Erfahrungen mit cFos Power Brain?
Re: Erfahrungen mit cFos Power Brain?
- Hat sich bedankt: 149 Mal
- Danke erhalten: 23 Mal
Meine Konfiguration (die Datei lässt sich nicht hochladen, sorry):
"params" : {
"title" : "cFos Power Brain",
"desc" : "Standard-Konfiguration",
"max_total_power" : 25000,
"power_reserve" : 0,
"overdraft" : 0,
"max_total_evse_power" : 11000,
"cons_pwr" : 282,
"prod_pwr" : 0,
"prod_pwr_w" : 0,
"error_pwr" : 0,
"grid_pwr" : 282,
"grid_pwr_w" : 282,
"storage_home" : 0,
"storage_all" : 0,
"cons_evse_power" : 0,
"avail_evse_power" : 11000,
"surplus_power" : 0,
"lb_enabled" : true,
"disable_policy" : 1,
"max_imbalance" : 4600,
"imbalance_add" : false,
"min_pause_time" : 300,
"reduce_on_com_err" : false,
"ocpp_srv_tls_mode" : "off",
"ocpp_srv_port" : 19520,
"ocpp_srv_use_ext_cert" : false,
"ocpp_srv_cert_fn" : "",
"ocpp_srv_private_key_fn" : "",
"ocpp_srv_cacert_fn" :
"ocpp_srv_password" : "",
"price_model" : 0,
"fixed_price" : 0,
"lm_mqtt_broker_url" : "",
"mqtt_publish_dev_info" : false,
"mqtt_dev_ctl" : false,
"api_mqtt_broker_url" : "",
"last_budget_reset" : 77,
"surplus_expr" : "",
"cycle_time" : 3009,
"max_evses" : 3,
"shareware_mode" : false,
"version" : "1.18.0",
"time" : 1679094001,
"vsn" :
"vendorid" : 52997,
"version" : 17958664,
"productid" : 1,
"serialno" : "W00-020R",
"platform" : "esp32"
"cpu" : 26,
"mem" : 50,
"cm_vars" :
"vars" :
"cm_outs" :
"users" : [
"id" : "045769798317",
"name" : "Fahrer",
"display" : false,
"show_evse" : true,
"rfids" :
"charging_rules" :
"devices" : [
"dev_type" : "meter_virtual_grid_demand",
"device_enabled" : true,
"name" : "Grid Demand (VM)",
"address" : "",
"id" : 1,
"dev_id" : "M6",
"number" : 7,
"desc" : "Netzbezug",
"is_evse" : false,
"is_virtual" : true,
"used_phases" : 7,
"hproxy_allow" : false,
"hproxy_cookie" : false,
"enable_history" : false,
"hide_dev" : false,
"show_in_overview" : true,
"show_chart_in_dev_info" : true,
"show_chart_in_overview" : false,
"role" : 0,
"factor" : 1
"dev_type" : "meter_virtual_surplus",
"name" : "Surplus (VM)",
"address" : "",
"id" : 1,
"dev_id" : "M5",
"number" : 6,
"desc" : "PV-Überschuss nach Abzug des Hausstromverbrauchs",
"is_evse" : false,
"used_phases" : 7,
"hide_dev" : false,
"role" : 0,
"factor" : 1
"dev_type" : "meter_tasmota_http_json",
"name" : "Tasmota",
"address" : "192.168.31.155",
"id" : 1,
"dev_id" : "M4",
"number" : 5,
"desc" : "Hichi IR-Lesekopf",
"is_evse" : false,
"is_virtual" : false,
"used_phases" : 7,
"hide_dev" : false,
"role" : 3,
"factor" : 1
"dev_type" : "meter_dts353",
"name" : "Wallbox Zähler",
"address" : "meter3",
"id" : 101,
"dev_id" : "M3",
"number" : 4,
"desc" : "cFos Power Brain, Modbus Zähler",
"is_evse" : false,
"used_phases" : 7,
"hide_dev" : false,
"show_in_overview" : false,
"role" : 4,
"factor" : 1
"dev_type" : "meter_powerbrain",
"device_enabled" : false,
"name" : "S0 Zähler 2",
"address" : "meter2",
"id" : 3,
"dev_id" : "M2",
"number" : 3,
"desc" : "cFos Power Brain, S0 Zähler 2",
"is_evse" : false,
"used_phases" : 7,
"hide_dev" : true,
"role" : 0,
"factor" : 1,
"modbus" :
"enable" : false,
"id" : 3,
"port" : "4703"
"pulses_per_kWh" : 0
"name" : "S0 Zähler 1",
"address" : "meter1",
"id" : 2,
"dev_id" : "M1",
"number" : 2,
"desc" : "cFos Power Brain, S0 Zähler 1",
"is_evse" : false,
"used_phases" : 7,
"hide_dev" : true,
"role" : 4,
"factor" : 1,
"modbus" :
"enable" : true,
"id" : 2,
"port" : "4702"
"pulses_per_kWh" : 1000
"dev_type" : "evse_powerbrain",
"name" : "Wallbox",
"address" : "evse",
"id" : 1,
"dev_id" : "E1",
"number" : 1,
"desc" : "cFos Power Brain 11kW - ab 4,5kw startet Überschussladen",
"is_evse" : true,
"used_phases" : 7,
"hide_dev" : false,
"charging_enabled_plugged_out" : false,
"label" : "",
"min_charging_cur" : 6000,
"max_charging_cur" : 16000,
"prio" : 1,
"phase_rotation" : 0,
"fixed_rfid" : "",
"enable_wakeup" : true,
"enable_snooze" : true,
"battery_save_threshold" : 0,
"battery_save2_threshold" : 0,
"ocpp_gateway_server_addr" : "",
"ocpp_gateway_password" : "",
"ocpp_gateway_client_id" : "",
"ocpp_gateway_socks_host" : "",
"ocpp_gateway_socks_authentication" : 0,
"ocpp_gateway_use_ext_cert" : false,
"ocpp_gateway_cert_fn" : "",
"ocpp_gateway_private_key_fn" : "",
"ocpp_gateway_cacert_fn" :
"save_signed_data" : 0,
"attach" : "M3",
"users" :
"charging_rules" :
"days" : 127,
"mode" : 5,
"current" : 6500,
"enabled" : true,
"solar" : 0
"modbus" :
"enable" : true,
"id" : 1,
"port" : "4701"
"def_charging_enable" : true,
"def_charg_cur_limit" : 16000,
"def_fixed_current" : 16000,
"relay_select" : 0
- Hat sich bedankt: 49 Mal
- Danke erhalten: 221 Mal
Moin,
der Startstrom in der Regel darf nicht Null sein!
Möchtest du reinen Überschuss laden, setzte den Wert auf 6000 (=6A = min. Ladestrom nach Typ2 Norm)
Nimmst du Netzbezug in kauf kannst du einen Wert zwischen 1 - 5999 setzen. Dann wird, sobald der Startstrom erreicht ist, mit 6A geladen und die Differenz aus dem Netz bezogen.
- Hat sich bedankt: 103 Mal
- Danke erhalten: 952 Mal
Danke für die Mühe. Ich habe es heute nochmal probiert, und das Problem ließ sich nicht mehr reproduzieren.
Ich habe leider mehrere Kleinigkeiten an der Konfiguration geändert (z.B. bei der Wallbox L1,L2,L3 -> L1), irgendwas wird da wohl falsch gewesen sein. Hätte ich die Bilder nicht würde ich mir selber nicht glauben
Was mir im Bezug auf Speicher immer noch nicht klar ist:
Wie kann ich die Wallbox so einstellen, dass sie erst startet, wenn der Speicher auf z.B. 90% geladen ist?
Die Daten dazu gibt die API der Sonnenbatterie her, aber eine entsprechende Funktion hätte ich nicht gefunden.
Desweiteren lädt das zweite Auto (ein Corsa) an der Wallbox nicht einphasig: Wenn ich L2 und L3 ausschalte, dann lädt nur noch der Leaf. Da bin ich aber noch am herumprobieren. Witzig ist, dass das einphasige Laden des Corsa definitiv funktioniert, mit dem beiligenden EVSE sowie einem in der Garage vorhandenem Morec-Kabel mit CEE-blau.
Schön das es jetzt klappt.
Leider kann ich dir mit dem Speicher nicht richtig helfen.
Aber, wenn du Lust auf Experimente mit der Speichereinstellung hast, schau mal hier:
https://network.cfos-emobility.de/antwo ... n-gesucht/
- Danke erhalten: 18 Mal
Die neue Power Brain mit Phasenabschaltung ist nun raus. Kostet 50€ mehr als die alte. Vielleicht kommt ja noch ein Umrüstkit.
Mit diesem Code gibt es 20€ Rabatt auf eine cFos Power Brain Wallbox: 02475C2D7AA
https://shop.cfos-emobility.de/ghp/e1L4W
- Hat sich bedankt: 80 Mal
- Danke erhalten: 60 Mal
das kommt mit Sicherheit
allerdings schade, das die Umschaltung nicht vollautomatisch wie bsplw. bei der openwb oder zappi funktioniert
https://shop.cfos-emobility.de/blogs/ne ... lbox-solar
ist die Frage, ob ein "Ladevorgang stoppen" via AutoApp und das Umstellen an der cfos erlaubt und den Ladevorgang dann wieder starten lässt
Model 3
cfos Powerbrain 11kW @Home , cfos WB Thread
20€ Rabatt pro cfos Wallbox? Gerne über meinen Referral Link
PV Solax + Deye
PV Solax + Deye
Folgendes habe ich gestern auf Nachfrage vom Support bekommen:
"Wenn Sie Bestandskunde sind und Ihre Wallbox nachrüsten möchten,
lesen Sie bitte die Hinweise auf der folgenden Seite und füllen das Formular "Nachrüstkit Solar" aus
https://network.cfos-emobility.de/cfos- ... kit-solar/
Am besten prüfen Sie vorher welcher Controller in Ihrer Wallbox verbaut wurde:
https://network.cfos-emobility.de/antwo ... ontroller/
179€ ist schon happig.
Mein Elektriker möchte mir keinen FI-Schalter einbauen, bei dem ich die Phasen einzeln ein- und ausschalten kann, weil es gegen eine Norm verstoßen würde.
- Hat sich bedankt: 66 Mal
- Danke erhalten: 75 Mal
Ja, wenn eine Phase einen Fehler hat, müssen alle 3 Phasen abgeschaltet werden. Das geht nicht mehr, wenn du 3 einzelne FI-Schalter hast.
Bei den 179€ wird es aber wohl nicht bleiben:
(Tippfehler sind Eigentum von cFos)Wichtiger Hinweis
Der Umbau darf nur von einem Elektriker vorgenommen werden. Die Kosten dafür übernehmen wir nicht.
Die Fachkraft muss alle weiteren, benötigeten Bauteile, wie Anschlulsslemmen, Drähte oder Kabelsätze selbst bereitstellen.
VW ID.4 Max (bestellt 16.02.21, ausgeliefert 07.10.21)
cFos Power Brain (installiert 29.04.21)
Setz halt einen Fi und dann einzelsicherungen dahinter für eine manuelle Umschaltung
Danke für den link mit Preisen, hätte mit einer höheren Inzahlungnahme des Alten Controllers gerechnet.mh
Model 3
PV Solax + Deye
PV Solax + Deye
- Hat sich bedankt: 25 Mal
- Danke erhalten: 16 Mal
Ich finde €49 für den zusätzlichen Schütz fair. Dass der alte Controller das nicht kann - schade, aber nicht unverständlich. Und der neue für €130? Eigentlich doch auch okay. Dass überhaupt nach- oder umgerüstet werden kann: Vorbildlich.
Dass die Umschaltung nicht dynamisch erfolgt, ist schade. Andererseits ist einer unserer beiden Stromer eine Zoe - da ist mir das aus Sicherheitsgründen eigentlich sehr recht.
gruesse
secuder
gruesse
secuder
Verkabelung cFos Power Brain Solar (evcc, §14a)
Antworten: 3von HyIo5 » So 16. Mär 2025, 14:29 » in Private Lade-Infrastruktur - 3
- 337
Letzter Beitrag von Hofer60
Do 20. Mär 2025, 18:50
Ionity Passport Power kündigen
Antworten: 5von luig » Fr 12. Jul 2024, 09:49 » in Betreiber, Roaming und Abrechnung - 5
- 1447
Letzter Beitrag von Tommy73_
Fr 12. Jul 2024, 11:11
Strategien des Power Sharing bei öffentlichen DC-Ladepunkten
Antworten: 9von Rico Chet » Mo 21. Okt 2024, 17:15 » in Öffentliche Lade-Infrastruktur - 9
- 801
Letzter Beitrag von Helfried
Do 24. Okt 2024, 15:17
Tracmax X Privilo, Tracmax Trac Saver, Tomason Sport Race oder Tourador I-Power EV1 auf dem I3S
Antworten: 4von Jodeci » Mo 31. Mär 2025, 07:33 » in i3 - Allgemeine Themen - 4
- 700
Letzter Beitrag von Jodeci
Sa 5. Apr 2025, 16:15
Günstig AC am Supermarkt laden - Erfahrungen
Antworten: 27von georgij » Do 16. Mai 2024, 21:21 » in Betreiber, Roaming und Abrechnung - 27
- 4245
Letzter Beitrag von Athlon
Mo 1. Jul 2024, 08:08
