Mennekes ladekabel error: Hausinstallation Fehler
Does anyone know what type of tests the Mennekes ladekabel mode 2 does in order to come back with a Hausinstallation Fehler.
Connecting the cable to most 220 V outlets in my house does result in the Fehler. However a few outlets do not produce the error and I can charge just fine from them.
BTW The charging cable from BMW-i3 broke (electronically) within 2 years (450 euro), so thats why I switched to Mennekes.
Dick
Dick
Re: Mennekes ladekabel error: Hausinstallation Fehler
Hi Thomas,
I tried to reverse the polarity to no avail.
Here is one further piece of info that might indicate what Mennekes checking of the Hausinstallation embodies. When I use a working outlet but this time with an extra extension cable from that 'working' outlet, Mennekes reports by a red LED again that the Haus-installation has to be checked. So Mennekes may be checking impedance? (In the latter case with the extension cable I didn't reverse polarity so maybe that explains this behaviour with the extension cable. I have to repeat the test when I am back where I had this problem). Dick
- Hat sich bedankt: 33 Mal
- Danke erhalten: 40 Mal
I might be mistaken, but perhaps the ICCB simply measures the conductivity of the protective earth conductor, just as you suspected in your 2nd posting. Can you give as any more details about the conditions of your house installation? Age, dimensions of the mains, how many terminals between outlet and house connection point?
- ecopowerprofi
- Hat sich bedankt: 194 Mal
- Danke erhalten: 501 Mal
Is it possible that in 220V outlets the PE-pin is disconnected or not avaiable?
ZERO APP -> Error usage_expired
Antworten: 5von Disasterwildboy » Fr 5. Mai 2023, 10:16 » in Zero Motorcycles - 5
- 754
Letzter Beitrag von Disasterwildboy
Mi 10. Mai 2023, 09:51
Be Charge - Bezahlmethode Error
Antworten: 9von charly74 » So 4. Jun 2023, 14:55 » in Betreiber, Roaming und Abrechnung - 9
- 769
Letzter Beitrag von Boris6
Di 6. Jun 2023, 09:13
Fehler: "Hochvolt Fehler" & CCS laden geht nicht
Antworten: 8von I3sMUC » So 17. Dez 2023, 14:59 » in i3 - Antrieb, Elektromotor - 8
- 1293
Letzter Beitrag von BMW EV
Mo 8. Jan 2024, 15:08
Mennekes Amtron Compact 3,7 / 11 C2 reduzierte Ladeleistung klappt nicht
Antworten: 4von Juanle » So 11. Jun 2023, 18:46 » in Private Lade-Infrastruktur - 4
- 613
Letzter Beitrag von VolkerK
Mi 6. Dez 2023, 18:20
Mennekes Wallbox: zeitgesteuerter Ladevorgang möglich?
Antworten: 2von MasterChief » So 8. Okt 2023, 10:53 » in Private Lade-Infrastruktur - 2
- 368
So 8. Okt 2023, 11:13
