Hacking into Zoe's CANbus
Zubehör für den Renault ZOE
Re: Hacking into Zoe's CANbus
- Hat sich bedankt: 30 Mal
- Danke erhalten: 40 Mal
It looks to me the left two windows are fine. The right ones should build up a graph, you need to keep it running for a few minutes. It looks like the top right screen it has received some data.
Anyway, can you please report the issue here?
https://github.com/fesch/CanZE/issues
That way the developer who made this particular screen can ask detailed questions and you will be automatically notified if there are changes made. Thank you!
Jeroen - ZOE Q210 Nov 2013 - PV powered - CanZE co-developer http://canze.fisch.lu
Thank you. You are right, the right ones build up a graph. The screenshot had been taken while the mobile phone was not connected.
My problem is that I can't enlarge the diagrams/graphs to read it clearlier. Sometimes it works, sometimes it doesn't.
12/2015 - 07/2019 Renault ZOE zen in taupe-beige, mit Wallbox wallb-e 11kW
11/2021 - 11/2023 smart fortwo EQ blau / silber
seit 08/2022: VW ID.3 Pro S in stonewashed-blue
seit 11/2023 - smart fortwo EQ Brabus Edition british-racing green
The tapping problem is found and fixed. That fix will be incorporated in the next release. https://github.com/fesch/CanZE/issues/301
Please report crashed if they happen on github with as much detail as possible, Thanks!
- Danke erhalten: 49 Mal
Motorola Moto G2 with Android 5.0.2 also works fine with CanZE using MaxiScan Dongle.
Sascha
Sascha
eUp! Style, seit 02/21
Tesla Model ≡ LR AWD, Midnight-silver, seit 09/19
verkauft: Twizy , Zoe Q210, Peugeot iOn
1.500 km kostenloses Supercharging: https://ts.la/sascha67503
- Hat sich bedankt: 562 Mal
- Danke erhalten: 4693 Mal
Hi to all the great engineers of this great project.
I am working on something similar, on a fix installed Display. But we have not all the Information about the CAN Matrix, so we stuck a little bit.
Is it possible to share the information so that we get a new boost in our project?
PS: I tested your Software on a SONY XPERIA, Modellnummer E2105, Prozessor MT6582, Android 4.4.4 and it works great on this phone. Only the linking to the bluetooth Device is not able to deal with the R-Link. The phone should be deleted from the R-Link system and the Device should not be cold....
Zuletzt geändert von AbRiNgOi am Fr 8. Jan 2016, 16:12, insgesamt 1-mal geändert.
Aktuell: 150.000 km
Aktuell: 150.000 km
Sure. The entire project is Open Source. https://github.com/fesch/CanZE
The field definitions can be found in Class "Fields".
Of course we wouldn't mind acknowledgement or maybe even software development contribution, but it's free (as in: free beer)
of course you get all our SW-source-code, but it is C-code, I am not familiar with Java and so. I have some Ideas about a new display of the cell-Voltage or to calculate some parameters like driving resistant and air resistant out of car running out from high speed.
Of course the source code will be yours!
Aktuell: 150.000 km
Aktuell: 150.000 km
Awesome project! Is there some other, similar project available as Open Source, too, for normal cars?
I'm asking because I've already tried to get an Arduino with HC-05 BT shield to connect with my older OBD2-BT adapter but without much success (setting up a reliable blue tooth connection was the problem).
What I would do, is diagnose if the problem is between the HC-05 and the Arduino (i.e. using SoftwareSerial). To do that, wire your HC-05 to your PC, like in my video. It was absolutely rock solid reliable in my case. https://www.youtube.com/watch?v=TQRatlPNUmw
I don't really understand though what you meant. For an ICE car, things like Torque (light) work pretty well, depending on your goals of course. If you want to use this setup for the Zoe, I strongly advice you not to go the dongle + BT + Arduino AVR route, but use a tranceiver + Arduino Due. Cost is the same, much more reliable and blazing fast. https://www.youtube.com/watch?v=6Ei03NHvTKA . Timing and buffer issues are pretty hellish with the dongles.
Some more info on the Hardware page http://canze.fisch.lu/hardware/
- 6781
Letzter Beitrag von quasimodo
Fr 15. Dez 2023, 17:10
Reichweite ZOE ZE40
- 2964
Letzter Beitrag von E-Fan66
So 11. Jun 2023, 21:52
Reichweite ZOE ZE40
- 737
Letzter Beitrag von tbline67
Di 13. Jun 2023, 11:08
- 557
Fr 16. Jun 2023, 07:28
Kaufberatung Zoe für Rentner
Antworten: 43von MasterGreen » Fr 16. Jun 2023, 15:14 » in ZOE - Allgemeine Themen - 43
- 2683
Do 29. Jun 2023, 19:12
