okt 2023, 10:06 » in XC40 Recharge Pure Electric - Infotainment - 1
- 1540
Update Google Maps
Das neue Update scheint in den US angekommen
Antworten: 43von luig » So 15. Okt 2023, 17:11 » in IONIQ 5 - Infotainment - 43
- 5518
Letzter Beitrag von Tommy73_
Di 24. Okt 2023, 11:44
nissan connect update
Antworten: 8von einstein2000 » Mo 16. Okt 2023, 10:35 » in Leaf ZE1 - Allgemeine Themen - 8
- 1396
Letzter Beitrag von c2j2
Di 24. Okt 2023, 12:29
