Vestel EVC04 läuft! Erfahrungen, Probleme und Lösungen 10/2022
Re: Vestel EVC04 läuft! Erfahrungen, Probleme und Lösungen 10/2022
  • MoinMoin01
Hattest Du die Ladevorgänge denn über die App gestartet?
Tags: app drive-green drive-green-next evc04 firmware vestel web-gui
abecker
  • Danke erhalten: 1 Mal
Nein, steht auf Auto Start, hängt in der Garage die Box. In der App wird der Ladevorgang dann auch angezeigt.
zeroz
  • Hat sich bedankt: 5 Mal
  • Danke erhalten: 11 Mal
FW 3.150.0 Changelog:
• Improvements have been made to Rooter/LTE Connection switching.
• The problem of DLM charging current staying at 6A has been improved.
• Sensitive data such as AuthorizationKey in OCPP logs has been removed.
• The problem of the StopTransection message appearing again after the charging process with Soft Reset has been resolved.
• The StopTransactionOnEVSideDisconnect function has been ensured to work properly.
• The problem with TransectionID disappearing has been fixed.
• The problem with OTA files sent repeatedly has been resolved.
• The problem of backend disconnection after changing the heartbeat duration has been resolved.
• Synchronous operation of the LightInsensity parameter was enabled
• Daily Reboot can be adjusted via OCPP
• The problem of missing some languages when "WebconfigLanguage Get" is done has been fixed.
• The problem of DLM log files increasing in size has been fixed.
• Password display via Rest Api has been removed.
• Power Optimizer is active, the home load is activated and the error where the Tap your card or use mobile application appears on the device screen after the device is powered off has been fixed.
  • MoinMoin01
Schon installiert?
HWiLader
  • Hat sich bedankt: 26 Mal
  • Danke erhalten: 26 Mal
Ich habe es installiert. Lief alles normal. Keine Auffälligkeiten/Veränderungen zu V1.131.
VW ID.3 Pro SW3.7 2024/06, Vestel EVC04-AC22SW-T2P
tacjazo
  • Hat sich bedankt: 134 Mal
  • Danke erhalten: 189 Mal
Ich schreibs in diesen Thread auch nochmal:
Moin Leute,
hat einer hier es schon hinbekommen eine E.On-Vestel Box umzubranden, damit man die Drive Green App nutzen kann? Ich habe nur Probleme mit E.On bzw. E.On Drive und habe keinen Bock mehr auf die...
Hier könnte Ihre Werbung stehen!
abecker
HWiLader hat geschrieben: Ich habe es installiert. Lief alles normal. Keine Auffälligkeiten/Veränderungen zu V1.131.
Lief bei mir auch ohne Probleme durch.
WilhelmDerStromer
  • Hat sich bedankt: 37 Mal
  • Danke erhalten: 53 Mal
  • Website
Hallo HWiLader, ich habe auch die Version 3.150.0 per WLAN installieren können. Jedoch leuchtet der LED-Ring jetzt dauerhaft violett. Bei den Einstellungen hatte ich DIMM auf sehr niedrig eingestellt und Stand-by-Verhalten auf "aus". Irgendeine Idee, was ich tun könnte, damit der Ring nicht mehr leuchtet?
BMWi3 seit 2019; Wallbox Vestel am Stellplatz in Gemeinschaftsgarage mit Lastmanagement
http://wohnen-am-steinweg.de
HWiLader
@WilhelmDerStromer Hast Du dir Box nach dem Update mal redetet? Sicherung aus und nach paar Sekunden wieder an. Und dann über die Weboberfläche die Einstellungen überprüfen.
Bei mir war nach dem Update nichts verstellt. Die Farben des Rings beim Update habe ich noch nie verstanden, so wie sie weitgehend nicht der Dokumentation entsprechen. Bei mir ist der Ring aus, außer es ist ein Auto angeschlossen.
WilhelmDerStromer
  • Website
Ich habe die Stromzufuhr abgeschaltet und wieder eingeschaltet. Die Box aktiviert ja auch dann erst den Hotspot.
