Vorstellung SETEC 10KW mobiler CHAdeMO Lader
Re: Vorstellung SETEC 10KW mobiler CHAdeMO Lader
No problem for asking.
If the 40kw charger with both cable is comissioned before Christmas it will be 22.000 eur w/o VAT.
Charging stations where you can charge for free are nice but most companies are not so altruistic. We plan on offering these with the option to charge money for charging cars. If you don't want that function it's ok.
- Hat sich bedankt: 159 Mal
- Danke erhalten: 218 Mal
Ok, thank you very much for your Information
Charging power can be adjusted.Blue shadow hat geschrieben:It depends of what is module worth for you...no trick...
In the moment It would make no sence for me to buy half of a 20kw charger ...no cargo space left
It is important that you can reduce the power to 22 kw or 11 kw...
You can charge for free...you can fill the battery gratis.
- Hat sich bedankt: 2387 Mal
- Danke erhalten: 1647 Mal
I believe the next 2 years it will be free, but at the end they will make profit...sanicare - charge for toilett you get a discount for coffee and tesla will earn money with the SUC..
So ...are you able to send us the charging protokolls...what cars do you have for testing?
For public short distance transportation it would work quite well...
Probably.
What do you mean the charging protokolls ?
So far we have tested only Nissan Leaf with Chademo but it has been confirmed to work with Tesla adaptor as well.
Not a lot of DC charging cars in Romania.
My own i3 94Ah is coming in the last week of November so that will be the test bed for CCS connection.
I would like to see a japan and a euroleaf on the 20 kw charger....a leaf spy charging protokoll and some dc current when
Soc 10,20,50,70,80,90,100%
Leaf spy is an app ....obd can bus bluetooth reads out info from leaf
Erfahrungen mit Enercab mobiler Wallbox
von R.S. » Mi 26. Apr 2023, 14:36 » in Private Lade-Infrastruktur - 0
- 319
Letzter Beitrag von R.S.
Leasingfahrzeug Fiat 500e, kann ich mit mobiler Rückfahrkamera „nachrüsten“? Oder geht auch ohne?
Antworten: 8von ABC » Fr 14. Jul 2023, 17:36 » in 500 Elektro - Allgemeine Themen - 8
- 981
Letzter Beitrag von Toschi
Sa 15. Jul 2023, 23:02
- 522
Letzter Beitrag von Xentres
Di 31. Okt 2023, 11:49
Honda e:Ny1 - Vorstellung
Antworten: 36von Helfried » So 14. Mai 2023, 19:10 » in Honda - modellübergreifend - 36
- 6142
Letzter Beitrag von isolar
Fr 12. Apr 2024, 14:14
Vorstellung eines neuen Mitglieds
Antworten: 7von Nitschi66 » Mo 24. Jul 2023, 15:06 » in Ampera-e - Allgemeine Themen - 7
- 838
Letzter Beitrag von Kehrmaschine
Mo 14. Aug 2023, 20:33
